Question about Whirlpool GR460 Electric Kitchen Range
It keeps flashing a E2 and F3 while im trying to cook
    Sergeant:
    Champion:
  • 263 Answers
Bake range over temperature. It means you either need a new board or a temp. sensor.
Whirlpool range repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 07, 2010
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 | Ovens
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
I had the E2 F3 code while I was baking something. Is it safe to eat the food that was in the oven at the time the error occurred?
F3
- E2 Oven temperature is too high (Cook
mode)
Replace
Oven temperature sensor (RTD)
Note: Applies to all
F3-E... codes.
Dec 21, 2010 | Whirlpool GR460 Electric Kitchen Range
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
Hello my oven will not turn off and it gives me an error of E2 F3
F3
(upper oven, if double oven) Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
mode)
Dec 11, 2010 | Kenmore 96422 / 96424 / 96429 Electric...
What is E2-F3 mean on the gas range display?
Note: Applies to all F3-E... codes. F3 - E2 Oven temperature is too high (Cook mode)
Nov 22, 2010 | Ovens
Failure/error display E2 -F3- What is going on? When using the oven
Oct 24, 2010 | Whirlpool GBS277PD Electric Single Oven
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Whirlpool accubake self clean oven. Error code(s) E2 - F3?
You can get all the codes here.
F3 E2 9 Bake range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control.
http://www.repairclinic.com/0078.asp#Westinghouse
Good Luck and Please Rate FixYa!
Jan 07, 2009 | Whirlpool RBS305PDS Electric Single Oven
Error codes e2 and f3
F3 is an open or shorted oven temperature sensor, you will have to replace this and it should be attached near one of the elements but you will have to pull it out through the back.
E2 is, sorry to say, a possible ERC or Electric Range Control, otherwise known as the brain behind it. But on the plus side, sometimes it gives this code intermittently when it can't process the information from a failed sensor, so you might get lucky.
Jan 28, 2008 | Whirlpool GR460 Electric Kitchen Range
Whirlpool GR460 Electric Kitchen Range Logo
153 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
