What is the syncing process for a logiteck wireless mouse
  • 415 Answers
Take your wireless receiver that is connected to your computer and turn it over. There should be a red button. Press it once (propably a led light will start flashing). After you do that, take your wireless mouse and do the same. Turn it over and press the red sync button.
Your mouse should now be synced.
Posted on Feb 07, 2010
Belkin wireless mouse won't connect on power up of PC
A Belkin Mini Wireless Optical Mouse frees you from the restriction imposed by the limit of the wire that your mouse uses to connect to your computer. The Belkin model works up to three feet away from the receiver and operates on a 27 MHz frequency. It's smaller than a regular mouse, making it easy to add it to a laptop case or desk drawer without losing much space in the process. Before you can use the Belkin Mini Wireless Optical mouse, you must install it. The receiver and the mouse should sync automatically; if they don't, you must perform the sync manually.
1 Press the bottom release tab on the top cover of the mouse. Insert the batteries included in the package and replace the cover.
2 Turn on your computer. Plug the Belkin USB receiver into a USB port on your computer. The drivers will install automatically.
3 Press the sync button on top of the USB receiver and then press the sync button on the bottom of the mouse to connect the two devices.
Warning
  • close Before you can install the Belkin mouse, remove drivers for other wireless mouse types on your computer.
Jul 17, 2017 | Belkin Mini Wireless Optical Mouse...
How do I sync a microsoft explorer mini mouse
Install the driver for the mouse and this will ensure connection between the computer and the mouse. Often the installation process should be automatic and other times, it is not.
Nov 14, 2012 | Dell Wireless Keyboard Optical Mouse w0147
How do i get my wireless technika mouse wm110pk to connect to my laptop?
Insert the USB dongle that came with your technika wireless mouse into a USB computer port on your machine.
This dongle, which resembles a regular flash drive in appearance, can be plugged into any available USB port.
Once inserted, it immediately turns on.
Insert the required amount of batteries (typically two AA batteries, though it changes depending on the model) into the compartment on the bottom of your HP wireless mouse.
Flip the "ON" switch on the bottom of your technika wireless mouse.
Press the "Sync" button on the bottom of your technika wireless mouse.
The mouse will now sync with your computer and will be immediately usable.
hope this helps
i have read some good and bad reviews on this mouse one stated the wireles stopped working several times and it had to be replaced
Oct 12, 2012 | Computers & Internet
Had to change the batteries but now the mouse will not work. I'm not sure if I need to sync the device, if so I'm not sure of the process
Look for a small button on the bottom of the mouse and also one on the receiver. Push the one on the receiver first and then on the mouse. That should get you going again.
Thanks for using Fixya.
Nov 25, 2010 | GE Wireless Optical Mouse
Cant get my wireless mouse to work
1. Press the sync button on the reciever (the only button on the reciever)
2. When the light blinks, press the sync button on the mouse (the button you are talking about on the mouse is a sync button, not a reset button, there is no reset button on the mouse), after you press the sync button on the mouse, the blinking will stop and will remain steady
Please post your feedback and Vote if the proble resolved as per your satisfaction.
Aug 17, 2010 | HP Wireless Optical Mouse
Mouse works but keyboard does not.
Ironically, when I replaced my dead HP Pavilion, on which I had the same wireless keyboard and mouse, things worked in the reverse but opposite method. The mouse doesn't work, but the keyboard does.
I suspect it is directly related to the config buttons on the bottom of each part. The buttons were supposed to sync such that the keyboard and mouse worked together perfectly and did, until I had to replace the PC.
My only suggestion is to continue to press those little buttons repeatedly, until they finally do sync all the way around. And most important, ensure that your mouse and keyboard have fresh batteries at all times, as that would make the whole process fail in the most embarrassing way.
Good luck,
-a.
Jul 06, 2010 | Microsoft Wireless Desktop 3000 Keyboard
My mouse does not want to work , theres power but doesnt work
This is kind of hard to diagnose without more information but i can try to help you out. Has the mouse ever worked? If the mouse was working fine and just quit working then you most likly will need to change the batteries. Once you change the batteries you will have to then re-sync the mouse with the usb device the plugs into the computer. Its usually just as simply as hitting the button the the usb device (adapter that connects to the computer) and then hitting the button on the bottom of the mouse (usually on the bottom) if this is the first time you are installing the device usually u put batteries in the mouse. Then you do the same sync process above. I hope this helps
Thanks
Steven.
Apr 21, 2010 | Targus Wireless Optical Notebook Mouse...
I need to connect my mouse
There should be a tiny sync button on the mouse and the USB receiver that connects to your computer. Make sure your computer is on and loaded, then connect the USB receiver, and make sure the batteries are functional in the mouse. Once it's set up, simply press the sync button on the receiver, then press the sync button on the mouse and wait for it to sync up.
If your wireless adapter is bluetooth, you'll have to install the software that came with your mouse, and use the software to synch the mouse.
May 05, 2009 | Dynex Wireless Optical Mouse
Mouse not functioning
You should have a USB adapter that goes from the Charging base to your computer to make the connection. the wireless is from the base (charging unit) to the mouse.  once you connect your USB it should find the mouse and work. you may need to sync the base unit and mouse to complete the process, by first click the sync button on the base unit then the small sync button found on the bottom of the mouse
Oct 12, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
