This unit came fitted in RAV4 with manual in Japanese. Will accept CD disc into unit but can not select CD play option. (Manual shows a remote control which I do not have if this is significant).
regards
The remote control missing shouldn't be a factor - Pioneers will usually select the same sources with the "source" button as they will with the remote.
I would suggest 2 things - first, try different CDs. If it's accepting and ejecting just fine it may be a problem with reading your CD (I'm assuming you haven't tried this already). Ideally use a regular audio CD (not an MP3/WMA disc) that is relatively scratch free.
If that doesn't work, check to see if the initial settings can be adjusted to enable CD play.
To get to the initial settings menu you need to hold the "source" button until the unit powers off (the car's key will still need to be on at this point). Push and hold the "function" button and it should go into a menu with various adjustments, such as clock, aux enable, etc...
There may be a setting in there to enable CD play. I realize that the display may also be in Japanese but I'm hoping it will be somewhat intuitive for you - you seem to have a decent technical grasp on things already.
Describe your Jeep engine code Number one cylinder misfire. Check engine light come on. #1 cylinder...
(More)
Describe your Jeep engine code Number one cylinder misfire. Check engine light come on. #1 cylinder misfire. Clear code, OK for a period of time, then shows up again Also hard starting. 1997 Jeep 4. w/ std 5 speed
i need to find the part that recieves the wiring harness, the black plastic piece that attaches to...
(More)
i need to find the part that recieves the wiring harness, the black plastic piece that attaches to the back f the cd player itsself
After moving Alpine iDA-X200 from one car to another, Ipod and USB sources have no audio. Power is...
(More)
After moving Alpine iDA-X200 from one car to another, Ipod and USB sources have no audio. Power is available to Ipod and USB (they are flashing normally). Radio is fine. Unit reset button pressed but no success. What am I missing? Rick
