Question about Samsung Yepp YP-F1Z MP3 Player
How to remove the battery
I want to remove the battery of samsung yp-f1. how do i do it? There is communication problem between a firmware update application and device while it is in the recovery mode for which i will have to disable the battery. but im unable to figure out where the battery is inside the player.
    Problem Solver:
  • 6 Answers
Have to completlydissaemble unit. Not hard but fiddley and tiny parts. Remove top custom color plate with fingernail. remove 2
phillips screws and set aside on nonslip surface (tissue). slide top plate with view screen away form usb connector 1/16 inch to unclip and lift off. Slide Metal belt clip left or towards usb port side (carful not to scratch ld viewscreen. and set aside. Remove 2 philips screws holding circut board and lcd (Set aside seperat from other screws as shorter and must go back samme place.
Fingernail out whit clip over usb port and set aside. Lift entire circutboard/lcd unit on left side (usb port) up and slde out that end so as not to catch volume control . Carful of battery leads.
(CAREFUL OF ROCKER SWITCH INSERTS ON EACH SIDE NOTE HOW SEATED AS THEY TEND TO FALL OUT BUT EASY TO REPOSITION IF YOU LOOK BEFOR THEY DO)
Raise far enough to get fingernails on battery terminal clip ON BOTTOM OF CIRCUT BOARD and pull straight off. ( note polarity as clip will fit back on either way but only 1 works and reverse polarity may damage unit. Wafer battery will pull right out of case and haspolarity +/- marked with numbers (assume model or part number)
Posted on Apr 12, 2008
My samsung mp3 player yp-f1 wont power up and when i plug it into the computer nothing happens either just like it went dead it does not power on, the pc recognizes the device you can upload music on it...
My Granddaughter has the same problem, but with intermittent problems.
Turned out she went to the beach and had gotten sand into the dial.
I took an air hose and blew around the dial while turning it. It works well now.
Hope that helps.
May 07, 2009 | Samsung YP-U3 MP3 Player
Samsung YP-T6 MP3 player keeps turning off when system loads 100%
I have had the same problem several times. Each time I needed to flash the firmware. Go to Samsung.com support > download center > type in the model number (yp-mt6) click on firmware, and download the version that corresponds with your device. install the firmware updater on your computer, plug in your device. and flash the firmware. (this will erase ALL songs and settings so you will want to back those up first). After that its like brand new. Kepe the updater handy, I fixed this the first time, and it kept reoccuring every few months.
Apr 03, 2009 | Samsung YP-MT6X MP3 Player
I HAVE A SAMSUNG YP-T10JAW AND IT WONT UPDATE
make shure you have full battery before trying to update the player.
Mar 26, 2009 | Samsung YP-T10 Digital Media Player
YP-P2 FIRMWARE PROBLEMS
have u tried the reset pin on the back? give that a go.
Feb 12, 2009 | Samsung YP-P2 Digital Media Player
Occuring the problem when turning on with the title"bulding eror"
Click here for Firmware Update from samsung.com
Here is the instruction for updating the firmware:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port(Hold down the play button while you connect the device, you should seea message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message"Initializing" on YP-U2J Updater, you can now remove your hand fromplay button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUSTdisconnect the Mp3 player and turn it on. You will see a 20% messagefor about 50 seconds and it will be restarted automatically.
Dec 13, 2008 | Samsung YP-U2X Digital Media Player
YP-U2J - Need download - Didn't come with CD
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
CLICK Here to Download : Firmware Update
In case u have WMP 11 and player not working, this error is common after installing Windows Media Player 11
Here is the instruction:
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Jan 27, 2008 | Samsung YP-U2X Digital Media Player
Loading
Hello This is Bill MacLean Billxw@gmail.com. See my earlier post on same problem of dead yp-f and also my reply to member wanting to replace battery. As you can see I had tried pretty well everything when I stumbled on a solution that worked for mine. Follow my directions in other post to remove Battery. Reassemble without
battery and hook up to usb/miniplug to computer.Unit is now powered only by computer usp and the battery is not interfering with
computer now recoginizing the unit. Reformat and reload the O/S
that came with the unit or download the firmware upgrader from Samsung. When you have access transfer some songs and unhook from compuer (remeber o use usb tray icon to stop unit as I think this is what crashed mine) Dissamble unit and replace battery and turn on. E-mail me if this works for yours of if it was a one time fluke with mine.
Regards
Bill MacLean billxw@gmail.com
Jan 20, 2008 | Samsung Yepp YP-F1Z MP3 Player
Cannot use my player-device manager problem/deleting files
This error is common after with Windows Media Player 11
Jan 01, 2008 | Samsung YP-U2X Digital Media Player
My yp-k5 wont upload songs?
What you probably need is a firmware update. Many people seem to have this problem and it is fixed when you update the firmware from 1.03 (the one that comes with it) to 1.05 Here's the link to the firmware update: http://www.samsung.com/tw/support/productsupport/download/FileView.aspx?cttfileid=1536296&type=&typecode=200600&subtype=&subtypecode=200601&cmssubtypecode=&model=YP-K5QB&filetype=FM&language=
Aug 25, 2007 | Samsung YP-K5 MP3 Player
Samsung Yepp YP-F1Z MP3 Player Logo
193 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
