Question about Dryers
I need to run my Whirlpool gas dryer through 2
I need to run my Whirlpool gas dryer through 2 cycles in order to completely dry a load of towels. Any hints as to what can be causing the unit to run cooler
  • 572 Answers
Chech ur vent. blockage
Posted on Feb 07, 2010
Dryer not heating enought
The first thing you need to do is make sure your dryer vent hose is clean. An easy test (if you have a really long dryer vent run) is to unhook your dryer vent hose from the back of the dryer and just dry a load of towels like you normally would. If your towels are nice and dry when the cycle is complete, then you know your dryer hose vent is clogged somewhere down the line.
Oct 13, 2014 | Maytag Dryers
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
LGR7647 will dry fine but smells like gass only when it runs.
make sure the air shutter on the gas nozzle isnt completely blocked or changed positions as the flame needs oxygen to make combustion complete otherwise the gas wont burn completely and you will get a black smoke that smells like raw gas
Dec 06, 2012 | Dryers
Clothes not drying completely; takes about 5 cycles to get them dry. Was previously drying completely with one cycle. I believe I need a new heating element and would like assistance on getting...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 20, 2011 | Whirlpool Dryers
Dryer not heating very hot. need to run two cycles to dry
Dryer is not drying properly, In order to resolve try following things.
  • Check the exhaust hood outside the house, does it open and close freely, Clean the lint filter and exhaust duct.
  • Do not overload, 1 wash load = 1 dryer load. Sort heavy items from lightweight items.
  • Large, bulky items like blankets or comforters may require repositioning to ensure even drying.
  • Check the washer to be sure it is draining properly to extract water from the load.
  • Clothes load is too small to tumble properly. Add a few towels.
I hope this will solve your problem.
Good luck and have a nice day.
Jul 04, 2010 | Frigidaire GLGQ332A Gas Dryer
Doesn't dry clothes. New Just installed 11/16. Took 2 hours to dry a load of towels. It is a gas dryer. WGW 9450
Check vent out is clear blowing air / check clean all filters, the fact thats its new should not be anything too serious..Good luck
Nov 17, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Loads have to run through high heat cycle twice to get completely dry. It was drying completely with one run through any cycle.
have you checked your wall vent hole and dryer vent hole to make sure they are clear?if there not it will keep the hot wet air from coming out and take forever to dry,let me know-mike
Apr 14, 2009 | Whirlpool LER4634J Electric Dryer
Gas dryer runs, cleaned hose, get warm does not heat up to dry
with a gas dryer in which your assured te hventing is free and clear of any obstructions, i would look to replace the coil pack located atop the gas valve itself, probably about $25 part number 279834... 2 coils simply mount atop the valvle
Feb 11, 2009 | Whirlpool Dryers
Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Sep 07, 2007 | Whirlpool GEQ9858J Dryer
Dryers Logo
Top Dryers Experts
