Question about Maytag SkyBox MBV1976A Beverage Dispenser
Broken hinge how do I get inside door to try to fix/replace?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Lots and lots of screws. You need to remove the entire inner surface of the door. Not a lot of fun. But it does come apart.
Posted on Mar 10, 2010
How do I repair/replace a broken door?
Hello there, you will need a new hinge and probably the inside round piece of the door. Can you upload a photo? Please indicate the
E-Nr of the machine. You can find it on the label around the door and/or at the back of machine.
Jul 02, 2015 | Bosch Washing Machines
How do I replace the bottom socket where the door hinge slides in
I assume you mean the hinge that is on the cabinet and not the door? If its the door part that has failed, you will need to get a new door. If its the cabinet hinge, some of these are screwed onto the cabinet from underneath the fridge. Others however, are mounted inside the cabinet and are not really designed for replacement. Ive fixed a few over the years on different brands where the plastic hinge has broken but it can be a bit messy. The cabinet needs to be carefully peeled or bent back on the bottom corner of the fridge to access where the hinge is mounted. Unscrew the hinge and if you are lucky, the Manufacturer has these as a spare part. If not, the only way is to go to a hardware or cabinet parts store to try and source something that will suffice. Do NOT be tempted to put a normal gate or door hinge onto the fridge door and screw it onto the cabinet. Inside the cabinet especially around the edges are whats called "mullion heater" pipes or in older fridges, mullion elements. If you screw through a pipe, you will lose the gas and fridge will be shot. If you screw through an electrical mullion heater, there is a danger of electrocution.
Dec 23, 2014 | Dometic RM2852 Refrigerator
Oven door will not close the whole way
Your oven door hinges(s) are broken, the springs that hold the door closed inside the hinges are either weakened or their mounting points have become worn.
You need to purchase a pair or replacement hinges which you can fit yourself if you have some basic mechanical skill. Don't try to just replace one side if you determine which side has failed as the extra strain put on the old hinge can cause the door to twist and break the door.
Mar 05, 2012 | Tappan Kitchen Range
2001 grand prix..fuel door hinge is broken.how do you get at the hinge on the fuel door.?
I just fixed mine the other day. Take off all the screws you see inside the fuel door (You will need a #15 torx screwdriver and a small socket set). Then you have to drill out the 2 rivets (one on top, and one below the hinge.
You should be able to remove the door and hinge assembly now.
I think you will find that the hinge pins have rusted out. I replace mine with the shafts of drill bits. You will not be able to cut the drill bits, but if you put them in a vice you can break them off at the appropriate length with a hammer, just watch your eyes :-)
Then re-install, and re-rivet.
If you have any questions e-mail me rstbc at hotmail.
Cheers
Mar 03, 2010 | 2001 Pontiac Grand Prix
Door hinge on hygena single electric oven broken
You neede to replace both door hinges.
To get more detailed instructions on how to do this, go to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR HINGES.
You should then click on the appropiate link, and follow the instructions.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Ovens
Really Up Sh/t Creek With Fridge Door Hinge (broken bolt)
Put 2 lock washers under the remaining 2 screws and dont over tighten.
This should hold the door fine just do not over load the door.
Go to the hardware store and get 2 new hardened screws if you think you damaged the remaining 2 screws.
If they dont have any that will fit try an auto parts store.
Jan 05, 2010 | LG LBC22518 Bottom Freezer Refrigerator
The hinge of the washing machine has broken - Creda W100FW
The door hinge block has fallen inside the front of the washer.To retieve it, tilt the washer back, and you should find it at the left hand side.
Remove all screws securing 2 parts of door together, prise apart with a screwdriver or similar, and the door will come apart.
You can now access the hinge and all other partsd inside the door.
Trust this helps.
Thankyou.
Nov 28, 2009 | Creda W100FW Front Load Washer
The piece that connects the vertical hinge to the door is broken.
Try partsdirect.com they have one of the best parts resources available. you will need your complete model number off of the inside of the unit it is located either on the eiling or right hand wall of the refrig section. thx Peyton
Mar 16, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag SkyBox MBV1976A Beverage Dispenser Logo
112 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
