Question about Maytag Atlantis MDE7400AY Electric Dryer
How do i remove the top from a maytag atlantis electric dryer?
  • 56 Answers
Open the door, remove the two screws holding the hinge and on the opposite side, pull the front panel towards you then lift off. you will then see two 5/16 screws holding the lid down.
Posted on Feb 08, 2010
How do I take the top off of the Maytag Atlantis dryer?
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Sep 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
Remove front panel and door on maytag electric dryer atlantis
Simple, 4 screws total. open door, remove one screw from each of the door hinge plates that are against the front panel, remove two screws directly across the door opening (other side of dryer), door can be lifted slightly and pulled out of slots, and front panel can be unhooked from retaining clips by a little wiggling at the top sides, swing it down toward the floor and lift it from bottom retaining hooks.
Apr 14, 2013 | Maytag Atlantis MDG8400AW Gas Dryer
How do you install the belt on a Maytag Atlantis Dryer?
Ya gotta remove the front panel to get to the innards on this beast.
Take the door off. Opposite from the door hinges is 2 more screws that are used to hold the goalpost shaped front panel on there. Once them screws is out the panel pops off and you raise the top after removing the holddown hooks.
Then you gotta remove the front shroud and get the drum out. Give it a good cleaning. Oil the rollers.
Service manual
Nov 08, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
The paddle broke off in my Maytag Atlantis Dryer
you need to remove the frt cover 1st and then the screws will be accessible to remove top cover
Sep 19, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
We have a Maytag Atlantis dryer. Inside the tub
Did you try opening up the back of dryer or the top?
Sep 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
How do you pop off the top of the dryer?..is it bolted in any way
Hello.
Reomve the door from the unit and the plastic peices from the other side in the same spot as the hinges. Remove the front panel. You will see one metal peice on each side that hooks the top on. Remove the screws and the metal hooks. The top will lift up now.
Jul 22, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Replacing the belt for Maytag Atlantis Dryer Model MDE7600AYW. What steps do I follow ??
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 10, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
How do you lift the top on a 2003 Maytag Atlantis?
remove the door and the oppins screws from the fron panel, the panel will fall foward revealinga few 5/16 screws to release teh top assy
Mar 14, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis dryer no heat
The heating element and thermostat are located behind the front panel of the dryer. you will need to remove the door, then the retaining screws. the heater / element is located on the left side as you are facing the front of the dryer and has to sheet meta screws (upper back top / and front bottom) which will need to be removed. the unit has several colored wires for the thermostat and switch. remove these (remember which goes where) and the enitre unit will come out easily.
Aug 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis Model 6400AEW Dryer bought 2003
On my 2006 Maytag Atlantis the top is held down by 4 screws 2 under the front and 2 on the back.
To remove the 2 on the front you need to remove the screws in the door and remove the door and front panel, than remove the 2 screws. The 2 screws on the back hold a white plastic fastener. After removing the screw, pry the bottom of the plastic fastener with a flat head screwdriver. Than with a very thin screwdriver or a thin pry bar wedge it under the top cover and just pop it off. Take care to not scratch your dryer while prying the plastic piece off.
Good Luck
Jan 11, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
374 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
