Question about Epson Stylus Photo 1290 InkJet Printer
L have replaced both ink cartridges on the Epsom 1290 as the printer has not been used for approx 3.5 years and the pages were not printing. It still does not print
    President:
  • 3,278 Answers
Hello, Robert.
You need to run a nozzle check:
Select Start - Printers and Faxes - (Right-click) on the Epson 1290 printer. Click Properties and choose Nozzle Check.
You may need to run this several times.
Hope this helps.
Posted on Feb 07, 2010
Epsom print EX-200 wont print after l changed the ink cartridge
Did you pull the tape off the top of the ink cartridge?
Oct 17, 2015 | Office Equipment & Supplies
Have just installed new ink to my Epsom Stylus sx215 but wont print, just blank pages
Ensure cartridge fitted 100%, and you have taken off cartridge protectors, but the Printer should tell you why it's not printing !
sound simple to replace ink cartridge, but it can be tricky.
s
Feb 14, 2015 | Epson Stylus Office Equipment & Supplies
Epson stylus photo 1290 was working fine. replaced ink cartridge with genuine epson cartridge. csrtridge holder jumps and will not print. have repalaced black & colour cartridges. problem continues....
Hi fishbay,
Have you followed the proper way of installing ink cartridge for your printer. You might want to reinstall the cartridges by following the steps on the user manual. You can check page 37 down. You may download the manual here.
Hope this helps.
Thank you for using FixYa.
Sep 14, 2011 | Epson Office Equipment & Supplies
Hi I brought some Wilkinson ink cartridges that are compatible with epsom T0715 for my Epsom sx210 printer. Everything worked fine, now after approx 2 weeks I'm unable to print as it keeps saying...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
May 10, 2011 | Office Equipment & Supplies
Printing in just black and white
Epson,. has it rigged, that you must have ink in all the cartridges.............! Doesnt make a difference, if you are printing black and white ONLY.
You have to replace them.
Good Luck......
Dec 29, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Red light on after changing ink
Perform the following procedure:
n Press the ink cartridge replacement button until the print head has moved to the change cartridge position
n Lift the lid that holds the cartridge (do NOT remove cartridge) and press down immediately. Then press the ink cartridge replacement button and allow the cartridge to charge the print head. Do NOT switch the printer off until the printer has finished charging.
Does this solve the problem?
Yes: Solved
No: Go to Checkpoint 2
2. If you have printed between 100 and 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Go to Checkpoint 3
3. If you have printed more than 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Further help required
If red light again you must download resetter software from internet to reset your printer.
Aug 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
Epson stylus photo 1290 printing black splodges
Joy:
Once more have the printer to perform the ink nozzles cleaning.
If you are using a ontinuos ink system, place it at the same level than that of the printer.
With the printer in the "replace carrtidge position", put it OFF and by hand, clean the place at which the cartridge rest.
Good luck and merry christmas
emiliosan
Dec 22, 2008 | Epson Stylus Photo 1290 InkJet Printer
Repacing the color inks with black ink on the epson 1290
Well, since you say you'll be using new cartridges you shouldn't have any nozzle problems. About the worst case I can see would be the slight chance of getting too much ink on the paper resulting in wet paper and a stained platten roller. Seems like an interesting experiment over all.
Nozzle problems arise when reusing cartridges. The very thin metal film that is the nozzle assembly gets worn down as the print head moves over paper and after a number of pages printed the little holes that are the nozzles get larger making for fuzzy, wetter than it should be, streaky printing.
Enjoy,
Carl
Dec 14, 2008 | Epson Stylus Photo 1290 InkJet Printer
Ink cartridges come off carriage
I'm not too familiar with the 12xx family of printers, but sounds to me like you have broken the print head track arm. Look carefully at the side that has come off the track. The traditional Epson print head design is to have the top track arm as part of the print head, and the bottom track arm as part of the print head carrier. The print head and carrier clip together thus providing a closed arm over the track rail. The key question is, have you merely unclipped the print head and carrier? If so all you need to do is position the upper and lower jaws over the track and push the print head and carrier parts together until they click. Alternatively, is a lower or upper jaw missing? In which case, one or other is broken - disaster I'm afraid.
Remember, I'm talking about generic Epson design of the 1290 vintage. I have the 1290 service manual, which is of the usual Epson rubbishy standard, but it's not the same as having actually dismantled one, which I haven't. However, if you look carefully at the side of the print head that's come off the track rail, you should be able to spot if anything is missing i.e. broken off.
Nov 20, 2008 | Epson Stylus Photo 1290 InkJet Printer
Blue and sometimes red lines all across the prints using an epsom 1290. cleaned heads numerous times. nozzle check OK
Hey, sounds like the print heads, but replacing all the cartridges is best option first sometimes fixes the problem, if it dont you should look for epson 1290 cleaning cartridges on the internet they aint expensive, as head cleaning doesnt always unblock the print heads...
All the best
John
Jul 26, 2008 | Office Equipment & Supplies
Epson Stylus Photo 1290 InkJet Printer Logo
42 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
