Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Water doesn't drain in the bottom of the dishwasher. I have taken all the pieces out and checked for anything clogging it but couldn't find anything. When I first start it on Normal Wash it seems to wait for 30 sec to a min before it starts. It never did this before.
    Genius:
  • 1,036 Answers
Usually this would indicate a pump stuck by debris, but check the condition of the outlet hoses first.
If they are severrely clogged, try a couple of cups of washing soda in there, then wash through with a few bowls of hot water with the outlet hose resting in a low position. With the outlet hose low, the water will just drain out if the pipes are clear, and the soda will help break down the grease.
If you get as far as investigating the pump impeller - be careful as broken glass is often the culprit, and almost impossible to see in water.
The waiting is it figuring out why it has water in there - and what to do with it.
Posted on Feb 07, 2010
Have you tried **** cream?
Doesn't drain out all the way water stays in
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Maytag Dishwasher
Water will not drain out from the bottom
Hi
Daniel
Aug 22, 2011 | Amana 24 in. ADB3500AW Built-in Dishwasher
The water is not draining from the bottom of my fdb2810ldc1 dishwasher
Hi
Daniel
Aug 11, 2011 | Frigidaire 24 in. PLD2850 Built-in...
My dishwasher doesn`t drain. there is water at the bottom at te end of every wash... what`s wrong? how can i fix it?
Hi
Daniel
Aug 06, 2011 | Whirlpool Dishwashers
Water left in bottom after running dishwasher
Hi
Daniel
Aug 01, 2011 | Whirlpool Dishwashers
I run the cycle and there is still water on the bottom
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If it's still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 08, 2011 | Whirlpool 24 in. DP840D Free-standing...
Water is still present after cycyle on bottom of dishwasher
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
May 18, 2011 | KitchenAid Dishwashers
Dish washer has water in bottom & double beeps when trying to start
Hi
Daniel
May 06, 2011 | LG 24 in. LD-12BW5 Free-standing...
Water won't drain in bottom
Hi
Daniel
Apr 21, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
There is a lot water left in the bottom of the dishwasher. It looks like it isn't draining out.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance. Daniel
Apr 18, 2011 | Frigidaire 24 in. PLDB999S Stainless Steel...
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
90 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
