I have a gateway LP2407 monitor power is on BUT no picture
    President:
  • 2,923 Answers
There are several reasons why there's no picture. It could be the video card, monitor cable or it could be the monitor itself.
Try connecting the monitor into a known working computer to make isolate the problem. If the monitor works on another PC, then the problem could be your video card.
But if the same problem occur while on another computer, try replacing the monitor cable. If that did not help, then the panel could be shot. We cannot say that it's the power supply board because there's a power. So it could be the panel itself.
Good luck and have a good evening!
Posted on Feb 07, 2010
No picture on my Gateway monitor My Gateway FPD 22755W TFT LCD Monitor powers up but has no picture. The blue lights on the lower righthand side come on. It makes the little banjo strum, but absolutely no...
First of all disconnect the power & unplug the video cable from the back of the CPU & Monitor. Power-on the monitor & wait 10 secs. If the Monitor is functioning correctly, a 'No Signal' message appears & sometimes keeps bouncing around like a screen saver motion. This means your monitor is OK, if no signal message is not showing then either backlight or inverter(power) input has gone KAPUT. Replacing either or both may not turn out to be a cost effective soln. However if the damage is only in the cable then simply replace it or use the HDMI port..........................Sodeep63
Nov 11, 2012 | Computers & Internet
How to take the cover off an LP2407
There are 3 screws along the bottom of the monitor, remove those along with any screws where the stand is attached. There are 2 slots on the bottom where the halves of the monitor come together; with a screw driver, you can use those for leverage. With another small screwdriver on the sides of the monitor where the front shiny cover, and the duller back case come together, pry the shiny piece away from the back cover and lift. It is a very tight snap fit, you have to go slow and coax it off.When you get the front cover started you can usually pull it off with your fingers by lifting up. Be very careful Of the front panel switch ribbon cable it is very easy to break. Hope this helps
Nov 02, 2012 | Computers & Internet
Where can i get an owners manual for gateway monitor lp2407
can't find user manual, what is the problem with your monitor .
Aug 13, 2012 | Computers & Internet
I'm having trouble with my Gateway monitor coming on model # LP2407
Steve
there are so many things that can go wrong, the best thing is to take/send to a professional , or i can take a look at it.
many repairs are the standard capacitor replacement, but many others should be done by someone that has a bit of background in electronics to test all the circuits. For more help i can be contacted at Sprint6@zoominternet.net.
if you would like i can test the unit, at no cost to you, and give an estimate of repair cost once i have evaluated the condition of the unit.
Dec 01, 2011 | Computers & Internet
On my Gateway FPD2275w HD computer monitor I have power but no picture or menu image, it is just a totally black screen..
Coomon problem with this monitor is due to bad caps as shwon in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/GATEWAY/Gateway%20FPD2275W/
This is not an easy set to take apart, you must be real carefull on the front bezel cable assembly.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 25, 2011 | Gateway FPD2275W LCD Monitor
Power went off and now my gateway monitor displays GatewayWhield theft Deterrence. I never set up a password how do I fix this problem. Connect the monitor to the pc you would think fixes it but no. Help
Disable GatewayShield Theft Deterrence
  1. Launch EzTune.
    View Picture
  2. In the EzTune window, click the Plug-ins tab, and then click Theft Deterrence.
    View Picture
  3. To deactivate theft deterrence, click Disable Theft.
    View Picture
  4. Type the PIN for the monitor in the appropriate field, and then click Accept.
    View Picture
  5. A screen confirms that theft deterrence is now disabled.
    View Picture
Dec 03, 2010 | Gateway FPD1785 Monitor
I have a gateway lp2407 monitor and can not get a picture but the power is on. The blue display lights on the right side of the frame light up, then go away while the power button stays blue. Tried...
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 24, 2009 | Televison & Video
Gateway LCD powers on but has no picture
To solve your problem you can go to any rad shack or electronics store and pick up a DVI-AVG adapter. The're about $14.00.
Jan 16, 2009 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Power button does not light up and no picture.
Look for bad cap, should replace them as as set (red marking as shown in my pictures).
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
3: 680uF 25VDC
1: 1000uF 25VDC
3: 470uF 35VDC
Apr 24, 2008 | Gateway FPD2275W LCD Monitor
311 people viewed this question
jasbo
jasbo
