Question about Fujitsu Plasmavision 42" TV
Power won't stay on. I get picture, and then it goes blank and red light blinks. When I unplug power, it will go on for a few seconds and then red light blinks. HELP!!!! Thanks
  • jmnecap Feb 07, 2010
    Seriously? This is a hardware problem and not just buttons that were pushed in the wrong sequence?
  • 11,896 Answers
You have the all too common power supply/high-voltage transformer problem. It is VERY common in todays' electronics to due parts being made cheaper. I have replaced several of these in the last two years with same problem. There is only enough power to power up the little light but that's it.
The old one will have to be unplugged and soldered off and new one soldered back on. You can likely get one at partstore.com or shopjimmy.com or tigerdirect.com
Posted on Feb 07, 2010
  • Nate Stansfield
    Nate Stansfield Feb 07, 2010
    If buttons where pushed wrong your tv would most likely be in locked position and wouldn't let you do anything. But you would still have a picture.
My Sony tv won't power on its goes on then stays blinking on standby 14 blinks on red
Try unpluging the tv for several minutes and then plug it back in and turn it on and see if that helps
May 22, 2015 | Sony Televison & Video
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Turn on the TV, red light stays on, picture goes blank after a second.
I have the same problem. Factory reset did not help (hold Vol-minus on set and menu on remote five seconds, then unplug). Can there be something in service mode that would help?
Aug 04, 2012 | Panasonic Viera TH-50PX80U Plasma TV
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
After turning on, the picture is displayed for a fraction of second and goes blank. If power off and on, it does the same again. I tried unplugging the power cable, didn't help.
Count the number of times the red light on the front panel blinks in succession - this is the trouble code that pinpoints the problem area.
May 25, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv won't come one and blinks red 7 times then stops.
When the bottom half of the picture goes out this usually indicates a failure of the lower Y driver module. When this module fails it will often take out the Y sustain module and when that happens the set goes into over current shut down. Both boards will have to be replaced. All of this is assuming you have a Plasma set and not a LCD flat panel.
Jun 02, 2009 | Philips Televison & Video
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Fujitsu Plasmavision 42" TV Logo
98 people viewed this question
Top Fujitsu Televison & Video Experts
Tony
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
