Hitachi51F59 sound.....no picture. no power to 3 lens
    Brigadier General:
  • 8,619 Answers
You were provided with sufficient information on what is bad and also what all needs to be checked still you rejected the solution. Do you think this is fair.
Posted on Feb 07, 2010
Hi, I have a plasma 42inches TC-p42gt25, I have
sounds like bad capacitors on the power supply board
Len..
Oct 13, 2014 | Televison & Video
TV shuts off after 3 seconds
If the sound is still heard then the inverter board has failed and is triping the powersupply,if no sound the powersupply has failed.
Len..
Mar 29, 2014 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
Toshiba model CF30D50 has sound and will change channels, but picture is dark, can see vedio 1 and 2 faintly, but can get no picture on TV channels
Its a older set with 3 picture tubes---when was the last time the mirror and three lens for the tubes were cleaned?
Dec 13, 2012 | Toshiba Televison & Video
Hi, I have just bought the Fuji JX530. When I take a picture I get a split second clicking sound coming from the lens before the flash goes and the picture is taken. The picture is fine and the...
When you press the button, the camera performs many functions in a split second such as set the focus, set the aperture and shutter speed, calculate the flash power, etc. It will make sounds and if the pictures are fine, then all is well.
Jan 05, 2011 | Cameras
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Powers on, lens extends, 3 beeps, lens closes, camera turns off
Try doing a couple of things.
1) remove and digital media cards.
2) turn the camera on and delete any pictures that may be stored in the camera memory (not on a removeable card)
3) remove the batteries for 60 seconds
4) replace the batteries without the media card and lay the camera on a flat surface with the lens pointing up (5) The lens should retract.
6) Turn off the camera
7) replace the media card and turn on.
I think the camera was getting hung up on the pictures stored in the camera's memory.
Aug 17, 2009 | Cameras
I have the sd1000 power shot canon. i was taking a picture the camera took the picture as normal but when trying taking another shot i got an lens error restart camera.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
One thing, you mentioned that the lens error occurred after you wer able to take a good picture. This really sounds like your battery ran down during shooting, and did not have sufficient power to properly shutdown the camera. Focus on your battery as the potential cause first. Note that if the battery is older than a couple years, it may be time for a new one. Rechargeable are not meant to last indefinitely.
Jan 23, 2009 | Canon PowerShot SD1000 Digital Camera
Retry power on and lens error message
From the sounds of it, your lens is faulty and would require replacing.
You may need to call some of the camera repair centres in your area (State), they may have a 2nd hand lens that requires a clean up and they might be able to use that to repair your camera at a lower cost.
Aug 12, 2008 | Casio Exilim EXZ75 Digital Camera
Samsung S800
Lens mechanism can be stuck. Try gently to drag or straighten it.
Feb 13, 2008 | Samsung Digimax S800 Digital Camera
Camera froze whilst taking pictures, lens stuck.
It happend to me also. I think it is caused by the lens mechanism. It is stuck and it disabled all other functions.
Jan 02, 2007 | Canon PowerShot A75 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
