Question about Nokia 6220 classic Smartphone
The keypad wont unlock, i have tried turning it on and off by taking the battery out, it still comes up locked.
  • 107 Answers
The keyboard it's probably damaged
Posted on Feb 08, 2010
I can't unlock my vteck 15300 dect6.0 cordless pH handset help
I guess you mean the Keypad Lock/Unlock!
You can turn on the keypad lock of a handset.
In idle mode, press * button and then LOCK to turn on the keypad lock. "PRESS UNLOCK TO USE KEYS" is displayed on the LCD.
In keypad lock mode, press UNLOCK to turn off the keypad lock.
Aug 27, 2016 | Lands Phones
Schlage BE365 - How do I remove the key? It will lock/unlock door but cannot be removed from lock.
Recommend resetting the lock back to factory settings and try reprogramming. Also if you don't hold the latch while turning the key to lock/unlock the door it may not be recognizing the keys inserted and this will keep the key in place. Try that before resetting to factory just make sure you hold latch and turn key until it wont turn anymore.
Dec 01, 2013 | Schlage Camelot Deadbolt Keypad, Satin...
How do i un freeze my nokia twist
  1. Make sure that the keys are actually locked. If you attempt to unlock a keypad that is not locked, nothing will happen. Look on the phone's screen for the key icon that indicates the keypad is locked. If you try to press any of the keys and the word "Unlock" appears on the screen, your keypad is definitely locked. If you do not see the indicator but are unable to use the keypad of your Nokia 6085, your battery could be dead, so try recharging it and then see if the keypad works.
  2. Enter the unlock sequence. If the key indicator appears on your screen, you need to enter a simple sequence of keys to get the keypad working again. For the Nokia 6085, select Unlock and then quickly press the * key. If you wait more than 1.5 seconds to press the * key after selecting Unlock, it will not unfreeze the keys so make sure you enter the sequence very quickly.
  3. Turn off the automatic keyguard. If you are tired of having to unfreeze the keys every time you want to make a call, you can program the Nokia 6085 to always remain unlocked. In the menu, go to Settings, then select Phone, then select Automatic Keyguard and choose Off.
Mar 01, 2012 | Nokia Cell Phones
After locking my car, the interior lights dim and go out as usual and then come back on and the doors will keep locking themselves.
The problem is in the keypad assembly. It causes the interior lights to come on and off and can drain the battery. This also causes the doors to lock and unlock without driver input. The keypads on this model usually go out if someone is playing with it or trying to discover the unlock combination. If you don't need to use the keypad for entry or access to the trunk you can disconnect the keypad and you won't experience the above mentioned problems.
Mar 10, 2011 | 2000 Lincoln Continental
My nokia E71 cannot be unlocked. the keypad wont function. After several periods of turning on anf off, the displays is " continue using phone in offline mode? hoe can i select the answer between yes or...
had the same problem... remove the battery for an extended period of time and try again. unfortunately for me the phones screen now refuses to turn on, the keyboard woks now but the screen is completely black- best of luck with yours
Aug 22, 2010 | Nokia E71 Smartphone
I have a nokia 6500s-1 slide phone and my 3 yr old daughter pressed something while she had it, and now i'm locked out of the phone, tried all I can to no avail. Can't give you an IMEI number as the phone...
It seems that the keypad is locked. Does your poweron? If yes then press the poweron switch and you will find an option LOCK KEYPAD or UNLOCK KEYPAD. If it is the earlier then your keypad is free. If the later then select Unlock option and free up your keypad. If former then your there is no way that you can unlock your phone except re-installing the firmware. The IMEI number is below the battery. But, it will not help despite everyone asking for a SW generated password. get the firmware re-installed. It takes about half an hour.
Aug 12, 2009 | Cell Phones
Can not unlock keypad on lg envy
dial *22899, press send, allow the phone to program completely. it will shut off on its own and when you turn it back on, the lock code will be set to the last 4 digits of your phone number!
Jan 14, 2009 | LG enV VX9900 Cellular Phone
Locked cell phone keypad
first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
if that doesn't work then try this from the website.
How do I lock/unlock the phone's keypad? To lock and unlock your phone's keypad, press and hold the left navigation key.
Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK button. You can set your phone to lock the keypad immediately, or automatically if no key is pressed after 30 seconds, 1 minute, or 5 minutes.
To unlock the keypad: Press 1-2-3 in that order."
good luck!
Apr 15, 2008 | Kyocera K10 Royale Cellular Phone
Can't unlock keypad
The default security code for Nokia is 12345.
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Apr 03, 2008 | Nokia 6300 Cellular Phone
Nokia 6220 classic Smartphone Logo
105 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
