Question about Bose Lifestyle 38 DVD Home Entertainment System System
Although my system is just over 4 years old it has rarely been used for dvds, mainly tv & radio. During the last twelve months 'Unsupported Format' appearing when trying to play my granddaughters Chipmonk dvd for her also not 'reading' brand new cds. Thought it was something i was doing wrong but after reading comments on this site l am shocked to learn that it is the equipment, thinking i had bought the Rolls Royce of Home entertainment. Bose will be getting a call from me to-morrow ! Thanks
    Habit-Forming:
    Scholar:
  • 57 Answers
Try using a laser lens cleaner DVD.
They run $1 to $10 depending on where you buy them, I have not seen a bad one (I usually pay $1 to $3 when I buy them for friends).
That should fix it.
Posted on Feb 07, 2010
Just bought new pump. My old one lasted for 12 years. New one is 4 months old and recently started to make a loud whine or screeching noise when operating. It works fine but is very loud. I have trouble...
Most likely the bearings on the motor are going out. 4 months is way too soon, but it is possible you got a lemon. Unfortunately I wouldn't expect the new one to last 12 years. It's possible but unlikely. You should however get at least a few years. If the shaft seal on the motor shaft between the impeller and seal plate failed then water can drip back along shaft and get into motor bearings. This will cause motor bearings to fail. Even if this is not the case the motor bearings can fail even though it is rare to do so within first year. I would contact the place you bought the pump from, or whoever installed it. It should have at least a one year warranty. If for whatever reason this motor is not covered under warranty and you have to replace it, I would consider rebuilding it. Normally I don't care for rebuilds, but if the motor is truly only 4 months old then rebuilding it would be a good option.
Sep 23, 2010 | Polaris Pb4 - 60 Booster Pump
My Dell Inspiron 1525 is shutting down at it own during working. From last 4 months I having this problem. during working, laptop shutdown automatically. And after that once I'll start again, its again...
there are 2 possibilities 1. cpu fan ventilation got blocked, so use you old tooth brush to clean it 2. the system is infected with virus. so user online virus toll to clean the virus any i recommend to us this link to clean the virus. it clean virus, spy ware & malware.
www.bitdefender.com/scanner/online/free.html.
i hope it will help you.
May 07, 2010 | Dell Inspiron 1525 Notebook
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
My LG 42LB5D TV can't be turn off unless I unplug
It sounds like you have faulty logic in your main board. The remote issue could also be related because the main board controls the processing from the IR sensor which is more likely because IR sensors rarely fail.
Replace the main board to fix the TV.
Nov 11, 2009 | LG 42LC2D 42 in. LCD HDTV
My amplifier was working great when I unplugged my whole system for the last eight months. I hooked everything up again but the amp is not working? Hook up was checked and rechecked. Any suggestions? ...
old amplifiers usually have capacitors that do not last for long. you may find a few of them leaking out. if u still want to keep the amp change all the leaky capacitors by the right values and u may get it right
Oct 12, 2009 | Audio Players & Recorders
I have a 4 month old Model WD-73736 tv that is nonresponsive
i'd take it back!  it's obviously defective.  TV's are supposed to last longer than 4 months!
Mar 27, 2009 | Mitsubishi WD-73736 Television
DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
Mar 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
2 year old turned tv on/off several times - TV doesn't turn on
The main power supply is in the protect mode. Usually this is caused by the high voltage section, scan amplifiers, and or the main power supply failing. Many times, when there are failures in the scan amplifier output sections, the main power supply can also be damaged.
On rare occastions, the CRT electron-gun can have a short, and cause this type of failure condition.
An experienced TV tech should be able to service this for you.
Jerry G.
May 25, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
DIAGONAL LINES LG PLASMA
Find out the board number, contact LG Zenith company tell them your problem.This way it lets you know wheather or not you want to fix it ask them how much is board.www.LG zenith.com. Good Luck. ThankYou for using FixYa. Have a NIce Day.
Feb 08, 2008 | Televison & Video
Bose Lifestyle 38 DVD Home Entertainment System System Logo
193 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
