Question about Serfas Cycling
I have a Cl-501 coil lock that I won't unlock. Thought for sure that I knew the combination numbers.
SOURCE: How do I Unlock Ipod screen if I forgot the 4 digit password?
restore the ipod
Posted on Jan 07, 2009
  • 69 Answers
SOURCE: I locked my cellphone and thought i knew my lock
If you haven't specifically changed the code, it is usually set by the carrier to be the last four digits of your phone number: eg, if your number is (555) 555 3230 the code is likely 3230.
Posted on Sep 23, 2009
Obertelli
  • 3006 Answers
SOURCE: Thought I knew the 4
Without wishing to state the obvious, I feel that I must do so. A safe is called a safe for a very good reason. If it was easy to get inside without the correct key or combination then by definition it would be unsafe.
If you have lost the combination and the key doesn't work then you can either try every combination until you get lucky or you must consider calling out a locksmith who will usually open the safe destructively (often by drilling out the lock) or even by using an angle grinder on the hinges.
Posted on Sep 17, 2010
  • 11 Answers
SOURCE: I can't get my Defcon
Posted on Nov 17, 2010
timlippard
  • 15 Answers
SOURCE: How do you unlock a TSA COMBINATION LOCK WITH fogotten. number?
The only way to reset a TSA Combination lock is to turn the numbers until you get it. The good news is that you only have 1000 possible combinations. Start at 0 0 0, then 0 0 1, 0 0 2, etc...
There are posted videos on YouTube that talk about how to reset locks with unknown combinations but they are specific to the brand of the lock; assuming they aren't fake videos anyhow.
Posted on Nov 19, 2013
I forgot the combination
hey man, im not sure there is a way to reset it without knowing the combo first.
however, i did find a very detail video on how to figure out the code. if you go to
http://www.engadget.com/2006/09/08/the-lockdown-your-new-targus-defcon-cl-lock-hacked-by-beer/
and scroll down to the bottom, there is a link to a video you can download and watch that shows you step by step how to solve your problem. the video link is in blue and starts with the words "as shown in the video".
hope this helps
Feb 28, 2011 | Targus Defcon CL Security
Thought I knew the 4 number combination, now locked inside. I do have the key. However, safe not opening. What is the exact procudure for combo?
Sep 17, 2010 | Office Equipment & Supplies
Well, sometimes happens. Last week some "funny" guy (or girl) changed the code of my Defcon CL Laptop Lock and yes, usually a left my cable in unlock state, so he (she) had change this code, maybe he (she)...
An easy way? Yeah, sure, make it easy for thieves to bypass the security. :-)
On the average, you'll only have to try 5000 combinations, out of the possible 10 thousand. Or, buy/borrow a heavy-duty pair of bolt-cutters -- see: http://www.hand-tools.us/images/pictures/northern-industrial-18in-bolt-cutters.jpg
and cut away.
Aug 02, 2010 | Targus Defcon CL Security
Windows won't roll up and down and wipers stopped working at the same time. The blinkers stopped shortly at the same time but they are working again. We thought it was a fuse problem but the fuses seem to...
Do you know anything about automotive electronics ? The GEM - generic electronic control module is in charge of turning on the wipers an control the power windows . Would think this a fuse problem . Computer problem maybe , the first step in diagnosing a problem like this would be to hook up a factory or professional scanner an checking for DTC'S - diagnostic trouble codes . Don't think about replacing the GEM module ,if you don't know how to test it's electrical circuits an check for codes . Can set a number of codes !
B1431 Front Wiper RUN/PARK Relay Coil Circuit Failure GEM REFER to Section 501-16 . B1432 Front Wiper RUN/PARK Relay Coil Circuit Short to Battery GEM REFER to Section 501-16 . B1434 Front Wiper HI/LO Speed Relay Coil Circuit Failure GEM REFER to Section 501-16 . B1436 Front Wiper HI/LO Speed Relay Coil Circuit Short to Battery GEM REFER to Section 501-16 . B1438 Front Wiper Mode Select Switch Circuit Failure GEM REFER to Section 501-16 . B1441 Front Wiper Mode Select Switch Circuit Short to Ground GEM REFER to Section 501-16 . B1446 Front Wiper Motor PARK Sense Circuit Failure GEM REFER to Section 501-16 . B1450 Wiper Wash/Delay Switch Circuit Failure GEM REFER to Section 501-16 . B1453 Wiper Wash/Delay Switch Circuit Short to Ground GEM REFER to Section 501-16 . B1458 Washer Pump Motor Relay Coil Circuit Failure GEM REFER to Section 501-16 . B1460 Washer Pump Motor Relay Coil Circuit Short to Battery GEM REFER to Section 501-16 . B1462 Seat Belt Switch Circuit Open or Seat Belt Buckled GEM REFER to Section 413-09 . B1466 Wiper HI/LO Speed Not Switching GEM REFER to Section 501-16 . B1473 Wiper LO Speed Circuit Motor Failure (Wiper Energized and Park Sense Not Seen) GEM REFER to Section 501-16 . B1476 Wiper HI Speed Circuit Motor Failure (Wiper Energized and Park Sense Not Seen) GEM REFER to Section 501-16 . If you don't know any of this , your best bet take it to a qualified repair shop.
Feb 26, 2018 | 1997 Ford F150 Regular Cab
I locked my cellphone and thought i knew my lock code, but i tried everything i thought it would be but i wont unlock
Sep 23, 2009 | LG ALLTEL AX275 Cellular Phone
I have a VIP suitcase with three digit combination lock. Thouh I have not changed the code, it is not opening. It seems to have stuck. I have tried to open it even with a few earlier combinations or my...
I just opened mine. I also knew the the password and the suitcase wasn't unlocking. If you are all sure that u know the password. Then put some oil in the lock. wait for 1 hour... This will help. If it doesn't work then.. Put the lock code and push the clips manually with a pait or scissors or a small blunt knife.. Don't worry the lock is just stuck. After all it's a vip and not samsonite
Mar 21, 2009 | Baby Gear
My Brass Master Lock Combination Lock is refusing to unlock. A couple of the combo numbers seem to be "sunk in" a bit. I tried WD40 but still will not unlock and I need to open my gate. This lock...
You need to make sure you are putting the righ combination. Try to put it the opposite way also for example
3645 or 5436
How many numbers are in the combination?...if it is a 3 number system it should be easy.
Artgirl
Jul 18, 2008 | Master Lock 5400d: Portable Select Access...
Cycling Logo
48 people viewed this question
Top Serfas Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Serfas Cycling Expert? Answer questions, earn points and help others
