Question about Vehicle Parts & Accessories
Need a manuael to install remote car starter can you give advise?
  • 171 Answers
My advice is if you don?t know about car electronics you better leave it to the experts some times is better to pay, but if you?ll like to try it we need the car Make/Model/Year
Posted on Feb 08, 2010
I have a romote starter in my 2006 Sonata...battery died had use jumper cables and then sarter stopped working. Is thea way to reset them ? It was not factory installed thank you
Sounds like a job for the company that installed the remote starter. As we all know there is only 1 company that makes remote car starters, but i do not remember what it is and you aint giving up the information. Try the installer of the remote.
Apr 14, 2014 | 2006 Hyundai Sonata
Remote start reset
Sounds like a job for the company that installed the remote starter. As we all know there is only 1 company that makes remote car starters, but i do not remember what it is and you aint giving up the information. Try the installer of the remote. They can see it and answer you.
I want codes to set up my remote. I have lost my manuael.
Try to Google the model number with "manual" to see if you can locate one.
Dec 04, 2012 | Televison & Video
Have an 08 Kia Sorento. Had an after market remote starter installed a year ago. In this past light the check engine light has been coming on. Codes have shown an Oil Control Valve problem (replaced) and a...
yes its often that dealers will advise that if car starter installed there is no gurentee as well the car if its finish with the gurentee the tech line advises the mechanics to remove any after market devices installed to repair the original system but most of the time the starter is not the problem but it eliminates it sometimes the car starter has extra features that cause problems in the startingcircuit for example when the car starter installed the main wire is put it between the starter and ignition so if the wire is cut to far this causes a lost between the ignition switch and the starter or the module can be damaged and the same thing apears and so on
Mar 30, 2011 | Kia Sorento LX Cars & Trucks
Added remote starter on vw jetta 2004
No, this is not correct, did you have to give up a key, or did he use a bypass module, either way, you can check next time it won't start by putting your key into the ignition and leaving it in the off position, then try to remote start it, if it starts then your installer needs to reposition the transponder loop around the ign switch or reposition the "key in the box"
Jan 30, 2010 | Bulldog Remote Starter & T-Harness Kit for...
Need to replace starter
Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Disconnect battery negative remote cable from remote ground post.
  3. Raise and safely support the vehicle
Starter Motor
    1. Remove or disconnect the following:
    2. Three bolts attaching starter to engine
    • Positive battery cable from starter
    • Starter assembly from transmission housing
    1. Position jack stand beneath engine and slightly lift to relieve pressure from left engine mount.
    2. Remove three left engine mount bolts from engine block.
    3. Jack engine up slightly to give more room to maneuver starter assembly.
    4. Slide rear of starter motor out between catalytic converter and engine mount.
    2. Posi-lock starter solenoid connector.
    • Starter from vehicle.
    To Install:
    1. Install or connect the following:
      • Positive battery cable to starter
      • Posi-lock starter solenoid connector
    2. Jack engine up slightly to give more room to maneuver starter assembly.
    3. Install or connect the following:
      • Starter
        1. Torque to 40 ft. lbs. (54 Nm)
      • Three left engine mount mounting bolts to engine block
    4. Lower vehicle.
    5. Connect the battery negative cable.
  • May 05, 2009 | 1998 Chrysler Concorde
    Remote starter on a 2004 Accord with V6 engine
    remote starter is designed to shut down the vehicle if there is no key to drive with. This is a security feature so that unauthorzed drivers cannot steal it. to answer second question the purpose of remote starters is to allow you to heat up the vehicle so it is an ice cube when you are ready to drive. Not sure what remote I cannot answer the horn question. Need more on what remote starter you have model number and make
    Apr 20, 2009 | 2004 Honda Accord
    Cutting a duplicate key for a 2004 Accord
    you will need to get a spare key from a Honda dealer you will need to give them the VIN of the car
    if you get just a spare key cut all it will do is unlock the door :(
    Apr 19, 2009 | 2004 Honda Accord
    Install remote engine starter.
    yes they may have them also I know Meijers in Michigan does carry them and they come with a video/dvd on how to install
    Jan 25, 2009 | 2003 Volkswagen Passat
    Parking lights will not come on when I use the remote starter
    Most alarm installers use in line connectors or crimp-on connectors. If you can identify these connections looking under the dash, you will have to give it a little twist. Usually this allows it to make contact again.
    Jan 11, 2009 | Viper Security and Remote Start System...
    Vehicle Parts & Accessories Logo
    104 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
