Question about Pioneer Televison & Video
Display Standby/on light blinks red - screen will not come on. While watching I heard a pop and screen went blank. Whentrying to re-power up, the light briefly goes green, then blinks red.
  • 148 Answers
Hi there, the green light upon startup means the circuit boards are powering up. At some point ( a bad capacitor in your case) the system "runs" into a bad component ( the capacitor) and this faulty component will shut the system down ( for safety reasons the tv has a built in device that trips the circuit when a problem is encountered), this in turn shuts down "the power-up" cycle and the unit shuts off and displays the red light again....You will need to call a professional to have the circuitboards checked out. You can, if you wish, open the unit and use my guide to help you locate and diagnose the most common problem with tv's having the symptoms you've mentioned....The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped you any (or not) then please rate...Also I am very interested in your progress with this issue.Display Standby/on light blinks red - screen will - fb6651e.jpg
Posted on Feb 07, 2010
  • renthelp Feb 11, 2011
    Many thanks for a very helpful write-up and pixs.
    Gramps // renthelp // BDCD928E
Panasonic Viera tc-p65s2 - 7 blinks, won't turn on
I had the same problem with my Viera. if you disconnect the power and ribbon cable from the YSUS board (check youtube for how), the light led will blink 6 times, indicating the YSUS is bad. Check ebay for TNPA5175 board (about $115-160). The pop is one of the DG402RP chips burnout. These are about $4, but only available from China. If you can wait a month for delivery, you can solder the new one to replace the bad one. You may want to purchase several in case more are bad or it happens again.
Aug 06, 2012 | Panasonic VIERA Televison & Video
Was watching TV, heard a pop and the screeen went black. Now when I turn it on, the pwoer light blinks green but their is no picture or audio. The light then starts blinking red
Is is standby light blinking red or any other light? Let me know how many times red standby light blinking after three seconds long pause to provide you helpful info.
It seems pop sound was due to broken lamp, please check lamp inside tv and if it is broken, replace it to solve tv problem.
Hope this will help.
Thanks.
Mar 09, 2011 | Sony KDS-50A2020 Television
I have sony Bravia KLV -32V300A suddenly shut-off while I am watching power indicator went off and standby red light blinking 5 times then after 2 seconds off then red light blinks again 5 times and so...
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Mar 09, 2011 | Sony Televison & Video
My 47LG70 tv went out. I heard a pop and the screen went blank. The lower right hand sensor light turned blue. I tried unplugging but that didn't work. When I tried to turn it on again the sensor light...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 02, 2017 | LG 47LG70 42 in. LCD TV
Screen blank
Sounds like a cap or fuse has blown in the set, you will need to take the back cover of and have a look, check on the power board for any blown caps, you will notice them straight away if one has poped, also check any fuses that may have blown they will also need to be replaced.
Feb 18, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
We were watching our TV and there was a "pop" and the screen went blank. Now when I try to turn it on nothing happens, the standby light switches to red and no picture comes up at all. What happened??
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The "pop" you heard was probably a Capacitor has literally "Blown Up". Due to a power problem.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Feb 10, 2010 | Televison & Video
Power light flashing all 3 colors TV will not turn back on
Sounds like the Power supply module. I would take it in to service center ASAP!
May 21, 2009 | LG 32LC7D Television
Heard a pop and screen went blank - won't come back on.
Your Lcd Projector Lamp/DLP Television Lamp went out
its about $165-$200 to replace if not under warranty
Nov 28, 2008 | Hitachi Televison & Video
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
Televison & Video Logo
1,454 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
