Z313 speakers - Computers & Internet
  • cadd2813 Feb 07, 2010
    The speakers have sound for everything except for signal from contact while i'm in Logitech Vid.
  • 1,183 Answers
Could you give more information on what problems or concerns are you facing with the Z313 speakers. So that we can help you better.
Thanks for using Fixya
Proton
Posted on Feb 08, 2010
  • 3,230 Answers
Well can you please describe your problem in details..... so we can help you on right way........
Thanks
Posted on Feb 07, 2010
Schematic for logitech z313
I couldn't find a schematic but...
The red and black wires go to the subwoofer.
The white and black wires are main level inputs that go to the toroid.
The blue, green and black wires are the output from the rectifier.
Tthe green is your negative rail while the black is 0v and the blue is positive
Sep 05, 2016 | Logitech Audio Players & Recorders
Logitech Z313 Sound System Failure
On the basis of your description, you can conclude that your Logitech speaker system has failed.
Mar 18, 2014 | Sun -115H Computer Speakers
The volume on my z313 I hook it up to my computer is to low
There should be a volume level adjustment on the speakers.
Verify the master volume on the computer is turned up as well as the volume of the app in use is turned up.
Oct 21, 2013 | Logitech Z 313 - 2.1-channel PC multimedia...
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
Z313 no sound
Phone plug on subwoofer plugs into phone jack on back of tower! Plug and jack are color coded green. If you plug into wrong jack you get no sound or intermittent sound. Also speaker cables have an on-off swith so make sure you are switched "on" or you will not get sound.
Oct 30, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
How to connect logitech speakers to computer
Have you gone into your control panel and checked the speaker volume ???
Start, Control Panel, Sound
May 17, 2012 | Logitech Z313
Z313 one speaker stopped working
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the
computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems:
hope this helps you
Oct 04, 2011 | Logitech Z313
Connected up z313 speakers. have motherboard HD sound installed with my windows 7. no sound coming from sub or speakers. can plug head phones into the z313 controller and listen to music. plz help
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 31, 2011 | Logitech Z313
Logitech Z313 how to install it in your computer
plug these speakers
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 11, 2010 | Logitech Z313
All of a sudden the speakers stopped working. i can't hear any sound.
de rrepente los altavoces tienen un ruido en el sonido
Nov 22, 2010 | Logitech Z313
Computers & Internet Logo
David Payne
David Payne
