Question about Indesit W 123 Front Load Washer
Indesit wixe127 f-08 error - Indesit W 123 Front Load Washer
I have the same problem. Check this info (the below link) I found on F - 08 error for someones hotpoint washing machine. It may be the same thing. There could be standard error codes for all washing machines, maybe.
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&printertopic=1&t=37910&start=0&postdays=0&postorder=asc&vote=viewresult&popup=1
Posted on Feb 24, 2010
  • Duckling1992 Feb 24, 2010
    Does your washing machine fail to rinse the water out of the clothes and leave them lukewarm as soon as it kicks into the error mode?
5 Suggested Answers
  • 4 Answers
SOURCE: Hello, i have an Indesit
F05 is where the pressure switch has not reset within 10 minutes of emptying on any part of the cycle. Basically this means the pump is not pumping the water out. This could be a blocked filter (located on front of machine at bottom behind the kickstrip). Be careful when removing the filter as it unscrews anticlockwise and if the is water in the drum then tilt the appliance back at 45 degrees and put a large bowl underneath to catch the water. If the filter does not unscrew then theres definitley something in the filter. When the filter is out put your finger inside to rotate the impellor. This should spin freely. If this does not solve your problem check for blockages where the grey drain hose connects to the sink (it could be blocked there).
Posted on Apr 17, 2009
barkencoa
  • 3463 Answers
SOURCE: error code f-08 on indesit wixe127 washer
Error code F08 means that the heaterrrelay cannot be activated.
Check the connections to the Pressure switch, the Module,and the Heater element.
If you can, test the element of the heater to make sure it is o/k.
Hope this helps.
Posted on Dec 02, 2009
barkencoa
  • 3463 Answers
SOURCE: Error code F-03 Indesit wixe127
Hi.
The code F03 means the wash thermistor is open circuit.
Unfortunately, you will have to call an engineer.
Cheers.
Posted on Nov 21, 2008
  • 14 Answers
SOURCE: indesit wixe127 error code F05
I removed the drain pipe and ran the wash cycle into two buckets which completed correctly.
I therefore checked the drain connection to the sink and found a lot of fluff blocking up the hole.
The fixya guru suggested it could be pump and / or pressure switch but it was much simpler than that.
Us engineers often dive in at the deep end with technical fixes but sometimes the solution is simple.
Posted on Jan 17, 2009
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
F06 error on indesit WD 61451 washing machine
Could be the program select error, but why not check all error codes and save them on the Indesit site yourself.
Error Codes Indesit Service
Feb 25, 2015 | Indesit Washing Machines
Indesit w12s
the code 10 on the model listed is a fault code for pressure switch,first check if appliance is draing water,if not listen for pump and check filter.
Jan 27, 2008 | Indesit WA 125 Front Load Washer
Indesit we14
Hi l have a indesir WIE147 that keeps on flashing F 01 repair man came changed module and next day same thing happened again HELP PLEASE
Nov 13, 2007 | Indesit W 123 Front Load Washer
Error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Aug 11, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
1,404 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
