Question about Jl Audio 500/1 Car Audio Amplifier
I hookd my jl 500/1 up i like it louddd but the bass goes in and out??? can you help .
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 69 Answers
Is there a green light? does it go red? the unit could be auto-protecting from your speakers, are they old speakers?
Posted on Feb 08, 2010
What color is the manual for the 500 1/v2 jl?
the manual is black and white and has 13 pages, but you say you have alot concern that the amp was used, if so you should give onlinestereo a call and let them know. just get the model and serial number from off of the box they came in.
Feb 20, 2010 | Jl Audio 500/1 Car Audio Amplifier
Bass freezes at a certain volumn and no longer gets higher
JUST CHECK THE CROSSOVER SWITCH, AND MAKE SURE THE SWITCHES ARE IN THE CORRECT POSITIONS
May 22, 2009 | Jl Audio 500/1 Car Audio Amplifier
Want too get best low bass i can from this amp
you turn your low pass filter (LPF) on the amp down to your desired frequency, but the box you have it in will drasticly change the sound (if you werent aware) hope this helps!
Mar 22, 2009 | Jl Audio 500/1 Car Audio Amplifier
Low ohms light flashes and bass distorts at high volume
Sounds like you need to invest in a capacitor. Those are used when subs receive a bass spike. You just a need a 1 Farat Capacitor (1,000 watts) ran between the head unit and the amplfiier to fix your issue. Also, try reducing the volume gain to half gain and low pass frequency to half gain; this will increase your clarity and make your amp less hot. This may fix it without a capacitor. Also find out what amprage your alternator is. Your alternator may not be designed to run the amplifier. Most alternators are 200 amps now if they are gold plated.
Hope this helps
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20378
Feb 10, 2009 | Jl Audio 500/1 Car Audio Amplifier
Jl audio 500/1 problem
Usually all amps spark a little when hooked up again after a while of no use. this happen cause there are many little capacitors inside to keep the amp running when hitting long bass notes. I think the reason you have been having problem after replacing the transistors is because there not the rite model number or maybe the polarity. You mite have to call jl and ask them if they have any in stock or google the model number of the transistor and buy them and replace them and see if it work. if it doesnt work then it mite be something else inside.
Jan 16, 2009 | Jl Audio 500/1 Car Audio Amplifier
500/1 amp turns on, but small ugly bass comes out speakers
Heat sink is jacked!!! Burned it out. Replace it or send it away to get fixed.... check the pricin on it sometimes cost alot almost as much as new amp....
Nov 04, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl 500/1
Sounds like you fried the channel on the amp or your gain might be up to high for the speaker
Oct 26, 2008 | Jl Audio 500/1 Car Audio Amplifier
Amp settings
It's going to be mainly "what sounds best", but I'll give you a start.
  • Set the gain to 50%.
  • Set the LP filter to 12db at about 80Hz.
  • Set the infrasonic filter to ON and at about 20Hz.
  • Set the Bass EQ to ON, Q to 0.7, center freq to 40Hz, and boost to about 5dB.
The other settings are going to be based on how the system is connected to the head unit.
Mar 22, 2008 | Jl Audio 500/1 Car Audio Amplifier
Blowing fuses
You will need to have the amp bench tested at full load to see if there is a pending problem. It will need to see with speaker loading resistors, how much current the amp is drawing and at different frequencies. if the amp checks out with the proper current, at the rated output, have the speaker checked out. Good Luck
Jun 15, 2007 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
111 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
