Question about Cobra 25 LTD 40-Channels Base CB Radio
I have everything hooked up but all i get is static. I had someone from radion shack check the ground and hookup and they said it all looked good. I have tried numerous CB's and different anntennaes still nothing but static. What do you suggest to try. I have the antennae mounted to my truck box and grounded to my metal bed rails.
  • 56 Answers
Truck boxes may be the best looking place to mount a CB antenna but in my experience they are the worst place for performance.
The 'ground' you need is not an electrical ground but an RF ground. The easy answer is that you need to mount the antenna to a mirror or the bumper or even use a magnet mount instead on the roof. The body of the vehicle provides an RF ground that the small truck box cannot. The only way it might work is to use flat, wide ground straps at all four corners of your box to the bed of the truck. You need metal-on-metal contact.
Posted on Feb 12, 2010
  • MR LIGHTNING Mar 20, 2011
    you need to ground the truck box to the frame of the truck. most truck beds are insulated from the frame and not well grounded. also ground the radio well. i even recommend grounding the case on the radio to the frame. what are your swr's?
Hello, When I hook up my 2007 box trailer up to my 97 chevy k2500 hitch and plug in the 4 plug u-haul flat plug the brake fuse blows, but if the hitch is not hooked up but I plug in the plug all the l
check positive wires touching the negative(ground). by getting each positive wire from the plug to check continuity to the ground.
and check or clean the plug. it may has excess wire touches to the other wire.
Aug 15, 2012 | 2000 Chevrolet Blazer
AS SOON AS WE TURN ON THE WII WE GET A LOT OF STATIC SOUND. WE HAVE CHECKED THE CONNECTIONS TO THE TV AND HAVE UNPLUGGED THE CONSOLE TO RESET IT AND STILL GET NOTHING BUT STATIC.
If possible try hooking the WII up to another TV. If the problem persists, try replacing the hookup cables. If that doesn't help , your unit might need service
Jan 02, 2011 | Video Game Consoles & Games
I put banana clips on the wires and plugged them into the Insignia 200w audio receiver and everything sounds static tv and music
For temporary just for testing it ok.. but using banana clips permanently it not a good idear because due to excesive sound vibration it will create static for sure to avoid that you may have to souldering those wired in place to avoid that static and causing eventual damage inside your receiver... any conection as to be well connected special went it time to connect a large amps., beside a turn table, you may look for a good ground.... I suggest to put a solid ground wire also betwen your tv set and your receiver
for eventual hi static discharge., also make sure use a power bar for more protection ...good luck
Oct 15, 2010 | Insignia 200W Stereo Receiver
How do you set it up?
Oh boy this is a good one. Haven't played with one of these in 20+ years! First lets do inventory on he necessary components.
1. a 9 volt dc power adapter do not use any other size adapter make sure it is for the Atari System!
2. A slide RF unit ( it may be a silver metal box with a slide lever. on one side it'll say TV and the other says computer. If you don't have this box it wont work, but no fear Radio Shack still sells them.
3. A long single wire RCA cable. Usually about 10 ft long.
4. At least 1 controller ( they are black with a single red button on the top upper right corner)
5. A tv from the 80's that has an arial antenna input ( 4 screws, 2 for VHF and two for UHF may also some models will have a ground). If your TV does not have these hookups you can get a RF unit from radio shack or eBay that has the cable hookup on it.
6. A game that works with you particular Atari system.
Installation:
Here's a link to a video that is very descriptive on hooking it up.
http://www.youtube.com/watch?v=38os4_ama08
Have fun! I still miss mine.
Oct 09, 2010 | Atari Video Game Consoles & Games
Ref. Cobra 29 Radio: Can talk out and be heard but when someone is talking to me, sometimes I cannot hear them or it has a lot of static. Have tried everything. Please make suggestion.
HI, my name is John. Try putting the RF GAIN to MAX,also the squelch, check the antenna connections, have someone check your SWR, they can do it at Radio Shack for free, or a CB shack. If that does not help, let me know and we will go further with it....hope this was helpful...oh, and turn on the NB or the NBL switch..
Sep 02, 2010 | Cobra 29 LTD CB Radio
HID will not funtion hooked up right. They won't light. Everthing works as it should hit hi beams fog lights go out hi beam light comes on inside on dash. Its easy hookup maybe missing something? This is a...
yeah, shouldn't be that difficult. red-power, black-ground. unplug them then put everything back to normal, then try them to see if the originals(low beams, high beams, fog lights) work ok. if they do it's in the wiring. turn on your low beams and that's the wires that you need. just find the one that sends 12volts to the low beams and hook it up to red on HID's then hook the black(ground) from HID to chasis, not the ground wire from car and check to see if they work.
Sep 24, 2009 | 2009 Honda Ridgeline
Cobra 148nw st sound tracker - Need to test this yard sale find
go to any cb shop maybe even radio shack in your area. these plug in cords are fairly easy to find. even check with other cbers around you they may help you. these cords are usually fused so you shouldn't mess up. red fused to voltage and black to good ground. good luck
Mar 09, 2009 | Cobra Radio Communications
1992 Honda Civic Radio has only static
if the tape player works fine and no static u most likely have a problem with your ground,check to see if your radio is getting good ground and also check the antenna unscrew the two bolts on top of the car and carefully pull the antenna upwards and check the wire connected to a piece of metal where the screw goes (if good) add another ground to your radio.
Jan 13, 2009 | 1991 Honda Civic
Rebuilt heads on 96 blazer 4.3 now no power
Check your neutral switch, its usually on drivers side on the back of stearing column .Its easy to reach and if you consult a mechanics service book, it will be alot easier to find and save you alot of frustration. Please rate this. Thanx.
Jun 05, 2008 | 1996 Chevrolet Blazer
Problem with CB
definitely need more information:
1. Have you checked your coax to make sure it is good (with a meter)? Make sure center pin to center pin has good continuity, and making sure that the center pin to shield is not shorted.
2. Have you made sure your antenna is set up properly, not grounding out to the bracket. Make sure the plastic ferrel is between the antenna and the bracket so it does not ground out.
3. Do you have a good ground plane? Is the antenna bracked making a good groudning connection to the vehicle?
4. Do you have a friend with cb set up in his/her vehicle, so you can test between the two?
Jan 11, 2008 | Radio Shack TRC-521 CB Radio
Cobra 25 LTD 40-Channels Base CB Radio Logo
108 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
