Question about Xerox WorkCentre Pro 123/128 Printer
2 sided printing problem
Hi, i'm having problem with 2 sided printing on my Xerox workcentre pro 123.
On the 2 sided print drop down menu, the only available options are: 1 sided print, flip on short and long edge. If i want directly to copy something on the printer, i can copy it 2 sided.
I downloaded the latest drivers from xerox web page, same result, even worst.
Flip on short and long pages now is not available, it gives "duplex mode- not available" warning.
Help
  • 1 more comment
  • levski Feb 22, 2008
    Yes, i downloaded the PCL driver. I did the the options thing, but the same.
    This is ok, but why i can copy a sheet two sides directly on the machine and can't print two side pages from the computer?
    Thanks a lot
    Ok, i'll try it on monday when i get back to work. Thanks
    President:
  • 2,072 Answers
What driver did you download? The PS driver is much less capable and I am wondering if thats what you downloaded.
I am using the PCL driver and the selections are 1 sided, 2 sided long edge , 2 sided short edge.
Unless you are runnung CAD, you really should be running a PCL driver.
Maybe I am misunderstand what you are telling me also.
If you have the PCL driver and thats still a problem let me know and I will forward all I can find.
Posted on Feb 22, 2008
  • 3 more comments
  • Rick Kasper Feb 22, 2008
    Here is an additional thought. Configure your machine,
    Here is how to do that to confirm that your machine configuration is correct on your computer.
    From the printers and faxes folder, right click on the 123 or 128 machine and select properties. Select the tab labeled printer. This will bring up the list of options. You need to select available for all options that are installed on the copier. This needs to be done on each computer that has the driver loaded.
    Let my go look at another computer where that drive is installed. Ba back in a few
    Those 2 options are the corect options. What they mean how the duplex page prints.
    One selection puts the top of side one and side two on the same side. Both tops will be at the top of the page. The other selection will flip the page so that the top of side one and side two will be on the opposide sides, so that when you flip the original from top to bottom you can view it that way. That is for government work.
    What you are seeing is correct, the choices you have orient whether you flip the copy side to side or top to bottom to read.
    Try both modes and see how it comes out. As I view your driver those seletions are proper, they are both duplex modes, just different orientations for side 2.
    If you are getting the duplex mode not available, you have to reconfigure the driver. Easiest way to do that is to go into your browser. IE Ineternet explorer and enter the machine IP address then verify the machine configuration. You want just update the configuration.
    You want to just click update configuration and let the machine be read and set up correctly, Every time you relaod a driver it needs to be reconfigured to be 100 percent sure all is going to work properly.
Go to the printer in your printer folder in control panel. Right click on it and select properties. Then select the last tab named "Printer" and click "Get information from printer button". Hope it helps you.. works for me.
Posted on Dec 12, 2009
    New Friend:
  • 4 Answers
In Windows 7 - Duplex printing in Xerox Workcenter 128:
Go to the printer in your printer folder in control panel. Double-click on it then select menu option named "Printer" and click "Properties". Hope it helps you. worked for me.
Posted on Jan 23, 2014
Controladores WorkCentre Pro 123/128
Try Global drivers, maybe work in yoe case. In search put Global Print Driver, then Drivers & Downloads.
GL
Jefferson, Fortaleza-Ce-Brasil
Dec 12, 2010 | Xerox WorkCentre Pro 123/128 Printer
How to print auditron report (copy) from workcentre pro 128? Need step by step instructions- have no manual
Printing Service Reports
1. To access Service reports, follow the Entering UI Diagnostics procedure.
2. After entering the Access Number, press the Machine Status button on the Control
Panel.
3. Select the Billing Meter/Print Reports tab on the display.
4. Press the Print Reports/List button.
5. Press the CE button.
6. The following reports can be printed.
• Debug Log Report
• HFSI Report
• Jam Report
• Shutdown Report
• Failure Report
• Protocol Monitor Report
7. Select the required report and press the Start button. The selected report will be printed.
Jun 11, 2010 | Xerox WorkCentre Pro 123/128 Printer
How to open a message???help!!!!!
On the console you should find menu buttons. Find jobs or job prints. Select your number job and print it.
The menu buttons have many features you can scroll through. The print reports can print out the menu of the different menus of the fax machne.
good luck.
Feb 17, 2009 | Xerox WorkCentre Pro 785 Plain Paper Laser...
Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
Sep 08, 2008 | Office Equipment & Supplies
Printing recto verso
On your computer, click mouse on windows icon in lower left corner of screen. When the menu appears, left click on 'printers'. Go to the icon representing the Xerox, and right click mouse. from the drop-down list, chose 'properties' at the bottom. The 'properties' window should appear. Under the ''general' tab, it should show 'yes' for double sided prints. Go to the 'accessories' tab and left click mouse. A list of installed accessories should appear. See if there is a 'duplexer' accessory available. If it is, left click on the duplexer display and add it to the Xerox. Left click mouse on "apply" tab, then left click on the "OK' tab. Exit out of 'printers' and test.
Jul 05, 2008 | Xerox WorkCentre M123 Copier
Unable to print envelopes on Xerox WorkCentre Pro 123
Some thoughts.
Envelopes won't print from bypass tray. Cause:
Extended tray is not set up properly for envelopes. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Enter tools "Login" 1,1,1,1,1 Touch buttons with the following names in that order: System Settings System Settings Common Settings Other Settings Scroll down to "Extended Tray" Next to "Extended Tray" it may say "Inverter" if it does go to change settings then change it to "Offset Stacking" Close out tools.
Nov 22, 2007 | Xerox WorkCentre Pro 123 All-In-One Laser...
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
Xerox WorkCentre Pro 123/128 Printer Logo
1,439 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
