Question about HP Office Equipment & Supplies
I have an HP J6460 that growls during startup, then ''Paper Jam''s
I have an HP J6460 that growls during startup, then says there is a paper jam. I can see that the growl is coming from the print head area on the right. Anyone else seen this? Thanks.
    Habit-Forming:
    Scholar:
  • 57 Answers
If there is a manual feed, try feeding a sheet of paper through.
The problem is that the motor is being told to move the paper, and nothing happens. The growl is the motor/gears attempting to move the paper.
The motor may be dead. If not, then there is SOMETHING jamming up the gears. Clear out the gears and try again.
If that fails, go buy a laser printer based all-in-one (much cheaper per printed page).
Posted on Feb 07, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
Having message jam inside rear door and can not find any paper jam
Not all of the paper jam was actually cause by paper. There are also instances that the media is the one that is jammed, causing to display a "paper jam" message.
If you can't find any jammed paper from the unit, you can try inspect the following cause..
1. Trays are loaded improperly or overfilled.
2. Tray 2 or tray 3 is removed during print job.
3. The top cover is opened during print job.
4. The media that is being used does not meet HP specifications.
5. The media that is being used is outside of the supported size range.
Also, try to tun HP toolbox.. on the Paper Jam options, click the Typical Jam Locations... to see the internal paper path and potential jammed locations.
I hope this solve your problem...thanks..
May 28, 2010 | HP LaserJet 2420 Printer
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
My HP Officejet 4300 all in one stopped printing. Ran out of paper in middle of job. It acted like it jammed but there was no paper to jam. When I refilled the paper slot, it would not print. Deleted...
many times it happens the Cartridge rack get jammed on roller during paper jam.. so please find out the movement of cartridge over the rack is smooth or not.. reply me with your observation
Oct 08, 2009 | HP Photosmart D7260 Printer
Grinding noise at startup paper jam indication (alarm flashes 3 times) no paper stuck in printer sounds like plastic gear is not meshing grinding sound occurs twice during powerup
definitely sounds like the drive gears are stripped, did it jam and someone pull paper out by hand this is major cause of stripped gears. generally fixing is not cost effective cheaper to buy new
Jul 07, 2009 | Office Equipment & Supplies
Printer wont shutdown after paper jam
After removing paper jam, which may have been caused by using typing paper,which was a much lighter weight,computer was shut down,on startup printer had shutdown,no further problem.
Jun 14, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Business Inkjet 1200
sure..there must be something underneath in the tray or paper slots..check carefully..I use a pen light in a darkened room..the white shows clearly then.
Oct 16, 2007 | HP Inkjet 1200dn Printer
184 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
