Question about Tomtom ONE GPS Receiver
140-S keeps freezing up - Tomtom ONE GPS Receiver
  • 518 Answers
Hello my friend, your problem maybe due to application not installed right, get on your computer double click on tomtom home icon, hoping you have the maps copied to your computer, reset your device by inserting a clip or small object into the reset hole for around 15 seconds, then switch on your device and connect to your computer which then should ask if you want to connect, click yes and the programme should check for updates, in the device part of your programme highlight the map and click delete or remove, but only if you have the maps on the my computer part of the programme, Once removed, click on my computer in the programme tick the map you want to install and then click copy to device, this may take some time
Posted on Feb 08, 2010
My sound leasur jukebox has stoped working it wont sleced cds just keeps saying 140 01
The lazer is shot in it, It isn,t reading the info off the disc any more, Verry costly repair.
Oct 27, 2012 | Audio Players & Recorders
HITACHI AXM 140 SYSTEM
Try to reset the system.For reset procedure,click the link below :-----http://technoanswers.blogspot.com/2012/01/hitachi-ax-m140-system-display-keeps.html
---------This will help.Thanks.
Jan 27, 2012 | Audio Players & Recorders
My machine keeps freezing on me. It will work if I leave it off for about 10 min. but only for a few min. and then stops working again. I have to turn it off for 10 min. again before it works...
If the handwheel is tight and difficult to turn, then there is a bind somewhere. Could be debris in the hook raceway, thread caught in the take-up crank or a shaft bushing failure. Consult your instruction book for directions on how to clean out the hook area. If cleaning the hook area doesn't help, take it to your repair person. The more you use it in this condition, the worse it could become.
Jul 14, 2011 | Bernina Activa 140
Engine surges when airconditioning is on Harness pack was replaced & tune up was performed
This is a common complaint from 4 cylinder owners. Your car makes 140 hp at most (depending on which 4 cylinder you have) and the a/c compressor can take anywhere from 15 to 25 hp to operate. I'm sure you can see why you feel that compressor kick on and off. Compressors don't run constantly when you have the a/c on. If they did, they would freeze. Instead, they cycle on and off to keep the right temperature. What you feel is the a/c compressor cycling on and off.
Jun 30, 2011 | 2002 Pontiac Sunfire
My xbox 360 freezes up when I start it up and continously keeps unfreezing and freezing again
I've encountered this problem before. start studying or get ready to fork over $140 to M$ (unless its still under warranty). This normally means you console is about to RROD; your gpu is losing the connection with the mobo.
Jan 12, 2011 | Microsoft Xbox 360 Console
The ratio of Ann's money to Rosa's money is 4:7,If Rosa has 60 pesos more than Ann,How much money that each girl have?
Ann has 80 pesos and Rosa Has 140 pesos. Calculated by taking the 4 to 7 ratio and keep multiplying until you reach the 60 pesos difference which is 4X20=80 and 7X20=140. 140 minus 80 = 60.
Nov 07, 2010 | Computers & Internet
Appears to go into an extended defrost cycle.
Sounds like your freezer has a bad defrost thermostat ( bimetal ) or bad #4 and/or #5 thermistor . This bimetal , has a high temp rating of 140 degrees , which means , when it gets to 140 behind the panel , it will cut off the defrost heater , to keep ice and food from thawing . The thermistors , tell the main control board the temps , and it decides when to restart the cooling process . I would check the thermistors by the digital controls , in the test mode , or have a technician check them for you .
Sep 12, 2009 | GE Refrigerators
What temp should the fridge and freezer each be?
According to FDA safetey specs bacteria can grow at 40 to 140 F degrees .Refrigeration must be below this number but above 32F to keep from freezing. I maintain commercial refrigeration and they run at 34 to 38 F degrees. I have deep freeze set at -10F which keeps ice cream very solid but can go up to +2 F which renders softer ice cream...
Jun 25, 2009 | Kenmore 64802 Top Freezer Refrigerator
Freezer not freezing like it should
Yes that is hte panel in which "skeeter 140 " was refering
Jan 14, 2009 | Frigidaire FRT18FS6C Top Freezer...
Tomtom ONE GPS Receiver Logo
77 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
