Question about Toshiba Satellite L305D-S5881 Notebook
WAS RUNNING ON BATTERY, HAD 5 MINUTES LEFT PLUGGED IN ADAPTER, NO ICON SHOWING IT GETTING JUICE. TRIED TO SHUT DOWN, BUT, RAN OUT OF BATTERY BEFORE SHUT DOWN COMPLETE.....NOW NO LIGHTS NO MOVEMENT, NOTHING...THOUGHTS?
  • kchandler707 Feb 07, 2010
    it has been plugged in 48 hrs now and still nothing :(
  • Toshiba Master
  • 12,061 Answers
Ok when this happens it takes a considerable time for the battery to recover, you should plug in the adapter and leave it for at least overnight without using it, hopefully then after that the battery will be charged. This is very common.
Posted on Feb 07, 2010
  • electronic & computer repair&  servicre
    Hmmmm,,,, Damn. Can you check your power adapter, is there a light ON the adapter? OK anyway take battery OUT & try using with just the AC power adapter, does that work?
Battery ran out, I have charged it but only windows icon flashes and won't turn on?
is the battery showing fully charged ?. If it is remove the battery for a few minutes then replace it this will reset it without any data loss .
Oct 13, 2014 | Cell Phones
MY COMPUTER SHUT DOWN UNEXPECTEDLY AND WON'T TURN ON AGAIN
I usually try to hold the power button for >5 seconds to reset it. No lights even when plugged in?
Jan 01, 2013 | Computers & Internet
Nokia N900 not turning on or charging
not turning on. red notification light showing
May 14, 2010 | Nokia N900 Smartphone
Hp530 power on password prblem
The reason why your password is still re-curring after removing the CMOS battery is because when you were doing so, some of the cables supplying power to the Board were still plugged.
So before using the CMOS removing method, first make sure that you have disconnected ALL source of power supply cable from the Board, then remove the CMOS Battery for a few seconds, and re-insert it. It should work like that.
Jul 09, 2009 | HP 530 Notebook PC
Gateway laptop randomly shut off and wont come back on
Try removing the battery and see if will start up with power adapter. The battery may have failed. If it is a couple years old the battery may need replaced.
Apr 01, 2009 | Gateway Computers & Internet
Freezes on 'Samsung' screen
While the unit is connected to the PC, hold down the RESET hole at the back for 10 seconds.
Mar 23, 2009 | Samsung YP-Z5FA MP3 Player
Will not boot up or turn on though it is getting power
The Charger could be bad, Try replacing that, or let charge, then try to turn on. The laptop might not boot with AC power. kinda stupid but maybe. If that doesn't work, the AC adapter is bad.
Jun 12, 2008 | Lenovo 3000 N100 0689 Notebook
Laptop Power Issues
Most laptop batteries would die out after a year or two. None the less, the laptop should work with or without the batteries.
In some instances, the batteries have deteriorated to the point that it will gobble up the power from the charger denying sufficient juice for the laptop's use. The temporary workaround is to use the laptop without the batteries. if removing the battery and the unit powers up/works, then you have verified that indeed it is the battery causing you problems.
If even without the battery the unit will not operated, you can suspect the charger not 100% compatible with your laptop. If it is an original charger, then you can conclude that something is wrong inside the Toshiba.
I understand that the original charger intended for a Toshiba P25-S670 is 19VoltsDC. 6.3Amperes (120Watts).
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 02, 2008 | Toshiba P25-S670 Notebook
Wont go on
Dumb question, is it plugged in? Can you verify the lappy is getting DC juice from the power adapter?
If electricity is available from the charger, when plugged into the lappy can you see a charging icon either on the battery or some sort of display near a on, wireless, power, battery display? If no symbol shows charging, you either have a bad jack in the lappy or a bad battery.
If DC is not available from the charger, then it's bad.
Hope that helps;)
Dec 24, 2007 | Computers & Internet
Toshiba Satellite L305D-S5881 Notebook Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
