Question about Tomtom RIDER 2nd Edition GPS
My tom tom rider 2 unit is not shuting off - Tomtom RIDER 2nd Edition GPS
Open the compartment on the bottom of your TOM TOM RIDER and bellow the memory card slot there is a small hole and with a needle insert on it and bingo the unit shuts-off.
Posted on Feb 09, 2010
Can you tell me where is the reset button on tom tom 1 IQ
I'm a little confused about which unit you have, but the answer is simple enough..... If there isn't a small hole on the bottom of the GPS, then simply hold the on/off button for approximately 15 seconds -- until the unit restarts. The small "hole" that I'm referring to will be in the same vicinity as the connector that the cable plugs into. It should say reset right by it, if the reset button is there. If you do have a reset button on the bottom of the device, you'll need to use something to press the button. A paper clip straightened out a bit works perfectly.
The following lists are from Tom Tom's website. I hope this helps:
Devices that are reset by holding the On/Off button ico_open.gif
(GO x50, Blue&Me TomTom, GO x40,
XL IQ Routes, XL,
ONE IQ Routes,
Rider Pro, Urban Rider)
(GO x30, GO x20, GO x10, GO,
XL IQ Routes ², ONE XL,
ONE 3rd Edition, ONE 2nd Edition, ONE 1st Edition
TOYOTA, ECLIPSE, DAIHATSU, ECLIPSE II,
Toyota Aygo Connect Multimedia,
Start ², Start
RIDER 2nd, RIDER 1st)
Apr 29, 2011 | Tomtom ONE 3rd Edition GPS
My tomtom rider 2 will not turn on
My tomtom rider 2 will not charge on my bike and will not charge from mains electric, when i use my tomtom in the car it works.
Cheers Tim
Mar 23, 2011 | Tomtom RIDER GPS Devices
MY HEAD SET HAS NO CONNECTION WITH THE DEVICE (TOM TOM RIDER 2ND EDITION). THE DEVICE CAN NOT FIND THE BLUETOOTH HEADSET
Reset the unit by pressing the small pin hole button. Do this when the unit is on. let it reboot by itself and try again to pair ur phone/blutooth.
Hope this helps. let me know if not.
Aug 11, 2010 | Tomtom RIDER 2nd Edition GPS
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
My tom tom rider cnt find my cardo scala headset even tho it is on, can you solve, thanx
i have the tom tom rider 2 its a great bit of kit but i disconnected the scala cardo headset for helmets so that i cold try a different bluetooth headset for use in a car and it didnt work i then tryed to recconect it to my tom tom and it cant find it when searching for it what do i do ? what have i done?
Aug 06, 2009 | Tomtom RIDER GPS Devices
Tom Tom Rider 2 will not switch on
take it back from where you bought it from with your recipt they should replace it
Jul 24, 2009 | Tomtom Rider Europe 2nd edition GPS...
Tom tom rider
I made a video on how it open your TomTom rider.
Feb 09, 2008 | Tomtom RIDER GPS Devices
Tom To Rider
Unfortunately I have encountered the same issue with my Tom Tom Rider. I have worked out the problem is between the mounting bracket and the GPS unit. There are 4 little metal pins that spring in and out on the mounting braket that are supposed to be in touch with 4 metal cylindrical metal surfaces on the rear of the GPS head unit. This looks good in design and theory, but the GPS unit does not always make contact with the metal pins, hence allowing no charge to GPS unit and automatically turns itself off whilst riding. I have sort to overcome the issue with building the rear of GPS head unit cylindrical contact points with solder. It is a fiddly fix, but to date this has overcome the issues you have named up. A small drop of self fluxing solder is all that is required. No more than 2mm projection off GPS unit. Allow the solder to adhere to contact and move soldering iron towards the base of GPS unit. The reason for doing this is to allow the pins extra contact surface. I found my pins on the mounting unit did not line up with GPS head unit when fitting together from new. It's not easy to see this, but shine a torch light as you bring 2 surfaces together and you will see what I mean. The mounting braket pins were slightly lower than the GPS contacts. This is what causes the problem. Hopefully Tom Tom will redsign these on the next model or allow more contact space and tolerances to eliminate this frustration. Regards, Nicky (fellow Tom Tom Rider)
Aug 05, 2007 | Tomtom RIDER GPS Devices
Tom Tom Rider
speakers are very vulnerable on these units along with radar detectors. they get jostled around and broken or garbled. The unit needs service or you can live without voice as i had to for a while(just got new unit 2 weeks ago)
Jul 17, 2007 | Tomtom RIDER GPS Devices
Tomtom RIDER 2nd Edition GPS Logo
142 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
