Question about Optics
I HAVE BUILT MY FIRST SKS (YUGO) AND IT WILL NOT SHOOT IN SEMI-AUTO I HAVE USED A NE GAS VALVE NEW GAS PISTON NEW GAS TUBE AND OPP ROD AND SPRING
  • 2 more comments
  • reece279 Feb 08, 2010
    yes the gas valve hole is in line with the hole in the valve housing when fired you can smell the gas bit piston will not move or op rod you must eject the empty shell by hand also
    it will not chamber a new round if the recoil spring is to heavy how do i fix that
    thanks for the help
  • Adrian Ahrens
    Adrian Ahrens May 11, 2010
    Have you put the gas plug in the correct way?
  • Thermo King
    Thermo King May 11, 2010
    When you fire, will it put a new round in the chamber? If it reloads, it's self then it is in the trigger mechanism that will not allow the follow up. But if she will not put a new round in the chamber you may have too heavy a recoil spring..
  • 2,418 Answers
If your rifle reloads a new round but will not fire it is a problem with the trigger mechanism, if it does not reload a new round but locks back like the clip is empty, you have a problem with the clip spring not forcing a new round up hard enough to feed, if it cycles the receiver and does not pick up a new round your recoil spring is to strong or you need to open the gas port some more.
Posted on Feb 08, 2010
  • John Fourteen Six Feb 08, 2010
    Is this a SKS or an AK type. The SK has a gas tube and port on top of the barrel and the AK has the port and tube on bottom.
  • John Fourteen Six Feb 10, 2010
    reece279 I would like to know more about your project, what type of ammo you are using. Are you using the barrel with the grenade hook?
1997 chevy lumina bent rod and valve? Can I repair this myself or shop, I'm semi experienced shade tree mechanic and have done top end rebuilds down to head gasket many times but not a valve job. How?
First is to remove the valve. You'll need a spring compressor. Different types on the market. Then use a new valve to check for side to side slop. It shouldn't move at all. I tiny bit is OK. A lot, have the guides(all) knurled. Also check to make sure the valve didn't damage the seat in the head. If it did, find another head. If all is good, them you need to reseat the new valve. The is a valve compound at parts store to by. You can do it by hand. I use a drill on the valve stem, go both directions until the seat and valve are polished. After that put it back together. This was my first job, working with my Dad. I was 10 years old.
Aug 12, 2016 | Cars & Trucks
Gun will fire but bolt only comes half way back
Gas port plugged from carbon build-up.
Not allowing enough gas to hit the piston of the operating rod.
One tool you need that isn't normally in the cleaning kit:
http://www.ebay.com/itm/TWO-2-SKS-GAS-PORT-CLEANING-TOOLS-UNISSUED-FREE-SHIPPING-/321305505195?pt=LH_DefaultDomain_0&hash=item4acf4cedab
This is a "gas port cleaner/scraper".
Remove gas tube (with the upper forward handguard), and the fitting on the barrel that the front of the gas tube plugs into, look down the hole, and you'll see the gas port.
The below pic shows where I'm talking about:
http://www.koreanwaronline.com/arms/sks/jpegs/figure16.jpg
And what the gas port looks like:
http://yooperj.com/page08/08yugo_gas-block%20(4).JPG
Jan 10, 2012 | SKS Rifle High-profile See-thru Scope...
I need to find out how to convert a yugo sks to an automatic. it is semi auto but i want it to be automatic. Its a 7.62.39mm. Can you help?
Pay the feds $200 tax stamp and become one of their most watched, then go out and find a conversion kit, consisting of auto sear, selector, trigger, hammer, bolt carrier, springs, and whatever else you need, install it, you will be all set, then find a couple thousand rounds to feed the thing. And become hated by everybody within ear shot of your rifle.And every local police wanting to see your federal papers. Not worth it in my book. Fun yes, but not worth the aggravation. Are you in the US?
Mar 13, 2010 | SKS Rifle High-profile See-thru Scope...
I have two sks, one is norinco and the other one is russian. The chinese type can fire only 123gr of ammo but if I use 127 gr., it won't eject the shell out of the chamber. I don't have that problem with...
I don't understand that one but, I would have to guess that the gas tube is leaking? Or clogged, Most of those guns are made to shoot and cycle no matter what. And the difference between 2 bullets of almost the same weight shouldn't mean nothing. I know the russian is a better gun, But,,, You must have a leak, or the piston is letting gas by. One way to find out is wrap the whole handguard from the bolt handle to the front sight, especially the gas tube, fire it and see if it gets a black spot somewhere along the line, If so, you found a leak, If not, I would have to look at it to tell. I had an L1A1 that did the same thing and I traced it back to the adj. Had to seal it up tight or it wouldn't eject a spent round.
Feb 17, 2010 | SKS Optics
Gas tube
I don't know what you did, but when you beat on something that is supposed to glide with ease, something is wrong. Send me that thing, I'll fix it. I have been sitting around here bored to death lately. Where do you live? I was wondering what would happen if yo took the old gas tube, put crimp in it, to slow it down, and try it, see what happens. The locking lever? You mean the bolt? Is jumping out of it's track? Yikes!
Feb 13, 2010 | SKS Optics
My sks jams a lot. i sometimes get 2 or 3 rounds out of it and it jams again. i have to extract the spent shell and help the next shell in. what can i do
SKS's were built without polished ramps Have a gunsmith regrind and,polish the bolt ramp and, your rounds should insert and, extract flawlessly.
Jan 26, 2010 | SKS Rifle High-profile See-thru Scope...
Yugo sks. rounds wont cycle. all parts in pretty good shape.
sounds like you have some kosmaline left in there Take it all apart and degrees everything , trigger, bolt, firing pin and inside piston tube even an used one might have been sold because it never was cleaned of all the storage grease and they could never get it to work also watch for slam fire and firing from just carrying it as it keeps the hammer from cocking all the way
Oct 24, 2009 | SKS Rifle High-profile See-thru Scope...
SKS bolt jams with gun empty
If you have Cosmo any where it wont work . Clean it from inside the firing pin channel and trigger group , mine would also slam fire and bump fire till I got it all cleaned out
Oct 11, 2009 | SKS Rifle High-profile See-thru Scope...
Optics Logo
105 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
