Question about Logitech X-540 Computer Speakers
Sub woofer got weak
My sub woofer got weak shortly after I bought them. When I first bought them the bass would shake my house half way up, now I can't even feel it until it is all the way up but that is way too loud.
    Habit-Forming:
    Scholar:
  • 57 Answers
If there is an adjustment, turn up the subwoofer volume. After you started shaking the house somebody may have adjusted it for you.
Check your computer control panels volume too, cause they may have a subwoofer volume there too.
If there is an equalizer (software) then make sure the low frequencies are set properly (middle or above). Check for this in your computer audio control panels.
If there is no adjustment anywhere, take it back, 'cause it is busted. If it is too late to take it back, sent it to logitech for repair under warranty. If it is too late for that, go buy a new one.
--Dave
Posted on Feb 07, 2010
Testimonial: "thank you very much all my adjustments are the same it must be busted."
The sub woofer had a distorted sound.
the distorted sound coming out of your sub-w is actually originating from your audio unit, Have your audio unit check for possible repair
Oct 31, 2015 | Audio Players & Recorders
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
Can I use my Logitech x-230 speakers without the sub-woofer? My sub-woofer got busted!! Any suggestions?Perfectly good speakers!
i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
Jan 18, 2012 | Logitech X-230 Computer Speakers
I am attempting to reconnect my home stereo but do not see a cord or wire to connect the bass to the system. is there supposed to be a connective cord for the bass speaker? it is a 530 watt MHCGX99 model...
Hi from one Lakers fan to another 8^) - Yes you do. You need a cable to plug into the
sub-woofer out port on the receiver to the connection on your sub-woofer.
If you can't find the original cable, get a short (three ft.) standard stereo cable (one that has two cables, a white and red). Just plug one of the cables (the red or the white but it has to be the same color on both connections) into the receiver and the sub-woofer.
You'll be ready to pump up the bass.
Enjoy and thank you for using Fix Ya
Mikeywaf
Mar 12, 2011 | Audio Players & Recorders
My Onkyo sub-woofer sounds like something is loose in it or rolling around...the sound is similar to shaking a can of spray paint. When I plug it in to the system it sounds crackly. If i turn the volume...
sub woofers are very powerful bass , with incredible sounding technology. your problem might be with the woofer wall around the circle. open the box and take the woofer out.Check if there is any tare over the corners of the cloth. sometimes there might be a crazy noise because of a little opening in the cloth caused by small tare.. if so better change it with a new 1 and make sure that the new cloth has guaranty
damaged sub woofer eg. images?q=tbn:and9gcqv8lxhmuosnjkfywvef7uujnntmudkhhpl-pghy0i7xushrda- torn cloth- images?q=tbn:and9gctcogf_osbsmo3vmcu1vjnpozksylq4nojwpbojuo3w28zvb3honw
Thanks for rating good luck
Feb 08, 2011 | Onkyo SKW-200 Subwoofer
Bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Sep 20, 2009 | JVC RX-554V Receiver
I can't get bass thru the spkrs
So when you aren't using the sub woofer there's not enough bass, so you need more out of the other speakers. Chances are the front speakers are set to "small" in the receivers menu, change it to "large"if your front speakers have a 6 inch woofer or larger. Note: If you leave the sub on, the input signal to it will be greatly reduced when the speakers are set to "large". Hope this helps.
Feb 12, 2009 | Sony Audio Players & Recorders
Very quiet subwoofer
I had the same problem until I decided to plug the speaker system into my desktop instead of my laptop. Now, all is well and I had to turn the bass control almost all the way down... I was shaking the house! Must be something to do with the quality of the laptop output.
Alex
Oct 23, 2008 | Logitech Z-2300 Computer Speakers
Woofer making horrible noise! HELP!
Think as an expert... Probably from my experience repairing woofers etc... the cone (1) or the spider (2) isn't well glued onto the woofer skeleton(or both???) The woofer cone must be absolutely centered or else you will get those clicks in low frequencies(you also get them in higher frequencies but you can't hear them!) I must say that it is very difficult to repair a woofer by your own. I suggest to return it back where you bought it and take another one (i suppose that you have a guarantee ha?).
Aug 10, 2007 | Alpine SWR-1542D Car Subwoofer
Logitech X-540 Computer Speakers Logo
431 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
