Question about Kenmore 73952 / 73954 / 73959 Top Freezer Refrigerator
Fridge question Hello, fridge question, the power is on, lights work, I can hear the relay pull in and the compressor turn on, but it only stays on for a few seconds and turns off again. Of course neither the fridge or freezer are cooling. Any thoughts?
  • 311 Answers
Sounds like you mad have a bad relay or overload on the compressor. I would also check your condenser fan motor to make sure its running and blowing air on the compressor to cool it. If its not running the compressor may be overheating and shutting off on its overload. If the condenser fan motor is running I would assume that you would need a new relay and overload it will come in a kit. Usually it will make a clicking sound when the compressor is TRYING to start and then shuts off on its overload if the start components are bad.
Hope this helps _MJ_
Posted on Feb 07, 2010
GE Profile PTS25LBMARWW - Power, but no Cold
yes the mother board is located under the plate in the back.. but when you replaced the relay did you put on a 3in1 relay or a manufactured relay?
Aug 01, 2008 | GE Profile PFS22 33" Artica French Door...
HELP! - My fridge freezer is not cooling - clicking sound heard but motor not coming on
Hello Michelle;
My name is Peter. I am a retired field service refrigeration technician.
Lets fix this together. The clicking sound that you hear is referred to as a overload relay. The overload relay is an electrical component that starts and stops you compressor. It is very common for the overload relay to fail over time.
First, locate and purchase a overload relay. If you have a Trible's
in your area that's great, if not Lander's, Sear's, .... If you can wait a few days you can get the part over the internet for half price or less.
I do not have your model number otherwise I would give you the part number.
Having the part, pull the refrigerator out where you can move freely behind it. Unplug the refrigerator. There is a bottom cover that you need to remove. This cover is fastened either with Philips or hex head screws. Remove the cover. Open the new overload relay parts and lay them before you. Study and observe them.
There is a black box on the side of the compressor which holds the overload relay. The box is held on with either metal or wire clips. Using a flat head screw driver pop the clips off. Compare the parts on the compressor with what you have. Note the location of the connecting components on the 3 compressor pins, and the first piece to put on the compressor is the white piece with the 'V'. Using your flat head screw driver, wedge the components off the compressor (Remember how they go back on). Do not pull on the wires - just the connector ends. Replace the components. Shake the white piece - if it rattles or is burned it is bad. If you can not get the black box cover back on - not necessary, it's a dust shield.
Note: If you have a LG, bottom freezer 599, do not bother. Both the overload relay & compressor need to be replaced. Buy new, not LG.
Oct 28, 2014 | Refrigerators
Refrigarator not working after power outage
When power goes on and off suddenly, it can cause the compressor to overload and "trip out" This is supposed to protect the compressor from being electrically damaged. In most cases, after 10 or 15 minutes, the compressor will reset. It is usually safer to switch off the fridge or unplug it for 10 to 15 minutes to ensure a full reset. If it doesn't start, the power surge may have damaged the compressor relay. or overload device on the side of the compressor. I would doubt that it damaged the compressor itself. Be aware of the relay and overload device, unfortunately, there are Techs who will quote for a compressor job when all it needs is a relay or overload.
Feb 22, 2014 | AEG Refrigerators
Fridge and freezer stopped cooling...light stays on, cleaned coils, drain not clogged...fan is working...hear a click about every 3 minutes, light goes dim for about 10 seconds...another click, lights back...
the click is the compressor trying to start . i would replace the relay and compresser over load . . they do go bad and this is what happens . .. mm hope this helps .. feed back pls ..
Jul 10, 2011 | Kenmore Refrigerators
Fridge/freezer doesn't work although light on
Hi David and welcfome to FixYa. I am Kelly There are a few things to try before you go replacing parts.
1. after the unit has sat with no power for about 30 minutes plug the unit in and listen for an attempted sart on the compressor. An attempted start will only last for approximately 40 seconds. During that attempted start listen to see if you actually hear the compressor turning. If you hear it turning and it again shuts off wait another 30 minutes and try it again. (On a unit that has been in storage for more than 6 months it can take a few attempts to get it going.) If it just hums and does not move then your compressor is locked and as it attempts to start you will notice a slight dimming of the house lights. Don't give up on it right away... do about 4 cycles of the plug it in.. listen for the 40 seconds then the CLICK of the compressor thermal overload switch. If your not hearing a CLICK after 40 seconds or so then there can be a compressor PTC relay / thermal overload (KliXon) problem or the possibility that the run capacitor has failed. After all of these have been checked out then you start looking at controls and power. Give it a few more tries to see if it takes off. If it does not then just repsond here and someone will help you.
Thanks for using FixYa,
Kelly
Apr 10, 2010 | Liebherr KDPes 3142 Premium
My freezer is not working properly with clicking sound.
The clicking sound is probably the compressor relay trying to start the compressor. When the lights dim, the compressor is trying to start and hence, pulling power from the rest of the unit. If the compressor has a start capacitor, that could possibly be the problem. If not, the compressor itself should be replaced.
Mar 26, 2010 | Maytag MSD2454G Side by Side Refrigerator
GE side by side Model GSS25JFMD 2 yrs old. Original problem was not staying cold. now I see if I unplug for half hour it seems to work right but sometimes freezes in fridge . I'm hearing a clicking sound...
These problems are saying relay/capacitor replacement and if that don't work then compressor replacement.
First change the relay and the compresssor cap. See if you have improvement...if not then you will need to have the compressor replaced.
Here is a tip about the relay and cap....
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Heatman101
Feb 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Compressor only stays on for 30 seconds which is not long enough to completely cool refrigerator all fans work and coils are dust free
if unit is coming on for a few seconds and then u hear a click, you may have a bad compressor relay. pull it off the compressor and shake. most times u will hear a rattle of junk. if so its bad.
Jul 25, 2009 | Kenmore Refrigerators
Kenmore 73952 / 73954 / 73959 Top Freezer Refrigerator Logo
144 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
