Question about Cisco ASA 5510 Firewall
Network diagram i have a router with 3 circuit. router is the edge router behind it is the ASA5510 and i have l3 switch behind it i want to design a network with 3 vlan and use route map chennalized the vlans traffic to these 3 cricuit. can any one help me to provide the diagram and solutions to implement.
  • GScully Jun 30, 2008
    I'm trying something similar, 3 lans on 3 interfaces, wan on the e0/3 interface.trying to use ASA as router for the lans and firewall for wan, Can't get routing and or access list right for each one to ping others. So 10.1.1.60 can't ping 192.168.0.33. Setting the switch "allow access to interfaces with same security level" did nothing to help.
    Tried "static (server,users) 10.1.1.0 10.1.1.0 netmask 255.255.255.0 and the reverse and still no luck. Called Cisco, had tech on for week and he ended up saying it was my switch. Took switch out of loop and have the same issue.
  • Noe Lana
    Noe Lana May 11, 2010
    so you mean router > L3 switch > Servers?
    Problem Solver:
  • 11 Answers
You can feel free to call to this mobile number ill help u 09620077956.cuz we are the solution providers.
Posted on Mar 27, 2009
I need to wire up a 3 phase compresser motor, 9 wires wired 480, to change to 240 volt hookup. right now it is wired 3 motor wires to each hot, no nameplate or wiring diagram.
Please verify the existing connections to determine if they fit the "High Voltage" configuration listed below. If they do (and they should), the "Low Voltage" configuration below is then correct for 240.
Jaypug
Low voltage ...
L1---1--6--7
L2---2--4--8
L3---3--5--9
High voltage ...
L1---1 4--7
L2---2 5--8
L3---3 6--9
Dec 04, 2013 | Gb Electrical 100 Amp GE Load Center
New cisco asa 5510 setup
connect your laptop to the asa5510 using a cross over cable
Oct 07, 2009 | Cisco ASA 5510 Firewall
Basic UPS system circuit diagram
i want to design 3-phase UPS system for my project. so, i need the basic UPS circuit diagram before doing this project....can anyone help me..where can i get the circuit i want 60kva to 200kva ups circuit diagram with block diagram
Jul 28, 2009 | Powerware 9120 UPS System
Beginners network
It depends upon the switch/router port capacity. actually, if you don't know its better not to configure it. You can plug it directly without any problems.
May 07, 2009 | Computers & Internet
Failover best option required..
You can only do active/active if you're using multiple contexts. Active/active can give you some extra performance for your $ since you can pass traffic through both ASAs. Compare this to active/standby where the standby unit passes no traffic.
If you're pushing the 5510's to 80% capacity each in active/active mode, then you have one fail, now the one single ASA is oversubscribed. The oversubscription could cause connectivity issues that defeat the purpose of failover in the first place.
In the spirit of reliability go with active/standby. Seeing that you have two active core switches that would be pushing all of their traffic through a single 5510 in this case....it may be too much active/active may be the better solution.
Mar 31, 2009 | Cisco ASA 5510 Firewall
Real diffrerent between Router & L3 switch
Following links might be helpful to you:
http://web.ivy.net/carton/rant/l3-switch/switch-l3intro.html
http://compnetworking.about.com/od/hardwarenetworkgear/f/layer3switches.htm
http://www.e-tutes.com/lesson8/networking_fundamentals_lesson8_3.htm
http://nixcraft.com/computer-networking-internet-broadband/454-difference-between-layer-3-switch-router.html
Thanks for contacting Fixya.
Mar 24, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
I have a problem with a cisco catalyst 2948G-L3. A have erase of mistake the bootflash. I have tried in some way to download a new IOS, i have the IOS bu i cannot download it in the flash because the...
Two ways to do that are xmodem (slow) or Tftp from rommon mode. (fast)
Place the IOS image in your tftp server directory and start tftp server.
Then enter the following in the switch exactly as below as all are case sensative:
rommon 1> IP_ADDRESS=xxx.xxx.xxx.xxx
rommon 2> IP_SUBNET_MASK=xxx.xxx.xxx.xxx
rommon 3> DEFAULT_GATEWAY=xxx.xxx.xxx.xxx
rommon 4> TFTP_SERVER=xxx.xxx.xxx.xxx
rommon 5> TFTP_FILE=full file name of ios as it reads
rommon 6> TFTP_CHECKSUM=0
this one is in lower case
rommon 7> tftpdnld
If you dont have a tftp server below is a link to a free one
http://www.solarwinds.net/Tools/Free_tools/TFTP_Server/
You will need the .bin IOS image for this and not the .tar file. The .tar file contains router cluster management files that you must issue the archive tar command to load all of the files. Can do that if needed after router is back online.
P.S.: If this information was helpful, please rate this solution.
Feb 24, 2009 | Cisco Catalyst 2948G-L3 Networking Switch
VLANS
your router have reset switch just press, then off router and on.
May 29, 2008 | 3Com (3C16593BN) 24-Port Ethernet Hub
Cisco ASA 5510 Firewall Logo
1,187 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
