Question about Vacuums
Hi, I have a Simplicity Infinity 36. I just
Hi, I have a Simplicity Infinity 36. I just changed the bag and it was working great. But I cought the end of a bath mat in the roller and now the brush won't work. And the full bag light is on...any ideas?
LizDahl
  • 75 Answers
SOURCE: Roller brush on x5 chipping apart
Not too good, but there are motor problems with these models all the time. Personally I do not know it can be fixed without replacing 3/4 of the machine, which can be pricier than a new higher quality sweeper. I work for a repair shop/ dealer so if you need some assistance let me know.(570)326-1731
Posted on Feb 23, 2008
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Posted on Jun 20, 2008
SOURCE: brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Posted on Jun 04, 2009
susho
  • 18 Answers
SOURCE: Roller brush will not turn on Eureka "The Boss Power Plus" 12 amp
Depending on the model there will be a couple of screws on the top plastic cover. The cover lifts off and the belt is then serviceable. On some models you will need to remove some parts on the bottom too to get the roller out.
In any case just look for screws that hold the covers on and explore a bit. You can't break anything.
Posted on Jul 31, 2009
VacuumRepair
  • 438 Answers
SOURCE: I need a new roller bar or beater brush for
Hi There,
Here's a link to that part on our website if you haven't found it already:
Euro-Pro Shark Infinity NV30, NV31 Bagless Upright Roller Brush Assembly
Also if you need belts for this machine, here's another link to the belts on our website:
Euro-Pro Shark Replacement Belt Set For Shark Infinity Upright Models, Part 1085F
I hope that this information helped you. If it did, please be sure to rate the repair helpful by clicking the thumbs up icon in the top right hand corner of the repair.
Thanks again,
Chris J.
GoVacuum.com
Posted on Apr 14, 2010
Why is the light on switch lighting up but the vacuum wont come on?
It won't work properly if there is a jam or something cought and wound round the roller... even if it's just a lot of string.
Feb 25, 2015 | Oreck XL® Classic Bagged Upright Vacuum
I turn it on and nothing happens,
I would double-check the seating of the bag. Some machines have a lockout switch that keeps you from running the vac with a bag incorrectly installed (which would then suck dirt into the motor).
Mar 16, 2014 | Simplicity Type S Sport Vacuum Cleaner...
My simplicity 7200 does not have vacuum. Air comes out the front post filter area
If air is coming out of the filter air has to be going in through the suction hose but it may be restricted with a clog. Replace the bag and both filters. If it's been over six months since the belt has been changed start by changing the belt. Most of the vacuums brought to my store with the customer stating "it has no suction" actually have great suction but no agitation from the brush roll. If the belt is not turning the brush roll fast enough when vacuuming the carpets it will not even pickup lint and hair.
Oct 28, 2013 | Simplicity 7850 Premier Bagged Canister...
Sentry 3 series vacuum smelled hot, and now will not power up, changed bag (not over full)
There is a reset button on the back of the vacuum that shuts the power off if the motor gets too hot. Try pushing the little white button on the back. If it comes back on that means that there is probably a clog somewhere or the bag was too full.
Aug 10, 2013 | Simplicity Vacuums
I have a simplicity 6 series vacuum. the bag overfilled and vacuum will not run. No power. is there a fuse of relay inside the unit?
no just on /off switch and direct power to vac motor sounds like its burned up from bag being overfilled , now you have to get to the vac motor test it with switch on to see if its getting power if so then motor is burnt.use an ohms meter for power test.
Feb 07, 2010 | Simplicity 7250 Deluxe Vacuum
Hi. I purchased a Simplicity Freedom about 2 years ago. I have had it in for various repairs several times. One persistant problem that the repairman cannot seem to fix is the dirt does not fall down into...
You can let the vacuum run alittle longer so the bag fills up with air, also make sure that the bag in on correctly and you have the right bag for the unit. Let me know if this helps.
Oct 12, 2009 | Simplicity Vacuums
Over heating
TAKE IT TO A DEALER HE WILL HAVE THE PARTS FOR IT
Aug 06, 2008 | Simplicity 7850 Premier Bagged Canister...
Changing the belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=83009&thid=695737
Changing the belt
Posted by cbgolba on Jun 22, 2008
My husband changed the belt on our vacuum, now the metal frame doesn't fit back on the bottom. Also, there is a small metal clip that we don't know where it belongs.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You should check on the owner’s manual to see how it goes together or call the Simplicity customer service line listed below to see what goes where. It’s been awhile since I have worked on a simplicity vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://simplicityvacuums.com/ Customer Service 1-888-9-Simply
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 22, 2008 | Simplicity 7850 Premier Bagged Canister...
Overheated vacuum
It normally won't over heat unless the bag is too full, the filters are clogged, or you have have a clog in the hose or down by the brush roll, the inlet may be clogged. Some will restart after a while, some others have a reset to push. If it won't power on, then you have a problem and it will have to serviced.
Mar 20, 2008 | Simplicity 7850 Premier Bagged Canister...
Vacuums Logo
55 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
