Question about Stoves Ovens
Hi in there...high pitched grating whirring noise when i turn my oven on on any setting
  • 417 Answers
It's probably coming from the fan in the oven.
It may be that an obstruction is hitting the fan blades or the bearings are gone.
Check visually to see if there is anything obvious but if not it will probably need a new fan.
Posted on Feb 08, 2010
My wall oven is making a constant unusual noise
Without a model number its hard to be exact. If your oven is older it will have a clock timer motor that turns the dials or flips the clock display cards. This timer has gears and bushings that will be annoying as they wear and start a vibrating hum or clicking-usually not worth tinkering with..it can be taken out and checked or replaced. Electronic timers of course don't have any moving parts to the timer, but have relays in the circuit to turn the oven on and off. They do not 'whir'. This is the likely issue.
Repost..let us know.
Apr 28, 2015 | Ovens
My Lincoln 1116 has a horrible high pitched squeeky sound off and on. What can it be?
The horrible high pitched squeaky sound in a lincoln oven could be coming from the moving parts more so from the main fan motor positioned at the back or it could be from conveyor drive system. In both you got to dismantle the motors if at the back replace the motor bearings.
Aug 05, 2013 | Lincoln Impinger 1116 Gas Oven
Viking oven buzzes all the time when not in use
the low voltage transformer on the ERC control is vibrating from not doing anything,when you put a load on this transformer it will quit,only fix is to possibly remove ERC and jam a piece of NON-Flammable/NON-electrical metal to keep it from vibrating and try this first,if this doesn't help,replace the noisy board with this transformer on it
Jan 12, 2013 | Viking 27" Professional Select Built-in...
Gas Oven Whistling noise
I HAVE A NEW PROPANE OVEN THAT I CONVERTED TO NATURAL GAS. NOW I GET A WHISTLE WHEN I USE THE OVEN ONLY. DO NOT GET A WHISTLE WHEN I USE THE TOP BURNERS.
Jun 23, 2010 | Maytag Ovens
Oven making whirring noise when switched off
The back panel of the main oven houses the circulating fan. From experience, fat/grease/gunge accumulates and drips down the inside of the plate through the vents. This will then rub on the fan as it turns. There are four self tapping screws, one in each corner of the panel. Remove the screws and the panel will come off. That is the easy bit, getting rid of the grease is harder. Don't forget that the oven side of the panel is a stay clean and shouldn't be cleaned with anything abrasive. I use the Lakeland brush on oven cleaner on ALL the walls of the oven (even the Stay Clean) and it works a treat. It may take some time to disolve the residue and a couple of goes, but it does work.
Apr 20, 2010 | Stoves 720EF Electric Double Oven
Display is flashing0.00 and auto. oven won't work, took out circut breaker still doesn't work. when trying to reset the clock high pitch sound comes on and have to turn oven off at wall to stop
It will not work if it is flashing, the timer needs to be reset to manual
If it will not reset, then It sounds like the timer is faulty, try a different combination of buttons when trying to reset it.
Hope this helps.
Feb 02, 2010 | Ovens
FAN NOISE in convection mode, as in a loud whirring sound, suggesting a problem with the fan. Any one else experiencing this?
FAN NOISE IS NORMAL BUT IF ITS SQUEELING THERE IS A PROBLEM WITH THE COOLING FAN. YOU DO HAVVE TO REMOVE THE OVEN FROM THE WALL TO REPLACE.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 24, 2010 | KitchenAid KEBC107 Electric Single Oven
A (automatic cooking)remains in the digital reader which means that the electric oven/grill and fan oven won't work. It will not clear from the box.
What happens when you turn the power off to the whole oven, leave it off for a few mins and then reapply? If the automatic is still set it could be the clock is faulty.
Have you tried resetting the clock as per the handbook?
Dec 01, 2009 | Stoves 720EF Electric Double Oven
Ovens Logo
206 people viewed this question
Top Stoves Ovens Experts
ashburton
John Tripp
John Tripp
Are you a Stoves Oven Expert? Answer questions, earn points and help others
