Question about HP 510 Notebook
Hp 510 monitor problem
I have hp 510 when I operated i found that the screen light is very faint,i sent to the maintenance but after a while it returned to its past. Process repeated three times noticed that whenever i leave it for a long time i got the same problem
  • yaman101 Feb 23, 2008
    Thank you but the problem repeated three times is there any other possible reason .
  • 28 Answers
You need to replace the back light in your screen. Depending on the laptop, the back l light can be relatively cheap. It is usually the repair that costs the money. If you decide that you want to replace the back light yourself, you can find a few tutorials just by searching google.
Posted on Feb 22, 2008
After booting, my HP 510 notebook works for a few seconds and then the screen becomes black. Computer still works when connected to external VGA monitor. Can it be processor problem ?
It sounds like you need a new ballast unit for your screen. It cannot be a processor problem as the laptop works OK on another screen. The ballast unit is beneath the screen itself.
Check ebay for a keen priced ballast unit or complete screen.
Hope that helps.
Nov 08, 2010 | HP 510 Notebook
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
Hp Pavilion dv6000 Blank screen. okay So My
Not for the faint hearted but here's the fix.
http://www.youtube.com/watch?v=JEpnqhRYGLw
They do appear to offer a good repair service a well at what seems a good price.
Jul 21, 2010 | HP Pavilion dv6000z Notebook
When I tap on the touch pad on a HP Pavilion dv7 cursor jumps
The touchpad is installed on HP notebook PCs.
You can "tap" and "double tap" your touchpad with your finger, and interact with the operating system in exactly the same way as clicking and double clicking on your mouse.
When using touchpad on your notebook PC, the cursor may jump, flicker, or double-click by itself.
Follow the recommendations in that HP document, or "disable" the TouchPad, if you don't like what it does.
May 12, 2010 | Computers & Internet
My screen is dark, appears like no back light, but everything else still works fine. can faintly see screen
Hello
If you can faintly see the screen I would guess the back lights are like you said....not working.
Can you hook up a external monitor or TV so you can still use it and get your files in order. or until you choose to get it fixed. I would get a couple of estimates first
I also found this video if you want to replace the back light inverter yourself.
http://www.youtube.com/watch?v=UT2GFVem_9U&feature=PlayList&p=70B03BCB27E35519&playnext=1&playnext_from=PL&index=16
Feb 23, 2010 | HP Pavilion dv1000 Notebook
Black screen on booting my Compaq 610 notebook
If it seems like you're accessing the hard drive (drive light comes on, flickers intermittently, then goes off, it's a good chance your screen is bad.
First thing to do is plug in an external monitor and start up the laptop. If it comes up with windows, you know it's the screen.
To find out if it's the backlight, or the lcd, toggle the monitor function and shine a flashlight on a slight angle to the screen. If you can faintly see what was displayed on the external monitor, then the backlight inverter is probably bad.
If the external monitor didn't come up, you're probably looking at a motherboard.
The good thing is that all of those are covered for one year under Compaq's warranty, on a new machine.
If you are able to use the external monitor, back up your data, because HP/Compaq usually reformat the harddrive. Additionally, if you've added memory, pull the cards. They want it sent back the way it came from the factory.
Jan 09, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Black screen on laptop
Call Dell For replacement backlit screen it happened with mite to the DELL
Sep 21, 2009 | Dell Inspiron 1100 Notebook
On bootup screen goes dark or very faint and does not come back
are you able to see windows eventually?you might want to replace the video driversthe correct drivers for this model is r106547.
good luck
Aug 26, 2009 | Dell Inspiron 6000 Notebook
Black screen
take a flashlight and look at the LCD screen and see if there is a faint picture to it. if there is, its a bad backlight.
if no picture you can hook an external monitor to it and switch the mon out to the external. usually this requires a FN key + monitor select function key pressed at the same time.
Aug 06, 2009 | UltraLast FOR HP PAVILION ZE 4000/5000...
HP 510 Notebook Logo
102 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
