I have a FilmScan35 I slide scanner, and am using Windows XP. I get the message "Cannot install this hardware". Help!
  • jlynes Feb 09, 2010
    Thanks for your suggestions.
    I still get the message "Cannot find camera". "Imaging Devices" lists "35mm Film Scanner", and then "The drivers for this device are not installed".
    John Lynes
    President:
  • 547 Answers
Try installing the drivers from this zip file and let me know if that works.
If it still doesn't work, open the Device Manager (Control Panel -> Administrative Tools -> Computer Management, then click on Device Manager) and tell me what all you see under USB Devices.
Use the "Add Comment" link to post back to this problem.
Posted on Feb 07, 2010
Benq Mirascan 4.00 won't find Benq 4300 scanner using Windows 7 32 bit
I think this scanner is not supported in Windows 7 OS. You can alternatevely try to install Virtual PC->Windows XP Mode and install your scanner there, so you could use your old hardware. If you want to follow my advise, go to this page and follow the instructions about downloading and installing Windows XP mode on your workstation.
Nov 23, 2011 | BenQ Office Equipment & Supplies
I have a Canon 4200F scanner and recently purchased a new computer with Windows 7 that is 64 Bit. When I try to use the scanner get a message that I need a WIA driver to use this device. Can you please...
Hi bjgestel !
This means there is no more support from HP for your unit under Windows 7 but Windows has a compatible driver included in it's system ( WIA ) .
The scanner should run smooth but with some restrictive functions . Normaly , it should run without having installed the HP XP driver/ sofware . If this not your case , there is a workaround after you installed the XP driver and made sure installation was successfull . The scanner will need to run with a third party application . Download FreeKapture from
http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Launch Freekapture , clic on Scan , select WIA-Hewlett-Packard . Your scanner will run . If you choose HP's software, program will hang .
Note : no slides or negatives scans possible in WIA mode but the rest works .
Good luck !
fanaudi .
Feb 22, 2011 | Office Equipment & Supplies
I am running windows xp and the scanner is not recogized
make sure you installed the driver for it and selceted the right printer.
Nov 29, 2009 | Office Equipment & Supplies
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
Scansnap manager won't properly install on windows xp...
Problem solved. Ignore the "Windows XP approval" message & continue with the fix suggested in the troubleshooting section of the manual.
Feb 18, 2009 | Fujitsu ScanSnap S510
CanoScan640P ex
If upgrading an existing PC to Windows XP from an earlier versionof Windows, Canon recommends a "clean install" to ensure reliableoperation of drivers. If a clean install is not possible, it isessential that drivers for your existing Canon Hardware are UNINSTALLEDprior to upgrading to Windows XP. After the installation of Windows XP,the drivers for your Canon Hardware can then be re-installed. Canon has released a software utility to uninstall USB and SCSI Scanner drivers for this purpose. Click here to download this utility.It is recommended to consult our Driver Downloads page and use the latest driver for your product. Canon supports several scanner models with Windows XP. Windows XPsupport is offered for Windows XP Home Edition, and Windows XPProfessional.The following older models are not compatible with Windows XPdue to hardware design: IX-3010, IX-4015, IX-4025, CS 300S, FB310,FB61
Source
Sep 20, 2008 | Canon CanoScan N640P Flatbed Scanner
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Microtek Scanner installation issue
If running XP SP2, then try clicking Start > right click My Computer > properties > Hardware tab > Device Manager button > expand Imaging devices > right click on your Microtek ScanMaker > uninstall > Re boot > and let XP pick up the device and let the found hardware wizard configure it.
I have seen plenty of hardware that when following the devices manufacturer's instructions for install, such problems as you're having occur and XP SP2 usually will cure it, though you may still need the device manufacturer's CD (for the driver) in your optical drive.
This link: http://support.microtek.com/downloads/bymodelname.phtml?viewtype=2&srch_in=ScanMaker+5950&frmsearch.x=10&frmsearch.y=11&frmsearch=Search&frm_rqst=2&axn=1 will allow you to select between the 5950 and 5950 Pro then on the next page you will be able to download the latest XP driver for your Scanmaker among drivers for other Operating Systems also.
I hope this helps, and Good luck.
Mar 21, 2008 | Microtek ScanMaker 5950 Flatbed Scanner
"Scanner not found" message
I have found a support site for your scanner that may be of some help... Please check your ports are compatible.. as far as speed and type. Have you installed the MOST up to date drivers etc? Check all cables etc. support.microtek.com/product_dtl_2.phtml?prod_id=22
Aug 16, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
