Question about D-Link Computers & Internet
My router won't work with my Qwest modem.
I bought a new laptop with a new D-Link modem. My Qwest modem and my D-Link router don't seem to talk to each other.
  • 2,260 Answers
Are you trying to set up the router.
You can do it manually without the CD.
When you connect the computer to the quest modem, does it work?
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Feb 08, 2010
Trying to connect dir-615 to qwest modem pk5000z. Can you help? We have two computers hooked up to pk5000z.
It looks like the Qwest modem is a modem/wireless router. It's hard to set up a router through a router. It's easier to connect multiple devices with a switch or hub going through a router then a router through a router. Other then me trying to guess at the problem below is a link to Qwest's support page. They have an excellent support page with troubleshooters, manuals and guides. I would try there first because the support page is so good.
If you don't need the second router then please don't try to set it up.
May 19, 2011 | D-Link DIR-615 Wireless Router
Just bought new laptop with window 7 i alreadu have a desketop ant two laptop using window vista on network the new compuuter won t connect
first be sure to check that your wi-fi in on on your laptop. the next step is to reset your router, if that does not work, reset your modem as well.
Mar 11, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
We have actiontec verizon router/modem GT704WG. We have to reboot our computer and router multiple times a day to get the internet to work. It will be working, then all of the sudden it just stops, and we...
I have had this same problem with Qwest using a new iMac and MacBook on the Actiontec modem. Qwest did two things: first we reset the modem which was fairly simple and took only about 5 minutes. However, this fix lasts only a few weeks and it comes back. I have just ordered a new modem since there seems to be a problem with the Actiontec device with the newer high speed internet.
I'd try the reset before doing anything else. Good luck.
Jun 25, 2009 | Actiontec GT704WG Wireless Router...
Want to use Dlink DI-514 with Qwest modem to hardwire 2 computers
Believe it or not, Actiontec modems from Qwest are setup as a router already (even though ports are missing from it). You should use a switch instead of another router. Otherwise you will have to configure the DI-514 to act as a switch rather than a router. This is done by assigning a new starting IP address into your DI-514. By default both routers use 192.168.0.1 as the default. You will have to plug the DI-514 seperately into a computer (to take it off the network) and assign a new starting IP address for the DI-514 such as 10.150.1.1 for example. Then you will be able to get it work. I would strongly recommend using a switch instead and turn the wireless on the modem itself (this is why the modem is the router). It will save you some headaches if the power goes out.
Feb 04, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Problem between my Qwest actiontec modem and D-link router
You need to sign into the dlink router and check the status tab, to make sure that the router has picked up the modems IP address. it sound like it hasn't, and is just assigning lan IPs to the client machines, butd oes not have a valid WAN IP to the internet.
If it hasnt got a wan ip, you want to do a hard boot on the router .unplug the router ONLY for 30 sec, and power back up the router only ...not the modem this should allow the router to find the modem IP
Dec 30, 2008 | D-Link DIR-625 (790069292637) Wireless...
I keep getting print spool message about my printer, I just hooked up a new Qwest modem with wireless
I found that you need the newest driver from the HP site and you may need to load it again and have it look for your printer IP address automatically, Mine was a pain at first and every time I have replaced my switch ot network router I have had to "rediscover" the printer as the network seems to ignore it...
Oct 09, 2008 | HP Office Equipment & Supplies
D-link 614+ will not connect with Qwest M1000 modem
Well what everybody really doesnt know is that if Qwest provided you with a modem named Actiontech that modem has the same ip address of router so just change routers ip address to 172.16.0.1 and subnet mask to 255.255.0.0 and the problem should be solved.Im a product specialist for dlink.
Aug 27, 2008 | D-Link AirPlus DI-614+ Wireless Router
Ip problem
It is common to have this as the default IP to connect to equipment.
I suggest you unplug your modem while you set up your router. You can also change the default IP for the router while in the settings. be sure to remember the new IP or you will have to do a factory reset to get it back to default
Jul 03, 2008 | D-Link 802.11g Wireless Router WBR-1310...
We recently got high speed internet from Qwest. It will not work. It keeps saying that the can't "ping" it. All light are green; power DSL, and the Ethernet. The internet is not. I have...
The DSL router/modem will receive an address from your ISP (Qwest) and will assign an address to the connected PC.
There should be a cable that goes from your DSL modem to your PC. It'll either be a USB cable (flat rectangular plug on the PC end), or a RJ45 (looks like a wider telephone plug).
If there is neither connection between the DSL modem and your PC, then the PC can't "talk" to the DSL modem, so it's not getting an address from the DSL modem.
Apr 06, 2008 | Computers & Internet
Computers & Internet Logo
297 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
