Question about RCA Televison & Video
Rca vcr will not take tape
Vcr will not take tape
  • greenewood2 Feb 07, 2010
    I plug in the vcr. When I press the on button nothing happens. The place where the clock should be flashes dashes. I try to put the tape in and it will not take it.
  • DaveMc3
    DaveMc3 May 11, 2010
    What is a VCR?
    Just kidding. I need more information.
    In GREAT detail, what happens. Start from "I turn the VCR on"
    Habit-Forming:
    Scholar:
  • 57 Answers
Thanks for the info! . If you can not set the time using buttons, and it does not respond to the menus via the remote control, and the display flashes dashes, it sounds like your microprocessor (controller) chip has gone bad, and the power-on boot is failing, so nothing happens. . Your VCR is very dead. . It blew a single transistor in a very bad place. . Slipping or broken belts are fixable, broken processors are not. Some other broken parts are fixable, but not many. VCRs were made to be repaired in the old days, but not for long. There is a Johnson VCR repair down the street from me, he keeps old dead ones for parts, so he can fix most anything (people often give him their VCRs for free once they hear what it will cost to fix it). Repairs start at about $250, so I just buy a new one when one of mine fails (I have about 4 of them, 2 of which are dead, and I have fixed two of them). . Note - parts from one model can rarely be used in another model, so a repair shop can only replace parts using parts from other broken machines. The spinny video head is the exception to that rule, and some of the switches too. . VCR repair parts are usually available for 2-3 years, so if it is a recent purchase, you may be able to get it fixed, but VCR parts are a bit like car parts in that the individual parts would cost way more than the VCR cost, without including labor fees to put them together. . If you just bought it, return it. . If you have a warranty, use that (if you want to pay their fees for S&H and there may be an additional fee).
Posted on Feb 08, 2010
3 Suggested Answers
  • 579 Answers
SOURCE: RCA VR688HF VHS VCR won't accept tapes
The brain in a VCR has a little switch assembly that senses what position all the mechanical stuff its in. Apparently, the mech is out of whack which is why it won't let you play. This is a common problem and any VCR shop should be able to repair it.
Posted on Dec 28, 2007
ahhsoo69
  • 167 Answers
SOURCE: VCR does not eject tape correctly
hello. it's sound's like that the idler cam wheel that turn's the tape has a problem. it could be that .the wheel if made of rubber is slipping. or it has a belt on the bottem of it that is ***** out. check those two thing's .and let mre know if it has a rubber wheel .? or teeath that turn a gear. and if the belt on the bottem of it is not tight on the two wheel's on the bottem of it. let me know.ok "good luck"
Posted on Jul 03, 2008
How to fix an rca vcr that auto. inserts a tape & then ejects it within seconds
There is somewhere some damage to the mechanism. It could be the carriage itself (the holds the tape) that has a fault on it, or something else in the transport mechanism of the tape. This could have sent the system out of position for the correct loading of a tape.
Aug 21, 2015 | RCA VR646HF 4-Head Hi-Fi VCR
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
RCA TV from 1989 will play VCR
check rca jack maybe some wire cut. check also vcr head maybe dirty.
May 30, 2009 | RCA F20TF10 20" TV
TAPE WILL NOT EJECT
Try unplugging the player from electrical power for several minutes. Plug the player back in and try to eject the tape.
Feb 26, 2009 | RCA VR639HF VHS VCR
Dvd vcr will not even recognise a tape in the recorder... we rarely use the vcr part of our combo but the tape player does nott
put a piece of scotch tape over the little square on the tape platic case bottom left......your recorder thinks it is a protected tape
Jan 18, 2009 | RCA DRC8300N DVD Recorder/VCR
Taping
If there is no coaxial cable input on VCR, then it should work by RCA cables. Which is the Yellow , red/white cables. On the back of the VCR. Take a set of RCA cables Yellow for video, red/white for audio to the VCR output.Then do the same to the Television input. Next use the television remote to turn the TV to Video input this will allow you to view what's playing on VCR. Then take another set of RCA cables and reverse the first setup. Attached Cables to VCR input and cables to TV Output. This will allow you record what's on television. Now make sure the cable is screwed to coaxial cable input on television. This will able you to access cable programming on television, view vhs tapes, and record programming directly from television.Good Luck
Oct 12, 2008 | Televison & Video
Can not tape from cable, blue screen
If you have a cable box connected now, leave the VCR on channel 3 all the time and use the channels from the cable box.
The way this should be connected is cable in to cable box and cable out to VCR, VCR output to TV IN.
Hope this works for you.
Feb 11, 2008 | RCA VR348 VCR
Dec 22, 2007 | RCA VR622HF VHS VCR
RCA VCR ejecting problem
TRY REBOOT -- UNPLUG CORD -- REPLUG -- GOOD LUCK !
Oct 31, 2006 | RCA VR639HF VHS VCR
Televison & Video Logo
272 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
