Question about Ricoh Aficio SP C222SF All-In-One Laser Printer
Sc300 service call - Ricoh Aficio SP C222SF All-In-One Laser Printer
  • 903 Answers
On the SP C222SF, sc300 is a high voltage output error. More than likely, either the high voltage supply board (HVSB) or engine board (EGB) is bad and needs to be replaced. However, before going that far, you can try turning off and unplugging the machine and reseating the connectors that go to those two boards. Sometimes a loose connector can cause a service code, and fixing the connection can clear the problem up.
Posted on Jun 03, 2010
Where is crank shaft sensor location on 95 lexus sc300 please help
images for Where is crankshaft sensor location on 95 ...
eplaced engine on '97 SC300 now new engine does not have Crank ...
www.clublexus.com/.../633233-replaced-engine-on-97-sc300-now-new-...
May 4, 2012 - Location: arizona. Posts: 3 ... apparently 95-97s had an additional crank sensor. .... 1995 Lexus SC300 5spd Na-T ( TT Ecu Mod + a few others) 2jzge position sensor??
Nov 2, 2011
SC400 Crank Shaft Position Sensor. WHERE?????
Oct 11, 2011
SC300 No Spark
Oct 2, 2010
What happens if the Camshaft Position Sensor goes bad?
Jun 18, 2009
More results from www.clublexus.com
Lexus Crank Position Sensor ' LS400 SC300 ES300 GS300 ...
www.partsgeek.com > Crank Position Sensor > Lexus Parts & Accessories
Products 1 - 10 of 68 - 95 1995 Lexus LS400 Crank Position Sensor Denso NLA 7/13 ... 96 1996 Lexus SC300 Crank Position Sensor Denso Includes Pigtail.
Jan 27, 2016 | Lexus Cars & Trucks
What kind of battery do I need for Homedics Lithium Electronic Scale
Here are the Instructions for SC300:
http://web.archive.org/web/20061029012330/www.homedics.com/prod/getpdf.aspx?name=SC300.pdf
Page 2 says the scales require a 3 volt CR2032 lithium battery. These can probably be found wherever batteries are sold - WalMart, Target, etc.
Dec 09, 2014 | Homedics Health & Beauty
How do I fix code 13 engine speed sensor Above 1000 rpm
Clearing the codes is simple that is done by removing the fuse of the EFI from junction box 2 for 10 seconds. Make sure to remove the jumper wire and switch the key off before clearing the codes.
Here are some common Lexus vehicles 1990-1995 codes:
Code 12 and Code 13 Rpm signal circuit fault
Code 14 Igniter signal circuit fault
Code 16 ECT control signal fault
Code 21 and Code 28 Main oxygen sensor fault (for ES300; SC300 & GS300 models)
Code 22 Coolant temperature circuit fault
Code 24 Intake temperature sensor circuit fault
Code 25 and Code 26 Air fuel ratio fault (for ES300 & SC300 models)
Code 27 Sub-oxygen sensor circuit fault (for ES300 CA & GS300 models)
Code 31 Low airflow meter voltage (for ES300 and GS300 models)
Code 32 High airflow meter voltage (for ES300 model)
Code 35 Barometric pressure sensor circuit fault (for GS300 & SC300 models)
Code 41 and Code 47 Throttle position sensor circuit fault
Code 42 Vehicle speed sensor circuit fault
Code 43 Starter signal
Code 51 Switch condition signal fault (for ES300; GS300 & SC300 models)
Code 52 Code 52 and Code 55 Knock sensor circuit fault
Code 71 EGR system circuit fault (for ES300; GS300 & SC300 models)
Code 78 Fuel pump control circuit fault (for GS300 & SC300 models)
Nov 18, 2014 | 1990 Lexus LS 400
Error Code sc300-01
Replace Charge corona end blocks
Dec 12, 2013 | Ricoh Aficio Office Equipment & Supplies
1997 lexus sc300 leaks in drivers side floorboard when it rains
Go to the nearest mechanic shop and let them check the leak to your 1997 lexus sc300.
Bushwacker
Mar 18, 2013 | Cars & Trucks
Sc300 had this code on afico 1075
Charge corona output error 1
The feedback voltage from the charge corona unit is too high
Possible causes -
· Charge P.P. defective
· Poor charge corona unit connection
Jan 25, 2010 | Office Equipment & Supplies
1992 SC300 starts initially then won't start
fuel filter is hardly ever been a problem with a lexus or toyota.you need to check for spark at the plugs.then go from there.
Jun 11, 2009 | 1992 Lexus Sc 300
Copier/printer is out of service
AC charge output error for k. OPC problem, bcu bad or hvps bad. Could be bad drum ground.
Mar 21, 2009 | Lanier Office Equipment & Supplies
1992 sc300 lexus
it is under the vehicle, driver side, below the seating area, in front of the rear wheelwell, mounted on chassis in fuel line.
Sep 28, 2008 | 1992 Lexus Sc 300
Ricoh Aficio SP C222SF All-In-One Laser Printer Logo
1,282 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
