Question about Yamaha Televison & Video
A DVD got stuck in my DVD-E810-Pianocraft player of Yamaha. As I tried to get it out, it dropped inside the box, and now stays there. Did anyone else have the same problem? Is it safe take off the screws and open the metal box to get it out? Can anyone provide help. Dmitry, Goettingen, Germany
    President:
  • 173 Answers
Hello Dmitry,
Lift the player out of the box as careful as possible and set it on a flat surface near your television so you can plug it in and test it after you have removed the disc. Go ahead and remove the screws and carefully remove the cover and take the disc out. In some cases you may have to apply a steady gentle pressure on the dvd tray to gently push it out if you can not get the disc out easily.
Once you have the dvd out of the machine you are going to want to plug it up to the tv and into a power source and systematically test the system components to make sure they are in working order.
Start with the power button to see if it is working and watch the screen to see if the video signal is being transferred to the tv (usually when you plug a dvd up and turn it on, it will say something about dvd on the screen).
Next push the dvd open and close button and make sure the tray is working properly. You will be able to see the tray slide in and out with the cover off. Make sure the little gears are not broken, belts are on, etc. If any part is not functioning properly or hanging up, stop and unplug it because you will most likely need it repaired and other components may be damaged. If everything works properly keep going.
Next put the dvd in and see if the disc spins and the laser is hitting the bottom side of the disc. Do not look directly into the laser. If the disc is spinning and the laser is working then the movie should be showing on the tv screen.
If everything is working, check the other buttons start, stop, pause, etc and check to see if the remote is functioning if it came with one.
If everything is working properly, replace the cover and continue to set your dvd player up where you want it. If something is broken, you will have to make a choice have it repaired or buy a new one. Depending on the price you paid for the device it may be cheaper to buy a new player.
I hope this helps you solve the issue. You can check my profile, go to my tips, where you can find some helpful tutorials and tips.
If you would not mind, rate my help. I would greatly appreciate it. Thank You
Posted on Feb 08, 2010
Testimonial: "thanks for help "
Yamaha pianocraft amp/tuner wont turn on, is there a fuse or known fault?
as far as i know there is not a SMPS but a normal power supply in there? Checked the caps?
Apr 25, 2014 | Yamaha Audio Players & Recorders
Dvd draw will not open yamaha dvr s60
Hello
either its loading motor is faulty, or the loading belt is broken. The commands are reciving, but it does not work mechanically. A mechanical fault indeed.
Feb 28, 2012 | Yamaha DVR-S120 DVD Player
Yamaha dvd s-80 showing error code H01 when trying to play disc. What does this mean ?
The manual isn't much help, is it?
http://www.retrevo.com/support/Yamaha-DVD-S80-DVD-Players-manual/id/320ag210/t/2/
It seems the "H01" is some kind of common and fatal error code in many disc players and I have yet to find anyone who has paid the ransom, er cost, to get one fixed as it is cheaper and makes more economical sense to just buy a new unit...
http://www.electronicspoint.com/panasonic-sc-ht75-dvd-player-broken-t55762.html
Feb 11, 2011 | Yamaha DVX-S80 System
Yamaha Pianocraft E810 It makes an unusual noisy motor sound every time i put a dvd or CD (ever since I bought it 6 months ago). I was expecting a smooth, almost unnotocible noise of the motor when in...
Ricardo! you should barely hear the motor when it is running, what you are describing is the pladder motor that turns the cd/dvd disc, you should not hear it when runs a dvd movie when audio is added, I think it would wise to take back to the supplier.
Jan 06, 2011 | Televison & Video
My dvd tray is stuck...I think it's a dvd stuck in the tray
unplug the player for 5-10 min...once you plug it back and power on quickly tap the open/close button (the player by default will try to load the disc)
feel free to rate help
Jun 26, 2010 | Yamaha DVD-C996 DVD Player
The dvd is stuck mid way not opening or closing
Try unpluging unit, then plug back in and press open/eject.Also look for a tiny hole on front door used to insert paperclip end, push in this will open tray.
Sep 04, 2009 | Yamaha DV-C6280 DVD Player
A DVD is stuck in my player. When I open the tray the dvd isn't in it. I can see the dvd inside the player but it will not drop on to the tray. HELP! ITS A RENTED DVD!
Try removing the top cover, very often if the DVD is not in the tray it will be accessible to retrieve once the cover is removed.
Aug 04, 2009 | Toshiba SD-2900 DVD Player
DVD Tray stuck open
the tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Jun 17, 2009 | Yamaha DVD-C920 Multi-disc DVD Player
Yamaha DVD S1700 player multi-region unlock code
see if this works
  1. Power on
  2. Press PLAY
  3. Enter 2, 7, 4
  4. Enter 222 222 005 255
  5. Press PLAY
  6. Power off
Nov 18, 2007 | Televison & Video
Televison & Video Logo
460 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
