Question about Whirlpool Dryers
The dryer stopped working i do not know why?
The dryer stopped working i do not know why? it all happened when i closed the door to dry cushions
  • Whirlpool Master
  • 2,128 Answers
Check the door switch,move the paddle in and out,it should click if it doesn't you closed the door to hard and broke it,also make sure you have power to the machine,you could have blown a fuse
Posted on Feb 08, 2010
How do I fix dryer that stopped working?
Check the little button that the door pushes in when you close the door (door switch).
May 01, 2014 | Bosch Axxis WTL 5410 Electric Dryer
Tip
Bosh Dryer Lint Problem
When your bosh dryer stops working and the lint light filter turns on ,close door and start again.This time push door and hold so that the door is closed more tightly.This time dryer should work.
To fix this ,remove the door then remove hinge bracket .Under the bottom part of the bracket insert plumbing ruber gasket.This will adjust the dryer door,it should close more tightly.
Lint light should not turn on again and dryer should work fine.
Please let me know is this works for you.
Since the adjustments of my dryer door, I have not had any problems.
If you have any questions, just ask.
P.S- I know it may sound weird to do this, but since I had adjusted the door this way, the dryer does not turn off during drying sessions.
leco
on Mar 12, 2010 | Washing Machines
Sudden stop
Do you have an error code displayed ? If so what is that. If not the either the door switch is faulty or the control board. More likely to be the door switch but, strange things do happen.Here is the door switch number 134813601. If you need help installing or more info let me know.
Jan 30, 2014 | Frigidaire AEQ7000ES Dryer
Bosch Dryer WTL 5410 UC do nothing after selecting a program and hitting the start button. The only thing that happens is that the Drying light lits and nothing else happens. I have tried to hit start...
Door switch may still be your problem. Mine showed lights as if working when closed but I decided to use a screwdriver and push in switch all the way in. It worked then without door closed. It will stay stuck until you pull it own a bit to release it. Give it a try. The door switch appears to have two switches in it requiring it to be all the way in.
Aug 12, 2011 | Bosch Axxis WTL 5400 Dryer
Dryer stopped working, sounds like timer still running
I suspect it is the thermal fuse. Seen here. You will need to determine what caused it to blow. on these machines the blower wheel is notorious for getting loose and causing the element to over heat. This makes the heating element shut down faster and takes a long time to dry the clothes. 7fc125e.jpg
Apr 10, 2010 | Magic Chef CYE4000AWW Electric Dryer
Dryer only shuts off and restarts during cycle
Get a new timer. It is not that expensive and the wiring is fairly simple.
Jan 14, 2009 | Dryers
Indesit IC70C Condensor dryer
We experienced a similar problem and corrected it by closing the drying door and then hitting "OPEN" followed by closing. Sometimes we use a tool to release the catch and then close the door. We have not seen this problem return.
Nov 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
