My pilot light wont stay lit
I have a propane furnace for a heater and my pilot light wont stay lit i replaced the thermo coupling
  • Heating & Co... Master
  • 2,557 Answers
Hi try cleaning the pilot light out make sure the thermo couple is in the flame,check where the tcouple goes in to the valve nothing stuck in there try this it could be the valve not working
Posted on Feb 08, 2010
  • Paul Carew Feb 08, 2010
My Furnace pilot light will not stay lit
chances are the thermo couple which is a copper wire that comes out of the controller is most likely broken check on that and replacement easy enough to replace and not too costly.
Dec 25, 2014 | Heating & Cooling
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
Pilot light on Tempstar furnace wont stay lit. replaced thermo-couple and it still wont stay lit. what next???
Do you have a good pilot flame? Is it wrapping around the thermocouple good? You may need a new pilot orifice.
Mar 07, 2014 | Heating & Cooling
Propane heater wont stay running
is the sensor for the thermocouple located in the right spot in the flame,remove it and if you have access to a propane torch,heat the end till its red hot and leave it connected to the gas valve,then start the unit and this will tell you if the sensor is properly positioned in the pilot flame on the unit itself,if not you could have a defective new thermocouple or another safety device keeping it from staying lit or the gas valve is faulty
Jul 28, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
I have universal 350,000 propane heater. Fan runs, but switch will not turn on to allow propane to burner.
The thermo coupler is at fault. If pilot won't stay lit thermo coupler keeps gas off. So, Unless it is a bbQ , make sure the pilot is on or the thermocoupler stays hot while the gas is on.
May 25, 2009 | Heating & Cooling
Hayward H250 (millivolt) pilot won't stay lit
make sure the flame hits the thermo couple if so then replace it lows has them in the water heater section thermo couple gets hot makes millivolt signal then opens gas valve
May 08, 2009 | Hayward H Series Millivolt 250,000 Btu...
Wont Stay Lit
I would suggest that you replace the thermo-couple. It is a long, slender copper "wire" that runs from the control unit to inside of the unit. THe thermo couple's job is to regulate the pilot light and the lit flame as well.
They generally cost about $10 and take 10 minutes to replace. Some of them are reversed threaded (rights loosen, lefty tighty) and some of them are regular threaded (righty tighty, lefty loosen). TUrn off the gas supply at the meter or an external valve and remove the thermo couple by unthreading it at the control unit. Bring that with you to the hardware store (lowes or Homedepot) to make finding the correct one a simple task.
I hope this helps.
Apr 24, 2009 | RTO Atwood Water Heater - 6 Gal LP
Heating & Cooling Logo
558 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
