Question about Singer 7442 Mechanical Sewing Machine
My Singer 7442 will not sew. It beeps 4 times
My Singer 7442 will not sew. It beeps 4 times when I use the foot pedal and does nothing. I've checked the button-hole lever, and that's not the problem, it won't sew a button-hole either and I've re-threaded the machine about 6 times. Any suggestions?
  • 1 more comment
  • macyaugustus Feb 08, 2010
    My machine doesn't have a removeable bobbin case- it is a drop in and everything is threaded correctly, the thread does pass through the tension discs
    my machine is brand new, do you really think that would be the problem?
  • macyaugustus Feb 10, 2010
    The pedal works fine with another machine, any other ideas?
  • 3,740 Answers
Hi this is not a solution but read this and see if it equates to the 4 beeps:
Stitch length and width/needle position controls
Your sewing machine will produce most of your stitching
requirements at an Auto/Default Stitch Length and Width. When
a pattern is selected, it will automatically sew at default settings
of stitch length, width and needle position for straight stitch.
Auto (preprogrammed) default settings are easily determined
by moving the Stitch Length and Width / Needle Position Control
Knob. The LED Indicator next to the Control will light without
blinking and a beep will sound indicating you are at the Auto /
Default Position.
Once you have determined the Auto / Default position you can
manually change the length, width or straight stitch needle
postition according to your preference. Starting at the Auto
position, slide the control knob left or right to locate each of the
potential adjustments. At each manual adjustment point, the
LED will blink 3 times and a beep will sound
The manual can be downloaded here: http://www.singerco.com/accessories/manuals.html
Enter your model number 7442 in the search panel
Just trying to help.. I do not think this is your solution so please do not rate it unless the info above helps you stop your beeping problem. Just reject the solution so it will go back to the live / pending posts. Thanks Kelly
Posted on Feb 10, 2010
  • Kelly
    Kelly Feb 10, 2010
    Still trying to assist you as best as possible. You can always try Singer at this link
    http://www.singerco.com/company/contact_...
    Customer Service: 1-800-4-SINGER
    Customer Service Fax: (615) 213-0994
    (Singers FAQ's are NOT helpful for your machine)
    Again if this is not helpful just reject it and it will go back to live posting. Please do not rate it.
    Take care. Kelly
  • 5,138 Answers
Problem is in the foot pedal you may need to replace it call Encompass Parts see if they have any in stock 1-800-638-3328
Posted on Feb 08, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all when you thread the machine do make sure you have the presser foot up so the thread goes between the tension discs, top tension between 4 and 6 normally, make sure the bobbin in the correct way round, you should be able to pull the thread through the bobbin case with some resistance, if it is too loose you will need to tighten the screw clockwise on the bobbin case, if it is too tight you will need to slacken it off a bit, remember the thicker the thread the tighter the tension becomes and even worse if you do not use a mercerized thread, if you need to check the top tension, with the presser foot down put your left thumb just above the eye of the needle and you should only just be able to pull the thread.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Feb 08, 2010
    If the machine is brand new its always better to use the warranty and get it repaired/replaced just to avoid any future issues. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
Why does my machine beep and refuse to move?
Mine does that only when the presser foot is up, check yours.
Jun 06, 2014 | Singer 7442 Mechanical Sewing Machine
Nothing happens when I push the foot pedal
Please check the Stitch regulator & Presser foot lifter.
Jan 03, 2014 | Singer 7442 Mechanical Sewing Machine
Electronic sewing machine (singer 7442) will not sew buttonhole
Ensure that you have the buttonhole lever all the way down until it doesn't go down anymore. This might sound like a silly fix, but it's actually one of the most common mistakes made by people using this(and other automatic buttonholing) machine.
Apr 23, 2010 | Singer 7442 Mechanical Sewing Machine
When i try to do buttonhole stitch the machine beeps and won't sew
I've answered this question for this model a couple times. Ensure that the buttonhole lever is all the way down. Also, ensure that it is point STRAIGHT down, and is not pushed by the buttonhole foot in any way.
Apr 22, 2010 | Singer 7442 Mechanical Sewing Machine
How to attach Singer Free Motion/Darning Foot to Singer 7442 machine?
To learn the skills to repair sewing machine by yourself, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Oct 15, 2008 | Singer 7442 Mechanical Sewing Machine
Wont Start (brand new) Just Beeps!
make sure the bobbin winder is not engaged and thread the machine over ,also check that the buttonhole switch is not down
Aug 18, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 7442 Mechanical Sewing Machine Logo
324 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
