Question about Frigidaire ATF6000ES Front Load Washer
Too much soap,doesn't appear to be rinsing out, any suggestions? First time this has happened..
  • 56 Answers
A front load uses a very small amount of water. use only 2 tablespoons of soap and use only h.e detergent.
Posted on Feb 08, 2010
Hi, each time i turn on the vacuum cleaner, the water in the tank will bubble and foam causing an overflow although the water level is just right. i will have to throw out the water and refill again....
Try changing the water before you turn it on the first time -- that will probably help you resolve the issue. It seems like there is probably some sort of soap or carpet shampoo in the system causing your foam issue. If your carpets have been shampooed or if you have spilled soap or detergent on your carpet at any point, the vacuum is probably picking up remnants of the soap when you are cleaning, and it is working its way into the water supply of the vacuum. This will continue to happen until you have completely removed the soap from your carpet -- and if you haven't cleaned out your vacuum very well. Try rinsing out the hoses and water tank really well, to make sure that the soap is not stuck in the vacuum itself and give it a try. Hopefully just rinsing out the machine will fix the problem.
May 29, 2011 | Rainbow Vacuums
3 days ago machine started producing heavy amount of soap suds/foam in the spin cycle - happened once before but corrected self after one rinse cycle - no luck this time - called Fisher - they suggested...
it can take a lot of flushing the machine to remove the buildup of suds producing wash powder. I'd double check the wash powder, and try and put the machine into "no eco" mode, so it won't recirculate the water, this may help was out the suds on an empty cycle.
Sep 04, 2017 | Fisher Paykel EcoSmart GWL15
Put dish detergent in rinse agent dispenser by accident
Hello and welcome to Fixya.
Aside from physically removing the dispenser assembly ( which would be quite involved and include taking the door panel off ) you should be able to "nuetralize" the dish"soap" by adding as much "white vinegar" as possible into the same location as the soap...the jet dry reservoir.
In fact you may have to try this several times, but you could also try pouring straight water into the reservoir, but that will take some time since it is "soap" as opposed to detergent, hence needing a lot of water to de-lute it to much of a degree.
I'd go with the "white vinegar" and repeat that several times through a "rinse & hold" cycle. ( do not add any dishes or cutlery...run it empty )
You can also add a couple of tablespoons of "vegatable oil" directly into the bottom of the dishwasher and some of your regular "detergent" before starting the "rinse & hold" cycle. This will give the soap something to react with and the "detergent" will also help "neutralize" the soap,,,hopefully breaking it down as a result.
To answer the second part of your post...
The effect is going to be oversudsing in the rinse cycle since this is when the jet dry/rinse agent is dispensed in the cycle. So what I'm hoping to accomplish with these suggestion's is to minimize the oversudsing or prevent it all together until the reservoir is "purged" of soap.
Let me know how you make out. It usually works in the cases I've had...eventually. I've seen plenty as you are not the first nor will you be the last...we all screw up, that's life ;o)
Good luck.
macmarkus :)
Jun 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I recently bought a different type of dishwashing detergent for my Frigidare dishwasher and my dishes look as if they have not been rinsed. They cycled all the way through the drying cycle so the detergent...
the best way to use your dishwasher is the way it was designed.
if your unit has a compartment for jet dry or rinse agent then you should add and fill that compartment with rinse aid. try not to buy soap with any extra like soap with jet dry or shine plus . because when you fdo that sometimes customer think that they dont need rinse agent . big mistake. rinse agent is deposited at a certain time in the cycle. diod you know that is you use lets say jet dry and a soap with shine plus or rinse aid in soap the machine can over suds? as a tech trust me i have seen it.let me know if i was helpful. drop a 4thumbs up post
Feb 28, 2010 | Dishwashers
The some dispenser and the rinse aid dispenser seem to be "stuck", soap door doesnt open and dishes appear streaky from no rinse aid. this happened after I cleaned the deposits from under the screen in the...
There is a solenoid which pops open the soap lid after the initial rinse.
If the solenoid or soap lid latch is faulty, you will need to replace it. In the interim just poar your soap in the bottom of the dishwasher tray before cycle starts.
Only use a little amount as per normal. Dishwashing tablets are best as it is a measured amount and has the rinse aid built in.
Good luck.
Ash
Oct 21, 2009 | Bosch Dishwashers
Sud code appeared
If you have a front-load washer then you probably have put too much soap in or not used "he" soap. Front loader use very little water and need low-sudsing soap. Most all brands now sell this "h.e" soap. What has happened is that suds have travelled up the tube to your pressure switch and have told the washer's computer that there are too many suds in the machine. The machine thinks that there is water in the tub even it there is not. You can either let it sit for a day or two or try unplugging it and then run a few hot rinses, without any soap, until you don't see anymore suds in the tub.
Jul 21, 2009 | Washing Machines
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Frigidaire ATF6000ES Front Load Washer Logo
69 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
