Question about Panasonic CT-27D30 27" TV
My panasonic CT-27D30 tv has white color scan lines on top of tv
My panasonic CT-27D30 tv has white color horizontal scan lines about 2 inches wide on the top of screen, and as time going the lines become less to half inches wide. Please tell me the reason and how to fix it. Thanks.
4 Suggested Answers
  • 556 Answers
SOURCE: Panasonic CT-36G24A Horazontal Hold
  • your problem is in the vertical output section as you have already mentioned that compressed down to 3 inch
  • if is is some times then you will have to check
  • loose contact in electrolytic capacitor in vertical output section
  •  it will be dry or some print cut must be there.you solder it.
  • it is best thing to replace all electrolytic capacitors in vertical output stage.they are hardly two or three.
  • it is a common failure,& not a major problem.
  • as per location of the suspect is concern it in the section from where the wires are going to crt neck.
  • hope this will help
  • good luck
Posted on Oct 19, 2007
SOURCE: Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Posted on Apr 19, 2008
SOURCE: Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Posted on May 23, 2010
I have a old tv 36 inch panasonic ct-36d30 my tv
sound like yoke short problem. replace same yoke as possible . good luck!
Feb 15, 2010 | Panasonic CT-36D32 36" TV
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Have slide picture on top.5"after a minutes stop at 2"
check for dry electrolitic capacitors around the vertical output section
Oct 02, 2008 | Panasonic CT-27G14 27" TV
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Horizontal lines center of Panasonic HDTV
Usually there is a capacitor in the pump up circuit and/or an IC in the vertical circuit that causes this problem. Contact Panasonic at: http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001 To find a servicer in your area. This will give you an idea of the cost of repair. Hope this helps.
Jun 02, 2007 | Panasonic CT-27HL14 27" TV
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
Pixel color fade
You are about reade to have a scan ic failure.Try to get it to a repair center asap.Have them replace the top 2 scan ic's
Jan 28, 2007 | Pioneer PureVision PDP-5030HD 50 in....
Panasonic CT-27D30 27" TV Logo
95 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
