Is all 6 conductor flat wire color coded the same? Also telco wiring is both tabs up where as data cable wiring is one tab up, one tab down. Is this right?
    Scholar:
  • 59 Answers
Can you please describe the problem you are having and what info you want more clearly.
Here are a few good links to wiring standards for Ethernet and Telco wiring:
Good link for basics of Ethernet and Phone
Ethernet Standards
Telco System Standards
Another good Ethernet and Telco jack wiring link
Posted on Feb 07, 2010
What network cable does a belkin N600 use RJ11or RJ12
Look again. Those "RJ11/RJ12" are not 2-pair/3-pair small Telco jacks but rather the 4-pair lager size found in Telco data com circuits (ancient DS0/T1 technology) and commonly now for Ethernet often referred as Local Area Network, LAN, data communications at 10 up to 1000 Mbps.
An RJ45 is larger and can not fit into an RJ11/RJ12 jack. The smaller RJ11/RJ11 will insert and make contact with the inner pins but if the line is active the Belkin device now has/will have a blown port. Don't!
Your Belkin N600 expects one Ethernet cable from a cable or DSL modem into the WAN or Internet port on the Belkin N600 for link through your carrier to Internet.
A four port gang of Ethernet RJ45 plugs is also present and is where your in-house PCs and Ethernet peripherals plug in. On the OEM website usually there is a colored quick setup guide to help you.
Some OEMs designate a yellow Ethernet wire from cable/DSL/satellite modem to WAN port and blue for internal LAN devices to try to reinforce outside verses after the NAT firewall inside the router for your internal LAN. The signal doesn't care about color it's for you.
The internally generated WiFi or WLAN (wireless LAN) is part of the LAN side but allows WiFi radio connection to client devices.
The 4-pair Ethernet cables have 8 conductors wIth the wire end of the plug to you and the contacts held upwards you will note the four pairs and their colors blue, orange, green and brown each with one conductor of the pair white with the color and then the color solid or more correctly the color with white stripe. Signals are on pins (left to right) 1&2, 3&6. On standard cable both ends are the same - a straight through, for hub to client. A cross-over cable takes 1&2 to 3 &6 on the opposite end and vice versa. This was for client to client or hub to hub connections before auto-sensing ports showed up to make the signals swap if needed automatically found in most equipment today. Some cables from OEMs have the correct physical size and pinouts, but only use the 2 signaling pairs. It is best to use these short distances and preferably away from rf noise like in modem to WAN port connections.
The twists per inch in the cable and interweave determines frequency response which defines CAT 3, CAT5, CAT5e and CAT6 level of Ethernet cables. CAT5 is fine else CAT5e/CAT6. CAT3 is generally considered now for telco use only, but can be pressed into into service short haul. (Won't get the 328 ft rated reliably above 10baseT speeds).
You may run across Ethernet with PoE this means on unused pairs a device like a video camera is fed power as well as data connectivity over its Ethernet connection. Follow directions to put power to the correct location as needed and look for any recommended grounding requirements, especially with antennas.
Prices vary widely depending upon bubble packaging and the store overhead generally $6-$12 for about 6 ft or 2 m.
If you want to make your own then RTFM and understand millage may vary until you get the right tools and parts and practice while adhering to standards. I find it more cost effective to use pre-made & tested cables except if failure at an end then I repair followed by testing to re-qualify the cable to not degrade its use.
OBTW - Generally the USB was for single computer use at lower speeds of earlier service speeds below 3-6 Mbps - usually don't.
Aug 27, 2012 | Belkin N600 DB Wireless Dual Band N Router
Rear defroster wire is disconnected. Any ideas how to fix it? Was told to get a flat tab and wire glue. Will this work?
I once tried that with a very small soldering iron after noticing there was a tiny blob of solder on the window conductor. It did not really work well as the heat burned the window conductor somewhat.
So now you can get electrically conductive "wire glue". Here it is in Oz where I am
http://www.jaycar.com.au/productView.asp?ID=NM2831
and Amazon sells it. This stuff also looks good
http://www.mgchemicals.com/products/8331.html
Jan 27, 2012 | 1991 Toyota Camry
D531 powers off when the screen is moved. The screen feels a little loose, so, I suspect a poor connection. Is this a common problem?
Not in any service bulletins I have seen, nor on the internet.
What is common is that the laptop may have been dropped, or an object left inside when the laptop was being closed, or eventually the hinges just wear out.
A loose, or defective hinge will put a strain on connections from the laptop, to the Display Assembly.
Damage, or a loose connection, can occur with the Video Cable.
(Video Cable from motherboard to Display Assembly, and cable to Inverter)
Dell Support > Latitude D531 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/latd531/en/sm/index.htm
Left-click on Display in the list.
Scroll down to the third photo.
Under - 8. Lift the display out of the cover
No.3 - Display cable pull tab - shows the video cable (Display Cable) connection to the motherboard.
See if this connection is tight.
The Display Cable is an FFC.
Flat Flex Cable.
It has NO connector on the end. It is a flat cable composed of individual wires, laid flat next to each other.
Each wire is insulated from the other wires.
The end of the FFC has bare contact pins for each wire.
The connector on the motherboard is a ZIF connector.
Zero Insertion Force.
The FFC is slid into the ZIF connector, in the PROPER alignment, so that the contact pins in the cable, line up with the contacts in the connector.
(OBSERVE which direction the FFC was installed before removing it. Some are installed twisted over one time. It MUST go back the same direction it was originally)
The ZIF connector has a blue Lock Tab.
This lock tab is brought straight up at a 90 degree angle, to unlock the connector, and free the Flat Flex Cable.
In the photo I pointed out above, the blue Lock Tab is in a vertical position. The position for removing the Flat Flex Cable.
Not a loose connection at the motherboard?
Check for obvious signs of damage to the sheath of the Display Cable.
The sheath could have been stretched, which in turn can stretch the wires, and possibly break them, or cause an intermittent connection.
No obvious signs of damage?
Next check the connection on the back of the LCD screen.
Not loose?
Remove the Display Cable.
Use a multimeter, and check each wire for continuity. (Ohms check)
Have a helper gently wiggle the cable, and see if there is an intermittent reading on the multimeter.
(Break in wire/s)
Check connections for tightness to the Inverter.
Report your findings back in a Comment.
Regards,
joecoolvette
Sep 27, 2011 | Dell Latitude D531 Laptop Computer PC...
I'm replacing the existing 3 wire cord with a 4 wire cord on a Maytag LDE312. I assume the green wire goes to the external connection on the chassis, AND ALSO the jumper (aluminum tab) must be removed from...
This is correct. When using a three wire cord, you leave the tab in place and this ties the neutral and ground together.
With a four wire cord arrangement, you remove the tie tab. The white (neutral) wire goes to the middle terminal, and the green goes to the chassis ground. The hot wires will always be the outside leads and connect to the outside terminals.
Best regards, --W/D--
Oct 27, 2009 | Maytag Dryers
Wireing
3-pair version of (red/green, black/yellow, white/blue). But the first two pairs are not twisted
So it becomes green/red, yellow/black, & white-black/blue. G1/ R2 /3Y /4B /5*Blk/6Blue (this is what you physically see on the other RJ11 connections since this is a data connection and not a phone connection it should be a straight-through instead of cross-over connection.
These RJ 11 PINOUT assignments may be incorrect because they apply to a color camera instead of B/W
1 SPEAKER (+)
2 VIDEO_OUT
3 GND
4 SPEAKER (-)
5 AUDIO_OUT/ALARM_OUT
6 12V DC
Back of Camera
Clip up, contacts down
123456
RJ11-e starts off like a RJ45 Stranded Patch Cable.
The color code used in stranded patch cables is different from solid-conductor cables. For NorTel Digital Patch Cable (DPC), the coding is; Pair 1: Green & RedPair 2: Yellow & BlackPair 3: Blue & *Orange White\Black
*In Pair 3 the color coding is Blue & Black instead of Blue & Orange and the pair is twisted so that the Blue wire is the 6th pin instead of the 5th pin.
Jun 27, 2009 | Samsung Weather Resistant Security Camera...
Brother 4070 CDW Drum Unit Error
The green tabs that you have to slide are under the color cartridges, so remove the three color cartridges and you will see three green tabs, to slide the tab across the wire you have to first open the translucent plastic wire cover, then slide the green tab across the wires and return it to it's original position, close the wire covers, replace the color cartridges, and reassemble the printer. All the Best
Jun 11, 2009 | Brother HL-4070CDW Printer
Changing the fuser unit
1 Unplug the power cable.
2 Remove the paper delivery tray assembly
3 Remove two (2) screws from the right cover assembly
4 Remove the right cover assembly, carefully disengaging the catches
5 Unplug the control panel cable.
6 Insert a screwdriver to loosen the release tab on each side of the upper face cover
7 Remove the upper face cover
8 Remove four (4) screws from the upper cover
9 Lift up and remove the face-down cover
10 Remove the output tray by releasing the tabs.
11 Unplug the harness from the fuser motor
12 Open two (2) clips and remove one (1) clip to remove the fuser connector.
13 Unplug two (2) 3-pin optical encoder wires
14 Unplug the red high-voltage bias wire.
15 Remove the thermistor wire.
16 Remove the cables from the wiring harness.
17 Remove three (3) screws from the fuser chassis.
18 Gently rocking if necessary, roll the fuser forward to remove.
Use the following procedure to replace the fuser.
1 Align the fuser tabs with their respective holes.
2 Complete replacement by following steps 1 through 18 above in reverse order.
NOTE When replacing the right cover, align the tabs on the upper edge of the right cover
and lower edge of the face-down cover with their respective slots.
Hope this helps
May 16, 2008 | HP Color LaserJet 2600n Printer
HP 2600 fuser unit
6 Insert a screwdriver to loosen the release tab on each side of the upper face cover.
13 Unplug two (2) 3-pin optical encoder wires.
forward to remove.
May 14, 2008 | HP Color LaserJet 2600n Printer
Excel 2007
default.aspx?assetid=za790050001033Show All default.aspx?assetid=za790050011033Hide All
  1. Select the sheets on which you want to change the gridline color. default.aspx?assetid=za790050001033How?
    When you enter or change data, the changes affect all selected sheets. These changes may replace data on the active sheet and other selected sheets.
    To select Do this A single sheet Click the sheet tab. default.aspx?assetid=za060521711033 If you don't see the tab you want, click the tab scrolling buttons to display the tab, and then click the tab.
    default.aspx?assetid=za060521061033 Two or more adjacent sheets Click the tab for the first sheet, and then hold down SHIFT and click the tab for the last sheet. Two or more nonadjacent sheets Click the tab for the first sheet, and then hold down CTRL and click the tabs for the other sheets. All sheets in a workbook Right-click a sheet tab, and then click Select All Sheets on the shortcut menu (shortcut menu: A menu that shows a list of commands relevant to a particular item. To display a shortcut menu, right-click an item or press SHIFT+F10.). Note If sheet tabs have been color-coded, the sheet tab name will be underlined in a user-specified color when selected. If the sheet tab is displayed with a background color, the sheet has not been selected.
    default.aspx?assetid=za790050001033Cancel a selection of multiple sheets
    To cancel a selection of multiple sheets in a workbook, click any unselected sheet.
    If no unselected sheet is visible, right-click the tab of a selected sheet. Then click Ungroup Sheets on the shortcut menu.
  2. On the Tools menu, click Options, and then click the View tab.
  3. Under Window options, click the color you want in the Color box. To use the default gridline color, click Automatic.
Jan 18, 2008 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
