Question about GE Refrigerators
I have a 1956 ge wall mounted refrigerator. i need to know how to remove it.
I have the same refrigerator i took form my Aunts house. What you need to do is remove the cover and unplug it first, then remove the doors to help with the weight. I then used my car hack and some 2x4s to lift the unit only about 1" it is suspended by a metal bar near the top it takes two people to let it down.
Is it in working order and what color is it?
RJ
rjh_1961@yahoo.com
Posted on Feb 08, 2010
  • belvair Jan 30, 2011
    I have this same fridge, and love it, but it looks like it may have a leak, not cooling in the ref. compartment, but is cooling in the freezer- and the compressor is working. Any idea on a qualified repair person in the Detroit area? Thanks, Jeff Belvair@hotmail.com
How do i remove back panel inside the freezer on a ge profile
I am guess the "-" is really a "a" as you listed in your model#.
This is actually built by LG and stamped GE on the front. So there are two ways you can do this.. The first is to remove the door from the rails, then all the racks, then the rack guides,then the icemaker, then the back wall, then you can use hot water to melt the ice out of the trough (do not use a heat gun because the plastic liner will melt quite easily and be very careful as everything is pretty sharp behind there)
The easier way is to take off the back panel (you would have to do this anyway) and make sure the little black flapper on the bottom of the drain is not all gummed up with lint,pet fur,ect.. Then defrost the unit for 24 hours, unplugged and doors open.
Of course you will need to move your food but your finger,back and knees will thank you!
These tend to clog here anyway and digging the ice out from the inside is a severe pain! Do not cheat the 24 hours and leave the doors open!
Feb 12, 2018 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
I have a GE side by side fridge Mod. psh23pss-sv that is showing 42 degrees on the fridge section and -2 in the freezer. No frost in the evaporator. Fan is working. Condenser is clean. Temp selection is...
check the damper assy in the upper left corner of the refrige compartment you need to remove all the plastic parts on the roof and back walls to access this part there are 2 possibilities either the fan inside this assy quit or there is a door inside here that opens and closes to throttle cold air in from the freezer compartment,a lot of times this doors mounting breaks from cold and can stick shut or wherever position it breaks in,remove it and then run the diagnostics and watch this door for operation as you enter the diagnostics,also make sure the fan in there works also,if both of these work ok then you could have a thermistor problem in one or more of the thermistors mounted in the left and right side walls midway up behind oval plastic grilles
Apr 30, 2011 | GE PSH23PSSSV Side by Side Refrigerator
GE model 25 - 6 years old - Top part of fridge and freezer not cooling. compressor seems to be working fine. Bottom part of freezer is very cold and bottom part of fridge is freezing everything. Appears to...
It sounds like the damper assembly might have failed or be stuck open. The damper is mounted in the left side upper rear corner of the refrigerator section. The damper controls the amount of cold air that comes into the refrigerator section from the freezer.
If you want to repair the refrigerator yourself you should disconnect the power to the refrigerator and remove the 2 screws holding the damper cover to the center wall. Sometimes you can spray the damper with WD40 and free it up.
Jan 30, 2011 | GE Profile PSW26P Stainless Steel Side by...
The refrigerator is not cooling MTB 1956 GE
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
n
Sep 17, 2010 | Maytag MTB1956G Top Freezer Refrigerator
Freezer not cold and guide fan barely spinning
Do you see frost building on the back freezer wall? It could be a failed defrosting has plugged up the evaporator. You need to access the service panel and have a looksee. BOTTOM MOUNT SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 03, 2010 | GE Profile Stainless Bottom-Freezer...
Aqua GE Wall Oven SN10729 (Can't find a part number) 1950's-60''s
from the serial # it was made in september the second letter N is either 1956 or 1972.
take a look at this site it'll lead you to ge heating elements
see if there is one that resembles your's.
then call them. they are very helpful and may be able to tell you where the model # is. ask if what you're seeing might fit.
here's the link...
http://www.appliancepartspros.com/ge-wall-oven-heating-element.html
Hope this helps a little.
Happy New year
Jan 02, 2018 | GE Ovens
Where is the defrost timer on a ge gsh 25kgbb
Good day,
There is no ordinary defrost timer on your machine.
The defrost cycles are performed by an electronic board mounted on the rear of the machine (under a cover) and are controlled by thermistors mounted in the freezer compartment behind the rear wall panel.
Dec 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The entire backwall of the unit is solid ice. 2
OK first defrost the refrigerator. Unplug and remove the back panel covering the evaporator and lets look at the defrost element and defrost thermostat. If they are OK we may need to have a look at mother board mounted on back of fridg. Let me know when you are ready, Sea Breeze
Apr 22, 2009 | GE Profile PDS22SCRL Stainless Steel...
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
Refrigerators Logo
291 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
