Question about RCA M4204 MP3 Player
My m4204A will not charge or start - RCA M4204 MP3 Player
  • maryellen4so Feb 23, 2010
    my mp3 just froze on the front screen
    Problem Solver:
  • 6 Answers
If youve ever forced the charger in it probly broke
Posted on Feb 07, 2010
When I crank my bike it don't show any charge . My stator is putting out like it supposed to and from what I googled , testing my rectifier, it tested ok . Why is my battery not charging then
most charging systems wont show any charge if your just using the starter to shove it over , but once engine starts it should , if in doubt you can use voltmeter on battery terminals before start and after start , of course voltage should be higher on battery after start , this shows its charging
Sep 14, 2016 | Motorcycles
(RCA OPAL M4204A) An update was sent via internet, it went to my unit and errased the data (as warned) and the OPAL's program. It will not leave the 'initialize' window. Turning on and off and on...
Push down the key lock switch, I think on your model it is on the side of the unit.
If it does not work, try performing the reset procedure below, From
ThaMp3Doctor
I quote
"Opal has a reset hole on the back of the unit in which atoothpick (non metallic) can be inserted to reboot the player. If thisdoes not work, I suggest that you reformat the player by using theWindows format command on the unit. To reformat the memory:
Right click on the device within the Explorer or My Computer window
Select the format command (full format) to reformat the internal memory of the device. "
If it still does not work, then the lock switch is probably faulty or stuck inside, in this case you need to take apart the unit, to fix it.
Try playing with the lock switch, or resetting the unit, that should unlocck your MP3.
Oct 27, 2008 | Audio Players & Recorders
Will Facebook start charging a monthly fee for membership?
Facebook Is NOT Going To Start Charging Monthly Fee Of 2 99
Facebook Is NOT Going To Start Charging Monthly Fee Of $2.99! September 24, 2014 4:01 PM
Share on email 165 View Comments By: Dan Kitwood
Getty images News Related Tags: Facebook, Hoax, monthly charge, viral
Doug Lazy Read More
You've Earned Points for Reading!Claim points in our Reward Center, and earn more tomorrow.online right now that Facebook is set to charge users $2.99 per month starting November 1st, but it's not true. See where rumor started...
Sep 28, 2014 | Facebook Social Network
Battery will not take charge, but can jump start and it runs, but does not keep charge
Possible charging coil under the flywheel issue, or with the retifier, there is a tool called a negative shunt, this will quickly tell you if there is any charge to the battary from the engine
May 06, 2012 | Husqvarna 22HP VTwin Hydrostatic 42" Cut...
Wont start batteerry checked ok , if i jump it with cables it starts , but will not start again the next day
the battery may seem ok, but it's obviously discharging itself or not charging during riding.
Try this...charge the battery with a battery charger.
disconnect the charger, and put a volt meter on the battery.
Start the bike.
Rev up to 2000 RPM. If the voltage is not HIGHER than it was before starting the bike, there's something wrong with the charging circuit.
If it IS charging, turn the bike off, and disconnect the battery overnight.
If the bike will not start the next day after reconnecting the battery, the battery needs to be replaced.
If the battery is NOT charging at 2000 RPM, the charging circuit is bad, and is likely what is draining the battery overnight.
Jun 24, 2011 | 1995 Honda VT 600 C Shadow
RCA MP3 PLAYER M4204A LOCKED UP AND IS NOW READING INITIALIZING FOR THE LAST HOUR. WHAT DO I DO?
Hi, let the battery go flat until it turns off, this will cure it without losing your music etc..
Thanks Mark
May 03, 2010 | RCA M4202 MP3 Player
My RCA Opal M4204A is stuck on Intialize...and my computer won't read it.
you can try fomatting it.to do so plug it and open my computer.go to the drive of the mp3 and right click it.in the sub menu click format(to foramt it you have to be administrator)(also be sure backup all of your music,videos,pictures,and anything that you want to save.)
hope it helps-
Aug 14, 2009 | RCA OPAL M4001 MP3 Player
M4204a mp3 player will not do anything, will not turn on, play or charge
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 08, 2009 | RCA M4208 MP3 Player
RCA M4204  MP3 Player Logo
211 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
