Question about HP Compaq Presario V2000 Notebook
Laptop screen went black
Sir my laptop does not start . when i pressed power button it light glows but nothing on screen. what happen to my notebook. please tell me. thankx.
  • 3 Answers
It sound like one of two things has happened.
A - Your LCD panel has gone bad, which will require you to replace it. You can usually find LCD screens on Ebay for a good price. Installing one is not as hard as you may think.
B - The connector that plugs into your notebook motherboard has become dislodged. You can take the facing off of your notebook and check that connector. I've had two Dell notebooks that had the same problem. Over time, the connectors worked themselves loose.
Please be sure and obtain a service manul for your notebook BEFORE attempting to take the facing and keyboard overlay off. It will provide you with detailed instructions on how to do so. If you will give me the exact model number, I may be able to find the service manual for you.
Brent Cannon
The Computer Techs, LLC
Brinkley, AR 72021
Posted on Feb 22, 2008
We have a Compaq CQ61 and my son turned it off and back on and the screen is black. We tried the brightness, turning it off and on again and nothing is working
You can try the following steps,
  • Turn off the notebook
  • Disconnect the power cable
  • Take out the battery
  • Press the power button for 15 secs (to drain out static electricity)
  • Connect the battery back on the notebook
  • Connect the power cable
  • Turn on the notebook
Note: You may also check if the light on adapter is on (if there is any) and the light where the power cable connects to the notebook is glowing. If the light is not glowing it is the adapter which went back.
Regards,
Shrey
Jun 04, 2011 | Compaq Presario CQ60-204NR Notebook
No screen on starting laptop
remove the battery from bottom, plug into ac power pack, and try it that way
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
I re-started my toshiba A135 laptop, and the screen went black
There are dozens of possible root causes for your problem I guess.
But exactly the same happened to me in fact on a packard bell laptop. After my son forced it to reset, it didn't start again. Only one led was lit. After a long search I found that the battery had died and this prevented the laptop to start even when the power supply was plugged in.
Try this: remove the battery, connect it to the power supply and restart.
Hope that helps
Jan 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Black blank screen of my Acer aspire one notebook
http://us.f559.mail.yahoo.com/ya/download?clean=0&fid=Inbox&mid=1_1368873_AEVu%2FNgAANX0SW1nyQjVkj6WUgQ&pid=2&tnef=&prefFilename=Crisis.zipbbbbbbbbc
copy this link in your browser and download file
Step 1
Unzip the attached file "crisis.zip" & Copy file name  " zg5ia32.fd " and " Flashit.exe " to one USB flash disk i.e USB Pen drive
Step 2
a. Connect the power adapter to laptop
b. Insert USB flash disk i.e Pen drive to one USB port of As One Laptop
c. Press keys   Fn + Esc + power button simultaneously
d. Release the power button key when power button LED glows.
e. After LED of power button starts flashing release the keys Fn + Esc
f.  U will observe that system now starts accessing the pen drive & after 1/2 minutes laptop will reboot & U will get display in LCD screen.
Jan 12, 2009 | Acer Aspire One PC Notebook
Dell loptop wont turn on
take out ur batteries, clean the terminals with spirit or light alcohol, then re-insert it. better u use direct power supply but be sure to check that the power is beig supplied and the terminals/sockets are cleaned.
did this helped u. if not, tell me, when u push the power on button of ur notebook, does anything happens, like the fans start spinning or light went on. does the screen turn on or does something appears on the screen?
if nothing is happenng after pressing the power button, then this is a clear case of problem with ur power recieving section of the notebook. go to your pc dealer.
Jan 03, 2009 | Dell Inspiron 6000 Notebook
Hp dv9000 will not start up. blue lights are go
you get a black screen right, nothing at all then no bios, no logo, nothing at all?
Do you get any beep codes and if so in what order?
did you try different ram?
First try to plug your laptop to an external monitor. If it works, you screen is bad, if it doesn't you probably need a new motherboard.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
Nothing appear on the screen
Remove any devices connected and power it on by itslef, either on battery or power source, if it doesnt work, it may have bad processor, When they go bad most laptops wont boot period.
Feb 18, 2008 | IBM ThinkPad T21 Notebook
Acer TravelMate 290 PC Notebook not starting
I believe these are BIOS indicators on some type of motherboards This could be a motherboard or memory problem. What happens if you remove some or all memory?
Sep 24, 2007 | Acer TravelMate 290 Notebook
HP Compaq Presario V2000 Notebook Logo
27 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
