Question about Kenmore Dryers
No heat and timer not working - Kenmore Dryers
  • Kenmore Master
  • 5,568 Answers
You may get a more meaningful reply if you include model number; they are not all the same.
Posted on Feb 08, 2010
    Habit-Forming:
    Scholar:
  • 57 Answers
The power is probably not getting to the timer. Trace the wires inside the back of the machine. Verify that the wires are NOT MELTED where they connect to the machine.
If that is OK (not melted, looks good), then get yourself a DVM (Digital Volt Meter) They start at around $20, and the cheapest one will work fine.
Check the resistance across the power plug (unplug it from the mains first or you will blow out the meter).
Let me know what happens
Posted on Feb 07, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Does not heat up and timer not working?
send brand name and model number so i can help you,also if it's on time dry it should count down even without heat if you have it on more or less the timer will not move without heat.heat comes on until heater cycles off when the heat is off the timer will advance a little,when the heat comes back on the timer stops advancing,it will do this until the clothes are dry.
Sep 15, 2013 | Dryers
Dryer wont stop buzzing
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
LHE 5800: timer not working and not heating up
Have the timer checked and the heating element.
Jan 26, 2013 | Whirlpool Dryers
THE TIMER IS NOT ROTATING(I CAN MANUALLY ROTATE IT,BUT IT DOES NOT MOVE WHEN THE DRYER IS RUNNING). DRYER DOES NOT PRODUCE ENOUGH HEAT AND IT TAKES LOT OF TIME (4HRS)TO DRY THE LAUNDRY.
You need to buy a new timer and replace it. Be careful when replacing the timer as there are many electrical contacts in the back of the timer so when remove it, please label all the wires. Please follow the instruction from the manufacturer how to replace the timer. Of course, make sure you unplug the dryer because the dryer is powered by 220~240 VAC not 110~120 VAC.
As for the heater, there are two possibilities. The first one is, part of the heating element is open circuit and therefore, there is not enough heat to your clothing. The second possibility is, your timer contacts is broken, when the timer asks for high heat, the electricity supposes going to all the heating elements, but since the timer contacts are broken, you have only part of the heating elements working. The heating elements are quite easy to replace but please replace the timer first. You may fix both problems once you replaced the timer. WL
Nov 15, 2010 | Hotpoint Dryers
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Hotpointdryer timer problem
There are two coils in the heating element, and if one burns out, the timer will not advance in automatic dry. The timer should still advance when using manual (or timed) dry.
Jan 20, 2010 | GE DBSR453EBWW Electric Dryer
My dryer will not heat and timer works until the cooling stage
It's either the timer or insufficient air flow. check your vents to see if sufficient air is coming out.
Jul 07, 2009 | Dryers
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Honeywell Central Heating Timer ST699
In the end I bought another timer on sale/return. My heating didn't work with that one either, so my problem's not the timer but something else.
Aug 26, 2008 | Kitchen Appliances - Others
Dryers Logo
51 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
