Question about HP Computers & Internet
HP G 60 doesn't turn on - HP Computers & Internet
  • HP Master
  • 1,443 Answers
Hello, Sounds like power cord or battery is bad. Here are the parts you need.
Posted on Oct 26, 2015
Logik tumble dryer gdz 60-10sw heard clanging noise now dryer still goes on but drum doesn,t turn.
Sounds like the drum has fallen off of the support rollers. Will need to open up cabinet to verify
Jul 04, 2016 | Dryers
Screen doesn't adjust to the way its being held
Try a hard reset by holding the Power button down for 60 seconds, then release. Wait 60 seconds and turn the tablet back on, if the Kindle continues to act odd, contact Amazon for a replacement, this is not normal behavior and may be a sign of something serious failing.
Mar 27, 2013 | Amazon Kindle Fire HD
Set dead
Did you plug your AC adapter in and then try to turn it on? It may be that your battery ran out of power. Try to plug your AC adapter into your laptop, wait about 2 minutes for the battery to charge, then turn on your laptop. If that doesn't work, you may need to replace your battery. The battery on that laptop is fairly cheap, ranging in price from $10 used to $60 new. If that doesn't work, your power button may need to be fixed. You then need to have it fixed by a reputable computer repair store.
Hope that helps. Good luck!
Jun 27, 2012 | HP Computers & Internet
Dear Sir my pc is cq 60 presairo 205ee notebook i am instal youcam driver but software is not instal this is not your driver i am youser window vista 32 bit webcam is not didect,
One of the steps below should work.
1. Try installing the youcam software below first.
Here is the proper youcam software for your webcam:
http://ftp.hp.com/pub/softpaq/sp42501-43000/sp42568.exe
2. If that doesn't work then update the camera's firmware and try installing the youcam software again.
Your web camera's firmware file:
http://ftp.hp.com/pub/softpaq/sp41501-42000/sp41768.exe
3. If that doesn't work then re-install your motherboard's chipset drivers and try installing the youcam software again.
Here is your motherboard's chipset driver:
http://ftp.hp.com/pub/softpaq/sp39501-40000/sp39903.exe
4. If that doesn't work then see if you have the Intel mobile graphics chipset and if you do install that driver and try installing the youcam software again.
Intel mobile graphics chipset driver:
http://ftp.hp.com/pub/softpaq/sp41501-42000/sp41721.exe
All other drivers are here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3876922#N287
Jun 10, 2012 | Compaq Computers & Internet
0xc19a0035
The ink system failure is a pain to troubleshoot. It could mean that the ink cartridges are not communicating with the print head, the print head is bad or the entire printer needs service.
Try resetting the printer to clear the error from memory:
First with the printer on, unplug the USB cable (if using one) from the printer (and the computer).. Then remove all of the ink cartridges from the printer (lift the scanner unit as if to change the ink). Wait for the printer to indicate "Insert ink cartridge). Then unplug the power cord from the back of the printer. (Note: do not turn off the printer just disconnect the power cord.) I also disconnect the power cord from the outlet and the power adapter (this resets the adapter). Wait 60 seconds or longer. Then reconnect the power cord to the printer, the adapter and then the outlet. Turn on the printer if it doesn't turn on on its own. Reinsert the ink cartridges and close the printer. Print a calibration page if prompted to do so. Finally reconnect the USB cable. Try printing again.
If the message repeats, the unit needs service. This printer doesn't allow the user to service the print head so the cost for servicing is variable. If the printer is under warranty, contact HP for service. Otherwise decide if it is worth the cost of service (expect a minimum charge of $50 just to determine the problem.)
I hope this helps.
May 16, 2012 | HP Photosmart C8180 All-in-one -...
Have a late 2007 macbook pro and it doesn't turn on..tried the pram smc and it still doesn't turn on is there any other way to fix the problem>?
Unplug the power cable; remove the battery then hold down the power button for 30 seconds. Reinstall the battery; plug the power back in and hold down the power button for 30 to 60 seconds and see if it starts.
Aug 01, 2011 | Computers & Internet
ETX 60 altitude doesn´t work, but motor works
You need to tighten the friction lock - it acts as a slip clutch.
Apr 08, 2010 | Meade ETX-60 AT Telescope
Problems with HP HP Pavilion dv5-1159se 15.4
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 29, 2009 | HP Pavilion dv5-1159se Laptop
My HP laptop cannot be switch on problem with virus
do a power drain
1. shut down the comp
2. unplug the ac adaptor
3. take out the battery
4. without any power connect to the comp
5.after 60 seconds plug the battery
6. plug the ac adaptor
7. turn on the comp
Oct 20, 2009 | HP Pavilion dv6000z Notebook
Brand new ink #60 just bought is making the photo all orange
http://welcome.hp.com/country/us/en/support.html  remove the old driver's and get the original one
Jan 16, 2009 | HP Photosmart C6180 All-In-One InkJet...
Computers & Internet Logo
315 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
