Question about Alpine Car Audio & Video
Alpine 6 CD cassette fails to eject
Renault Scenic 02 Alpine 6 CD changer (under passenger seat) has suddenly decided not to eject CD cassette when green button pressed. Has worked fine for 8 years. Dashboard display shows ' CD error' and will not play.
Any suggestions very welcome.
Leon
pjstanley
  • 185 Answers
SOURCE: renault espace radio / pioneer cd multi changer
iwish i can help but i cant
Posted on Jun 02, 2008
Eagleeyes
  • 199 Answers
SOURCE: car multi cd changer wont eject
hi
do you have any model numbers on the cd changer?
Posted on Nov 25, 2008
SOURCE: RENAULT SCENIC RADIO CD PLAYER
I have a problem with my gear box
Posted on Mar 05, 2009
SOURCE: clarion 6 cd changer cassette will not eject
Don't waste your money and buy those repair manuals. There is an easy fix for this. The rootcause is most likely related to your disc tray (crooked carrier or broken spring). Just get a small screwdriver and take out the two black srews of the inner faceplate, covering the cassette tray itself. Please make sure you do not drop those tiny screws. Use a magnetic tip screw driver. Take the faceplate off. You will see a litlle lever in the center. Just push it aside and your cassette will pop out with no problem. That simple. So don't waste your money!!!
Posted on Apr 17, 2009
SOURCE: 6 cd changer
try to reset the cars computer. i had the same problem and it fixed it. all you need to do is unplug the battery for about 10 minutes and it may work. Good luck!
Posted on Jun 15, 2009
Renault scenic cd changer
no its not .some cd changers need positive ground and neg switched red to yellow /yellow to red /switch them around and try it/from the rear of radio best to let expert do it
Nov 01, 2013 | Alpine Car Audio & Video
6 disc, will not eject or play cd's
Try tapping on the changer. Sometimes a gear gets stuck inside the changer and tapping on the changer frees the gear.
Feb 15, 2012 | Alpine CHM-S630 6-Disc CD Changer
Need to eject Alpine Renault 6CD changer cartidge- no power?
lok at the 8 pin plug the first pin from the left is the power wire and the round metal part of the plug is the ground
good luck
the last pin on the right is the ignition
Mar 21, 2010 | Alpine CHM-S630 6-Disc CD Changer
Hi radio code
Ask here
www.ukbookshelf.co.uk
Dec 18, 2009 | Alpine Car Audio & Video
Jammed CD & Magazine in an Alpine CHA-S634
Mine jammed after I dropped it, trying to swap it into a new car :-)
Same problem, however. Three of the six CD trays had wandered into the righthand mechanism (which selects and plays one cd at a time). Nothing else at all, most fortunately, was broken.
I removed the cover (3 screws on each side), and the small black faceplate that holds the eject button. The main faceplate came off too, needless to say; no screws, just tabs.
You have to remove the side brackets also, and the angle-adjust spring loaded pins on both sides need to be slid out. Then the body of the cd changer rotates out of its cover.
Now, you can see down into the mechanism. A CD was still stuck in the reader, along with several shifted trays. I could simply remove the CD, and with a small screwdriver, shifted the trays back over so that I could then successfully eject it. I removed and realigned the trays, which had been jammed, and it worked once more! Reassembled and reinstalled ;-)
Apr 26, 2009 | Alpine CHAS-634 6-Disc CD Changer
''CDDJ ERROR'' WHEN ATTEMPTING TO PLAY VIA ALPINE CHANGER
My local Lincoln Dealership wanted to dismount the actual Clarion CD changer (I thought, and unfortunately reported to you, that the CD changer manufacturer was the same as the radio/cassettee unit that is installed in my dash, Alpine) from my 99 Town Car and ship the unit out for repair for a minimum of $130.00. Instead, I went to a local Radio Shack franchise who installs/repairs car electronic audio/video systems and they: dismounted the unit from the trunk; took the dismounted unit to their workbench; removed all the housing, etc. and finally were able to manually extract the fully populated 6 CD magazine stuck within the CD changer. Additional efforts (including inserting my spare magazine into the CD changer while it was on the tech's work bench) to determine exactly why the magazine would not eject while the unit was connected via the cabling to the car's power, etc. were not productive. So I now have a totally unassembled non-functioning CD changer on my hands. The "CDEJ Error" on the LED area in the dash when the eject buttoon on the CD changer is pushed.still persists. The technician said that it would be a waste of his time and my money to re-assemble the parts of the CD changer. He believes that the motor on the unit has been burned up.
So I am now checking with all the local auto parts salvage yards (we used to call them junk yards) to see if anyone has a usable Clarion CD changer for a 1999 Lincoln Town Car available that would be plug compatible with my existing Alpine factory installed Premium CD/Cassette audio system and the former factory installed trunk mounted Clarion CD changer. The Radio Shack franchise technician has already checked with the Clarion factory people and they iindicated that they no longer have my Town Car installed CD changer model available, new, used, refurbished or otherwise.
For what it's worth, here are the part numbers and other potentially important data that appear on the "cage"/sheet metal/housing that surrounds the working parts of the CD changer itself:
Assembly Part Number: F8VF-18C849-AE
Part Number (presumably the "cage"?): F8VF-18C830-AE
Date Code: 0998
Serial Number: 0201832
Mounting Orientation: Vertical
System Revision Level: 9.2
So it looks like I may have a potentially very expensive replacement of my whole audio system on my hands. I have been quite happy with my somewhat "obsolete" audio system and I have a very large collection of CDs which I migrate between my Sony 300 CD CDP-CX350 Mega Changer installed in my entertainment center, my car Cd changer and my Sony CD/Cassette player boom box in my master bedroom.
It was suggested to me that if I have to replace the radio/cd/cassette unit installed in the dash of my Town Car that I should consider a replacement model that offers a port to receive Ipod programming as a source of music.
So things have gotten somewhat complicated since the first instance of the Cd magazine not ejecting from the Clarion CD change mounted in the trunk of my car.
Maybe someone out there on your knowledge base knows where I can acquire a used Clarion model CD changer compatible with my car's setup at a reasonable price.
Thanks,
Tom
Nov 24, 2008 | Alpine CHM-S620 6-Disc CD Changer
Alpine cha-5624 cd changer
Need to order a 6disc container for CHA 5624;I lost the original:(. Tom H. Willett
Mar 23, 2008 | Car Audio & Video
Unable to eject cd magizine. Error 2
power off. open the cd changer unit. look for the motor that, when turning, performs the eject mechanism. now turn this motor by hand in the proper direction until cassette is fully ejected.
Jul 22, 2007 | Clarion DC625 6-Disc CD Changer
Car Audio & Video Logo
154 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
